How to pull down overhead console for radar install?
Old Jan 17, 2006 | 05:32 PM
Fikse's Avatar
STS,FGT,12C,P85D,M4
Anyone know how the overhead console that has the lights, sos switch and sunroof switch comes down? I'm going to hardware my V1, but don't want to break anything...
thanks....
Old Jan 17, 2006 | 10:21 PM
Hook's Avatar
thanks....
I'm not positive about this, but ... I believe that if you pop off the 2 translucent light covers (the larger ones), there are 2 small holes. If you stick something sharp (e.g., scratch awl) in these holes, you release clamps. Then you can twist the mirror out & you will see how to remove the entire assembly.
I hope this is helpful.
Hook
Old Jan 17, 2006 | 10:49 PM
DarkStar's Avatar
03 E55
you don't need to pull it (the int. lights) down...do a search there are some great instructions as to how to hard wire the V1. I just did the one I got for XMAS, it was easy....good luck
Old Jan 17, 2006 | 11:06 PM
Fikse's Avatar
STS,FGT,12C,P85D,M4
yep, i have that write up.... i was hoping to tap into power up there, but it might be easier to run the wire down the lighter....
thanks..
Old Jan 17, 2006 | 11:20 PM
L8Apex's Avatar
05E55
Does anyone have the integrated V1 in their rearview mirror? I have it on my BMW but have not seen it for Mercedes.
Old Jan 18, 2006 | 07:05 AM
Hook's Avatar
I have this setup, as do several others on this board.
Hook
Old Jan 18, 2006 | 06:35 PM
pas's Avatar
pas
2007 S65, 2005 Nissan Armada
Hook
where do you get it??
Old Jan 18, 2006 | 06:48 PM
Vetluver's Avatar
SL 65 AMG and E63s AMG
V1 uses 12v. There are 4 places where 12v are found,(that I know about) the cig lighters, front headlights and the battery. I tied into the headlight circuit. Getting into the cigarette lighters is tricky and I haven't found the secret to getting them apart. As far as I know nothing in the dome light assembly has switched 12v, it's all low voltage. Hope this helps.
Old Jan 18, 2006 | 07:16 PM
Fikse's Avatar
STS,FGT,12C,P85D,M4
I got the overhead console down, you remove the small plastic trim piece that goes around the rear view mirror, then there are two buttons up there to release the clips.... it was mess up there, all kinds of ribbon cables and such, so I just ran the wire down the the cigarette lighter, much easier.....
Old Dec 29, 2006 | 07:23 PM
W Cole's Avatar
makes your daughter horny
Any more info on how to do this? I cant figure it out...
Old Dec 29, 2006 | 08:41 PM
PerisanGodFatha's Avatar
is Sick as Fu*k
any pics or instructions on how you did it threw the cig lighter???
Old Dec 29, 2006 | 11:50 PM
Dogshine's Avatar
CLS55
tap into the cig lighter and then run the wire above the passenger footwell under the dash and up the passenger side a pillar.
