CORRECT TIRE SIZE FOR E55/211 19" WHEELS?
I have ordered some 19/8.5 front and 19/9.5 rear wheels for my 03/e55,i want to know which is the best tire combination to use with these size tires,without me experiencing any rubbing or rear end wiggle.
![](https://mbworld.org/forums/images/ranks/veteran_air_force.png)
245/35/19 front
275/30/19 rear
probably depending on offset you could also do:
255/35/19
285/30/19
follow this thread:
https://mbworld.org/forums/w211-amg/136949-19-wheels-255-285-loss-acceleration.html
275/30/19 rear
255/35/19
285/30/19
follow this thread:
'03 G500, '13 G63, '17 GLS63,
What type of wheels did you order? The fitment depends heavily on the offset. When I first recieved my Iforged wheels, the rears were 19x10 with 275/30/19, but they rubbed on every small bump due to them sending the wrong offset. I had to send them back to have the correct offset built and the ones I have now fit perfectly with no issues.
Personally, I would not run anything less than a 245/35/19 and 275/30/19. Assuming the offset is correct, these are the ideal sizes that everyone seems to run with no issues. Seems that the 295 width is the one that rubs on the inside rear.
2017 S63 Coupe Iridium Silver
Originally Posted by jamusa
What offset on a wheel would be needed to 255/19 front and 285/rear.
With ET38 you will have only 3mm gap between the tire and the fender on full compression. (to test, you drive one rear wheel up a tall curb and after the car has levelled off, your rear wheel will be right up to the rim. Take two or three credit cards and move them around the tire in the gap between the fender.
I have the ET35/255 and ET38/285 set up.
F248 F1
Here's this page... i got it off somewhere ! i think it's very neat !
http://www.gdtm.net/tirecalc.htm
