Dyno results w211 K1
1 Post
'79 300D, '85 300Dt, '99 CLK430
Trick is a company that produces racing fuel, 101 is street legal.
http://www.trickgas.com/unleaded.htm
I wonder how much power the car would make on 91 octance
07 S65
Doesn't add up? Take the car to a track! I hope the numbers are right I just don't think it's possible. Look at what everyone else with K2's are pulling at the rear wheels. You have almost 100 more hp at the tires than they do. I just don't think it's possible. These motors are hand built and we really don't have that big of a gap between each others cars. I know your excited but, I just don't think it's accurate. Let us know what it runs at the track. With that HP you should be close to the 10's with DR's, at least 11.teens. Good luck.
2003 E55 & 2014 GL550
Trick 101 Must = 50 shot of nitrous.....
Can you post up some info on the system you used....wet or dry...AND where in the hell does that switch go in such a luxury car.
Oh yeah, spent over 12k for my mods and pulled 476rwhp so on behalf of all of us that got...
12' C63 P31, 06' Supercharged Range, 08' BMW 550i
Originally Posted by grussell
I know, I couln't believe it either.
After the first run, I said that's at the crank, right? He said no. I said well your dyno is broken! He said no, that's at the wheels and it's correct. OK, we do it again and it get's higher! We ran it with ESP off in 4th gear to 179mph, I thought it was going to blow up! Go figure! I guess I need to go to the track!
A similar thing happend with a guy on this board who has a SLK 55KS8. Dyno said almost 500 rwhp but the car was only really putting down around 440 rwhp. The dyno was calibrated incorrectly.
Take the car to the track and let's see what your trap speeds are.
I would much rather of had a few strong pulls that are within the expected range. Oh well, I guess I will take it to another shop and have it dynoed again.
#32
Super Moderator
The same place dynoed Speed Thrills CLS55 K1 and his best pull was:
464rwhp and 535rwtq
464rwhp and 535rwtq
And I need more pics of your car. Can you give me info on your wheels as far as size and width. Those wheels look HOT!~!
#33
07 S65
I am not excited, I am frustrated. Just like you and everyone else, I don't believe the numbers. I want to, but there is no way that they can be right.
#34
Administrator
I agree with E55 Baller, You have to get that freak to the track and get a trap speed. If you trap higher than 123mph. I will be the first to have a K2 to K1 conversion........................................ ......I wonder if Cory will give me a partial refund?
#35
Originally Posted by BenzoBoi
Do you mind tellin us where the place you went to dyno?
BBS RS-GT Diamond Black 19" x 8.5" and 9.5" ET32
#37
Pretty cool. You're only 20hp behind my K2 E55 with a 65 wetshot. If all dyno's are correct (insert laughter here), then you should run around 11.3-11.4 with better tires. With street tires, I'd imagine you should be 11.5ish. GET TO THE TRACK SIR!
#38
05 sl600, 06 CLS55 AMG, 1971 Cuda
Oh yes, very!!!
#40
Originally Posted by SLVRBLT43K
The way you answered you must know what happened with my car over there! So much power out of a car, you sure they did not install anything extra in there?!!!!!!! May be I should write about my experience!!!!
#42
#44
No, I don't know, but I would love to hear about it!
#45
Lets put it this way my car is on its way to Colorado.
#46
#47
I don't know what that means, but ok. I guess it is going to Kleemann.
#48
Why would I send my car to Kleemann? Because it is all messed up I had a burnt ME !!! The car is going there so actually someone who knows about Mercedes is going to work on my car. Kleemann products are #1 the installers on the other hand.........!
