*** Paging: Guys with M20/M40 Blinder ***
2003 E55 AMG
Where is the best place to mount the 2 laser jammers in the front of the car? Should they be mounted behind the lower grill (the steel mesh area) or behind the upper chrome grille??
Could someone post a pic of the front of the car showing the locations of the 2 jammers.
Also, do any of you have the rear jammers mounted? If so, where?
Thanks in advance!
Thanks in advance!
1 Post
STS,FGT,12C,P85D,M4
I would say behind the grill, it's chrome and between the headlights, the most tarketed areas for laser...
as for the rear, who has actually been lasered from the rear? I thought laser has to be used stationary, so it's not like they are following you with laser.... I guess you speed right by the cop, don't slow down, and he lasers your tag from behind......
Thanks in advance!
Thanks in advance!
2003 E55 AMG
In either area they should work fine. Just be sure to follow the spacing recommendations per the instruction manual. When I had my C43, I had them mounted in the lower area beneath the license plate and they worked perfectly.
You won't be disappointed with the Blinder system, definitely saved my *** a number of times.
2004 E55 Evosport I & II; VRP H/E
Victor:
Here are some photos of mine:
https://mbworld.org/forums/w211-amg/91850-lidatek-blinder-laser-jammer-install-question.html
Mark.
Mark.
I did an install several months ago that I think is quite good. I've installed units in numerous vehicles. I installed them on my 05' E55 behind the hood grill. I will take pictures as soon as the rain stops and I can get the car out of the garage.
Glenn
Glenn
Don't want to say anything negative, but those heads are likely WAY to far back (m)
Originally Posted by glennbaz
Here are the pics of my install. You can email if you have any questions
Actually, they are not as far back as they might appear. The grill slats have been cut in the rear to bring the heads as far forward as possible without destroying the grill. I do agree that any heads should be exposed as much as possible for the same reasons you state. It’s tough finding that happy medium between functionality and appearance.
Glenn
Glenn
