*** 80mm AMG Throttle Body ***
Rating: Thread Rating: 2 votes, 5.00 average.
Old Oct 19, 2006 | 02:39 PM
  #551
theboogers's Avatar
2020 S560,14 ml350, 03 sl55, silver, pano, slr cams, evo headers, lsd, 2019 s63 cab.
finny- did you have to replace gaskets when you put back together?
thanks
Old Oct 19, 2006 | 02:58 PM
  #552
Finny's Avatar
03 E55 AMG
Thumbs up
No, just an inspection and some cleaning. I used sensor safe blue silicone on the super-charger output to inter-cooler mouth.
The factory used some type of black gunk which beaded into the chamber.
Just remove clean and reapply safe blue "sparingly!"
Did I explain correctly...?
Old Oct 20, 2006 | 11:33 AM
  #553
theboogers's Avatar
Victor- when i get the new kit from you i wanted to take the old tb and bore it out to use on my s55. if i was bore out to 76mm or so do you have the change the throttle plate to be larger or just let the gap be around the plate.
Old Oct 20, 2006 | 12:13 PM
  #554
vrus's Avatar
2003 E55 AMG
You may or may not be able to do this. If your car has the solid 1 piece TB that is epoxied together you wont be able to pull it apart to port it.
The only way to know for sure is once you get it out of the car and inspect it.
If you do port the TB and put it in the other car, you should really port match the S/C inlet otherwise there is no real benefit.
Old Oct 25, 2006 | 11:48 AM
  #555
vrus's Avatar
2003 E55 AMG
All parts for the 13 remaining kits have arrived from Germany.. I have 10 of the 13 kits in my possession.. 3 kits still need to be picked up..
I have the machine shop working on making 15 adapter plates (that's only 2 extras) and they are going to be ready today.
Tomorrow I will dissassemble the Inlets (remove all the plastic pieces) and prepare them to be welded and hopefully drop them off at the welder.
Old Oct 26, 2006 | 02:43 PM
  #556
vrus's Avatar
2003 E55 AMG
Kit #23 - Cosm
Thanks Sean!! Your parts have been ordered.
Old Oct 26, 2006 | 05:39 PM
  #557
mbamg06e55's Avatar
06 E55 SOLD, 89 300 SE 375,000 miles
I cant wait to come back from SEMA to see my new toy waiting for me.
Old Nov 3, 2006 | 07:04 PM
  #558
MACHC5's Avatar
Veteran: Army
CLK63 Black, E350 Wagon, Supercharged Denali, Lotus Elise, Tesla Model 3 Dual-Motor.
I dropped off the car to have the "V80mm" T/Body installed over the weekend. Now I'm feeling like... I'm waiting for the great Dolemite on Halloween Eve...
Old Nov 4, 2006 | 09:42 AM
  #559
pas's Avatar
pas
2007 S65, 2005 Nissan Armada
Are we ever going to see dyno results from anyone who has put this thing on????? You need to be pretty patient around here!
Old Nov 4, 2006 | 09:52 AM
  #560
Kev04C320's Avatar
'09 911 C4S
Didn't Kens-E55 already posted his results earlier with the VRP 80mm TB?
Old Nov 5, 2006 | 03:29 AM
  #561
vrus's Avatar
2003 E55 AMG
TB's will be going through porting this coming week.. They should be shipping by the end of the week.
All future TB kits will have a 1 week turn-around time after these kits are done. I've found a way to eliminate some steps and refine the kit further. I will be able to do 1-at-a-time kits again now that some new stuff has fallen in my lap.
Old Nov 6, 2006 | 05:20 PM
  #562
Kens-E55's Avatar
2004 E55
Yes - with the K3VRP set-up my best dyno runs were 528rwhp/595rwtq in 70 degree weather..... For grins I went to a neighbor business this morning who had just put in a 4 wheel "Mustang" dyno (He works alot on rice-burners)
and the car was literally not able to dyno as each time you would "throttle-up f/2k rpms....the tires (295/30/19's - PS2's) would actually start to simply break loose and "spin freely" on the mustang dyno. We then put 500lbs of people in the back seat...drop tire pressure to 25lbs....and @throttle-up, the car was actually creating wheel-hop
needless to say, after 5 pulls we finally gave up.
The dyno was a "small wheel" dyno and I really need to find a "large wheel" dyno to test the ANIMAL in my car
I did a test on the way home this afternoon in 82 degree weather and ran a 121+ trap speed in the 1/4mi. I NEVER could do that kind of trap in 80+ temps with the stock TB. - This 80MM VRUS TB is the real deal!!
Old Nov 6, 2006 | 06:12 PM
  #563
Jakpro1's Avatar
2003 E55 & 2014 GL550
Your CAR is the real deal!!! Thanks to Klee and V!! Just awesome numbers.
Old Nov 6, 2006 | 06:58 PM
  #564
Kens-E55's Avatar
2004 E55
If that's directed to my car - I appreciate Jakpro......but I do believe your still a shelf above me!! If mine's the real deal....your the big KAHUNA!!
Needless to say K2 with VRUS TB's has truly brought us all to a new level....and it's so much fun to enjoy it!! Thanks Victor again for making this so easily "plug-n-play"
and while I'm throwing out congrats.....did I tell you how GREAT my car from top to bottom looks since Chris @C2Designs in Tampa did the interior?.....I know I did but he deserves another "plug" .... Thanks Chris!!
Old Nov 6, 2006 | 07:42 PM
  #565
Rock's Avatar
Administrator
Drives Slowly
Just wanted to post the results (in this thread) that I achieved with Victor's AMG throttle body. It proved to be more than just a butt dyno improvement. https://mbworld.org/forums/w211-amg/169502-proof-positive-80mm-tb-works-time-slips.html
Old Nov 7, 2006 | 05:41 PM
  #566
vrus's Avatar
2003 E55 AMG
Kit #24 goes to Ted Baldwin.
I am just ecstatic that you guys are enjoying the mod... All your cars sound just insane based on the power they are putting down.
I have revised the kit even further now.. Lead time to make them now will be 1.5 weeks based on delivery of goods from Germany. (It takes 1 - 1.5 weeks for parts to arrive with normal delivery). Because of these new designs I can do one-offs again if needed..
It will either be Kit #24 or Kit #25 which will be the new revised one.. There will no longer be a 3/8" adapter plate for the kit. I have a new 1-piece cast part that will replace the stock inlet. I'll show a pic of it once I get it back from the manufacturer.. It's a surprise..
Old Nov 7, 2006 | 07:15 PM
  #567
mbamg06e55's Avatar
Victor,
What would the one pc SC Inlet cost. What I was thinking was buying the SC Inlet off the new 07 SL55 and seeing if they work. I know that these come with the 80mm throttle bodys.
D
Old Nov 8, 2006 | 08:08 PM
  #568
Finny's Avatar
03 E55 AMG
Originally Posted by mbamg06e55
Victor,
D
D,
Don't waste your cash, just mod the one I sent you...
Cheers Mate
Old Nov 12, 2006 | 01:51 PM
  #569
MACHC5's Avatar
Veteran: Army
Hey Guys... Car was fired up yesterday....
All seems well, no lights, bells or bad messages from the ECU...
"VIC's the MAN"...
After installing T/Body turn key to on position without starting for 90 seconds for ECU check's and balance's to occur...
Just got to finish the IPOD & SIRRUS installs and start enjoying the new performance and sounds...
Old Nov 12, 2006 | 11:31 PM
  #570
vrus's Avatar
2003 E55 AMG
Not sure of exact pricing yet.. I'll post a pic very soon of the revised part..
Victor,
D
Congrats!!! Glad to hear everything went smooth.. Go drive it now and tell me what you think.. Car will feel alot better now that it is gulping alot more air..
"VIC's the MAN"...
Old Nov 12, 2006 | 11:32 PM
  #571
vrus's Avatar
2003 E55 AMG
All inlets are at the porting shop and have the welding complete.
Picking up 5 or 6 of the ported inlets tomorrow and will pack them and get them ready for the new owners..
Old Nov 13, 2006 | 06:54 AM
  #572
theboogers's Avatar
vic- just wanted to make sure you got my email. i will be closing my business from 11-16 till 11-25 for vacation. please hold my shipment for past these dates. thanks
Old Nov 13, 2006 | 10:32 AM
  #573
vrus's Avatar
2003 E55 AMG
Kit #25 goes to Scarafin
Just got a call from the porting shop.. 8 inlets are ported and ready to go.. I am going to pick them up later this afternoon.. I'll get everything ready and packed and should be able to get them all out for tomorrow.
These are the recipients of the 8 kits:
- Jspeed
- Loren
- e55 baller
- E55 Russ
- Fleebee
- jmf003
- rflow306
- clum553946
The remaining kits have the following status:
- GhettoDreams: porting
- mbamg06e55: porting
- Mad TKD : porting
- chiromikey: porting
- theboogers: porting
- Cosm: porting
- ted baldwin: waiting for parts from Germany
- Scarafin: waiting for parts from Germany
Got your message... Kit will be waiting for you when you get back. Have a great vacation.
Old Nov 13, 2006 | 08:52 PM
  #574
Apple '55's Avatar
'03 E55 AMG
It's in the shop now.........
Hey Victor:
FYI Just got around to the install today. Will try to get some dyno numbers soon!
Old Nov 14, 2006 | 05:38 PM
  #575
Apple '55's Avatar
'03 E55 AMG
Wow!
It's back and according to the tech who did the 80 MM TB install, he has never been in a faster car in his life! It even sounds faster. For sure it will torch Ken's 55 head to head Now it's off to the Dyno on Friday
Thanks Victor for all the R&D you put into this and for making it actually happen!
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
