12.1 @117mph..that seems slow for a K2 car doesn't it?
Old May 4, 2006 | 04:39 PM
silversurfer's Avatar
'05 E55TK, '00 Brabus/Kleemann 5.8 GCab, '05 CLK DTM
the particulars:
3/4 tank of 100 octane - should've been 1/4
DR in rear @ 27 psi
Dyno mode
1.8 60'
miserable R/T
Track was dry and approx. 65 degrees.
Both me and KenE55 (stock, averaged around 12.5 @ 112)experienced better ET but lower mph than previous runs. Any ideas?
Old May 4, 2006 | 04:56 PM
dragonAMG's Avatar
12' C63 P31, 06' Supercharged Range, 08' BMW 550i
Indeed that does sound slow for a K2 car. Not too concerned with the et, simply because excessive wheel spin from too much power can cause ****ty e.t's. MPH should be upwards of 120 on a K2 car. MPH is a good indication of how much power your car is really making.
Old May 4, 2006 | 05:32 PM
Bigdot's Avatar
some
maby its just the launch. then again i have no idea what i am talking about.
mark
Old May 4, 2006 | 06:07 PM
Rock's Avatar
Administrator
Drives Slowly
This may be BS but at the end of last year, right after I had K2 completed, I went to the track and ran low 12s @ 118 to 119. I was a little disappointed with this so I called Cory (at Kleemann) about my numbers. He told me that the computer adapts to your driving style and responds accordingly. So, that being the case I drove the living **** out of her for two weeks, returned to the track and trapped @ 122and 123mph on every run. Go figure.
So, my advise................. drive it hard for a couple of weeks and return to the track.
Old May 4, 2006 | 07:10 PM
Grumpy666's Avatar
Do what Rock suggested with a 50/50 mix of 100/91 octane fuel. Use the same mix at the track for your next run.
Old May 4, 2006 | 11:33 PM
Why would a mix of octane perform better than only 100 octane? I understand the ecu adaptation issue and will "drive the living ****" out of the car until the next event. That ecu WILL know who its daddy is.
Incidentally, my first run (in the rain) was at 119mph. The car can get up there...I know it can.
Old May 4, 2006 | 11:38 PM
DerekFSU's Avatar
Tires?
Old May 4, 2006 | 11:44 PM
BFG DR on the 12.1 @ 117mph run. Contis on the 12.3 @ 119mph run.
Old May 5, 2006 | 12:16 AM
FlyByNight's Avatar
05 E55
I think Grumpy was trying to say that if you do what Rock suggested, for two weeks, you probably don't want to blow all that money on 100 octane fuel that whole time... so mix it and get the cost down all the while getting your car used to a higher octane diet.
I'm sure you could drive the **** out of it with 100 octane the whole time if you don't mind the $$$...
ROCK: Your trap speed went up after all of this, but what about your ETs?
Loren
Old May 5, 2006 | 12:17 AM
Kens-E55's Avatar
2004 E55
Do you have the upgraded cooling pump? If not, the extra boost could cause the heat exchanger to be taxed by the end of the run,..Hence you may see a tail off of Hp by the last part of the 1/4mi. run w/o realizing it.
Old May 5, 2006 | 03:33 AM
Grumpy666's Avatar
Read the thread at the following link. I addressed your question there.
https://mbworld.org/forums/w211-amg/146307-104-octane-dilemma.html
Old May 5, 2006 | 07:38 AM
SleeperX's Avatar
E55
I think I might be having this exact same problem. In warmer temperatures I have seen my MPH drop from 120 to 116-117. So I had the Kleemann I/C pump installed. Heading back to the track in a few weeks and will keep you guys posted. My best time before was 12.1 @120. Think I can break into 11s with higher MPH with this I/C pump upgrade. Will post my new slips after I run in a few weeks. Mods are Renntech ECU, Pulley, Headers, Airbox, and Kleemann I/C pump upgrade.
Old May 5, 2006 | 07:54 AM
DerekFSU's Avatar
You should be in the 11's with K2 and DR's. 117mph is not bad. 1.8 60' is not bad at all and should also facilitate 11's. Go to the track again for more runs. Make sure the car has been cooled (iced) before you run it. LSD?
Old May 5, 2006 | 08:26 AM
Rock's Avatar
Administrator
Drives Slowly
Loren
ETs have dropped into the high 11s but the truth of the matter is, I'm just not that good of a driver.
Old May 5, 2006 | 12:42 PM
LSD, yes. Cooling pump, no. The car was sitting for almost an hour before I even pulled up to the line, so I don't think that heat could have been the issue. I'm going to go down again today and try it with less gas, will report the results...hopefully in the positive (wishing there was a crossing finger smiley that I could insert here).
Old May 6, 2006 | 04:22 AM
dragonAMG's Avatar
I guess 117 is not that bad at all. I just ran my K2 tonight (80 degrees and 15 mph headwind) and ran 11.902 and 12.023 @ 116 and 117, respectively. Both runs 1.8x 60's.
Just driving it around compared to my C55K S7, the difference in power is night and day. I can't believe I ran such a bad time. It feels like it pulls so much harder than my C55K S7 (which ran a best e.t. of 11.9 @117 on 100 oct.).
Granted I didn't heat up the tires nor was I running 100 oct. The car definitely feels like it should trap 120+.... very strange. Heat and elevation maybe?
I had my car dynoed the other day and it's putting down 481 rwhp and 552 rwtq. Go figure... thought my et and traps would be better.
Old May 6, 2006 | 09:16 AM
rbc55's Avatar
2005 e55
what tires were you running last night,the 20"s or the factory wheels?
Old May 6, 2006 | 01:10 PM
dragonAMG's Avatar
Factory wheels w/ Bridgestone Potenza's.
Old May 7, 2006 | 09:30 AM
cte430's Avatar
'07 Porsche 997TT
Josh,
Last time I had the car at the strip best run was 12.02 at about 121 mph. It was friggin COLD and windy. It's definitely a 120 + car.
How's it running otherwise?
