19" tire pressure?
340. this was my high school car. have had it for only 30 years!
Your GTS looks sharp. Same color as mine. Except I have the black top. Mines a 383 auto. It was my first car so I've owned mine since High School as well but that was only 14 years back. My best friend also owns a 383 4speed Formula S that he bought shortly after I got my GTS.
Like to see a photo when you get a chance.
Have you noticed Mopars are finally get the attention they deserve.
Been to many a car show and mostly you see Ford & Chev. and just a few token Mopars 1 or 2 including mine. Just the past few years I have been seeing more. Nice to here there are others out there.
tbone and OzE55, I'm wondering why do you run higher pressure in the rear? I always thought running higher in the front and lower in the rear was better for handling.
I was advised to use the higher pressures as I had bent two front rims.
I suppose the rears are less vulnerable because they dont have a big lump of iron sitting over them - but taking no chances now.
Having said that, the need to counter understeer forces us to raise the front tire pressure, relatively speaking, which might end up with the same pressure all around ie.you need to strike a balance between the load and steering response.
If you then complicate matters further by bringing a third dimmension into this equation ie. pot holes and bent rims, you can throw the other two out of the window!
I'm an XXL sort of guy and rarely have passengers.................that front end takes a pounding.
Not quite. You Increase the pressure to protect the rim.
The higher front pressure will make the ride deteriorate, but improve the handling.
