Last edit by: IB Advertising
See related guides and technical advice from our community experts:
- Mercedes-Benz E-Class AMG: How to Reset Your ECU
Step by step instructions for do-it-yourself repairs
Holy Crap you guys.....sneaky ECU reset WORKS!!!
#578
04 c240 avantgarde,2011 glk 300
was it really so odd? can't a guy just confirm its suppose to be a community where folks can ask for clarification and all that. the thread was running mostly with manual tranny hence the question raised.
#579
I'm done here. I'll leave the stage for others to entertain you!
#582
Best answer: try and see. It either works or it won't
Don't wait and sit inside your car though. As soon as your CI turns off you're done. Can bus is asleep and next time you wake it up the result will be there or not depending on if it is implemented in your car.
#583
If the car is tuned would u still need to do this ?
Does it change with daily driving habit of trans with a tune is where im getting at
#586
after doing this at the track what do u guys set the car at for your runs. Meaning sport,man,comf.
And which suspension setting for shocks like s1 or s2
#589
My E55 Got alot worse after doing this not sure why I was so stupid lol. Anyway been drivining like crazy and it seems to me back to normal thank God.
Took it to the AMG center behol another E55 AMG W211-AMG they guy before me insist on having The AMG SHOP resetting the ECU despite warning the ECU is coded from factory so of course u can't reset it with this reset guide here u need the mercedes benz star diagnostic obviously or another ECU coding tool.
Anyway despite warnings he wanted the shop to proceed with the resetting via Star I was great I can look while he being the guiny pig and so it went on
Jesus Christ what a mess after the reset firing up the car was nearly impossible it finally started but total undriveable miss firing and acting all weird I never forget the sound and the look at the owners face while The AMG Tech guy lifting he shoulder I TOLD U SO.
Now ECU reprogrammed he's car drives again.
#590
The tech was 100% correct. Star Diagnosis explicitly warns before you start the ETC reset/adaptation to only do it on the gear(s) that dont Shift properly and only if that is the last resort. It even states that it can get way worse.
#591
Comfort/sport mode and air supension
hi I have a 2013 e550
i have a couple of buttons on the center console to the left of the main control *** the e to s button works fine to the right the sport / conf button doesnt seem to have power going to it and the. Air lift suspension button the same no power going to it, try pressing it to switch modes, no red lights appear, doesn't even light up white, like the other buttons
everything was working fine when I picked up the car from the dealer , now nothing
previous vehicle was a 2012 e350 so really familiar with them
cause they just detailed the car was wondering if they might if shorted a fuse or relay,
any ideas
thanks
any ideas
thanks
#592
any ideas
thanks
any ideas
thanks
#593
any ideas
thanks
any ideas
thanks
To the dealer. Let them do a quick test. Lower control module has no fuse.
#594
Just thought I'd bring this back up for you guys with transmission issues. It resets everything your car has learned about the way it's been driven. If your car doesn't shift more aggressively then you have bigger problems.
mondo (05-10-2019)
#597
Alfa Romeo Giulia Veloce
tried this today. seemed to work fine then for some reason after a WOT run from about 40mph up to 90mph, the car seemed to go into limp mode? even putting the throttle fully to the floor, the car would not accelerate. i tried shifting manually but made no difference so in the end i pulled over, switched the car off, then back on and away it went. not able to check for codes as my reader will no longer communicate with my phone after running a firmware upgrade...
#598
Sounds like you have a problem lurking, and a little extra torque put you over the edge. Whatever it is will likely get worse over time. Might be best to get the scanner fixed first.
