EVOSPORT Rotors $1500.00!! Who is in?
This outgassing is not a problem with current generation pads, which negates the need for holes/slots. There is some speculation that slots help prevent pad glazing, but I think the jury is still out.
Holes are bad, especially if they are drilled and not cast into the rotor. Drilling holes in rotors causes the formation of stress risers, which are the precursor to cracks, which eat pads and reduce rotor longevity. Holes also reduce the rotors ability to absorb and dissipate heat (less mass). And yes, they do reduce unsprung weight a very small amount, but IMO, it's not worth the tradeoffs. The only valid reason for holes is to reduce the weight of big-*** rotors - other than that, it's just aesthetics.
Take a look at what the NASCAR boys are doing - you won't find any holes in their rotors.
iturk182@aol.com
On a serious note, thanks for your input. I agree that we "overpay" but that started back when we purchased these cars.
Are you suggesting that these rotors offer no significant benefit over the stock units?
http://www.autoaccessorystore.com/ho...izard=&s=&mid=
If you install the Evo rotors and track the car, you will probably discover a new shade of gold for your calipers. The reduced mass of those rotors will translate into reduced cooling capability. It could get ugly.
This is the list of members who have made and oral commitment to participate in the EVOsport rotor buy:
Those In:
1. Rock
2. Kev04C320
3. Kens-E55
4. Rotex
5. Loren
6. GTA23109a
7. eride
8. Sam E55
9. laj e55
10.e55 baller
11. MGO427
If I left your name out please let me know.
PLEASE- After you place your order next week, post that you have done so (in this thread). We need to keep track of the total number of orders.
I assume all that have posted are very serious and will place an order. So, since we have over twice the people needed to hit the 1,500.00 pricing, I am going to e-mail Simon to see if we can get an even greater savings.
Those Evo rotors will probably work OK for a normally-driven street car, but don't expect improved braking. The braking performance of a car like the E55 is limited by the tires, not the brakes. Have you ever done an emergency stop and felt the brake pedal pulsating? That's the ABS intervening because the tires are trying to lock up. Bigger brakes will not stop you in a shorter distance, but a bigger tire contact patch and/or more tire-to-pavement friction will.
And I doubt if there will be an acceleration improvement, either. The benefit of reduced unsprung weight occurs as the vehicle begins accelerating - getting the rotating mass into motion. With the E55, hard acceleration results in tire spin and ESP intervention (it applies the brakes). Having less unsprung weight will result in more tire spin and ESP activity. Best case, you may get a slightly higher trap speed due to the 34 fewer pounds.
However, there may be some braking improvement with the lower unsprung weight if you track the car, but after the first couple of laps, it will start to circle the bowl. The lighter rotors are smaller heat sinks and the advantage of lower unsprung weight will fade as fast as the brakes. The OEM rotors are larger for a reason, but even they aren't adequate for tracking - unless you like gold calipers.
Grumpy you got me sold ... I guess Im just going to keep my Stock AMG brakes ... I think you make sense .... for looks I would rather have the Brembos with their Calipers too ...
where do I get the calipers ....?
does that site sell them too?
For the forum:
I'm not trying to dissuade anyone from buying the Evo rotors. If you like the way they look and you're happy with the price - go for it. Just be aware of the issues I stated earlier. My opinion is you're buying aethetics, not improved performance. There are other upgrades on which I would rather spend the money. Do what you think is right for you.
Also, when I look at the pic of the rotors above, all I see are what look to be off-the-shelf rotors with with a machined MB adapter plate rivited to them. Maybe $150 in parts and another $50 in machining - for all four. Of course, this is just my opinion and I could be wrong.
Basically 34 unsprung pounds translates to a 57.8 sprung loss which translates on average to an effective gain of about 5.78 Additional HP -- you may see an ET improvement of 0.05 and 0.5 mph.
I have my car on a diet so adding the brakes will get me down to 3960 lbs with a 1/4 tank of gas. I have already taken out about 60-75 lbs. In total my 100lb effective diet should net me 1mph and 0.1 less ET.
I'll take that.
Even with additional cooling (crazy brake ducts, etc), I am pretty sure the calipers will still change color.
The E55 is simply very heavy and powerful to go around a road course. A road car definitely has many compromises.These EVO rotors look awesome. I doubt there is significant performance benefits. Yes, every bit helps and it all adds up. IMHO, the E55 is the wrong platform to try and squeeze the last bit of performance out of it though. I catch myself wanting to do it all the time. In the end, it's an emotional choice rather than a logical one. :p
As to the benefit of these rotors - I've got first hand experience on 2 other vehicles where I went with heavier rims and tires and kept the brake system stock. Vehicle #1-The result was I LOST 10 MPH in the 1/4 mile. Yes, I went from a 93mph trap speed down to 83mph. Extreme-Yes -- I added 90 lbs of rims and tires to my Dually - but true none-the-less ---I did lose 10mph!!
Vehicle #2 more realistic---Lexus GS400 where I went from stock 17" wheels/rubber to Plus1 going up to 18" wheels and tires ONLY!
The result was a 4mph loss in 1/4mi trap speed! (98 down to 94)
Too boot, that set-up only totalled an extra 36 lbs in weight!
- I'm willing to bet - lose 35 lbs in rotors, and most of us will see a gain in trap speed of at least 2mph!
Other benefits - The truck you can forget about panic stops
These lighter rotors will make the car feel much "lighter" to brake from normal speeds
I could go on with other advantages but I've rambled on enough.
The rotors will be a benefit that is noticed!!
That being said, they were a bit knicked up... huge gouges in the 2 front rotors (not too happy about this). Not just scratches..... gouges in the metal. Extremely poor packing job likely caused this. Simon/Evosport, I'll be calling you on Monday to discuss this.... not a happy camper. Not only did I pay more than all you guys (I wasn't even going to try to get the same price), but my rotors were effectively "damaged"... not cool.
Here are some pics...
Just like the picture below.... the bevel where mine is all hacked up is definitely visible.
Loren
Also, after a search of other floating rotors for European and Japanese cars I found that the cost is often times $300-$400/rotor, so this is right in line with what we will be paying.
Finally, I did hear from Simon and the price will stay at $1500.00 even with 10+ orders. Simon stated he could handle the orders but 2-4 weeks maybe needed for shipping.
