Bought the Aftermarket Rear Side Window Blinds -- Not Bad
So, here are my thoughts:
1. There is nothing as good as the blinds which come as the factory installed option where the base of the blind is rolled into and out of the door panel...for a stupid $200, can't MB makes these things standard on a $80,000+ car, or throw them into the premium package, like they do with the power rear blinds? Unfortunately, it's thousands of dollars to add them afterwards.
2. Recognizing this, MB makes a decent aftermarket solution available for $168 (both sides). The only difference/negative, is that if you don't want them to be "up" all the time, you need to remove them (easy pop out) and keep them in your trunk/garage. This is not a bad option, as they only really make serious sense, for me at least, when I am driving on a 2-3 hour trip with the family, like to VT or the Cape for a weekend...at which point, I am happy to "install" them (takes 30-60 seconds).
3. They pop in and out of little receptors that you insert into each side of the top of the door panels. Once installed, they look exactly like the other black shades. They secure themselves at the top by inserting two small latches under the interior rubber where the window meets the top of the door frame.
4. Once installed/raised, you can lower and raise the window without any impediment.
Anyway, I probably won't use them that much, but then again, they are pretty inexpensive.
My conclusion is that they are an effective and intelligent alternative if you weren't able, like me, to get a car with the rear side blinds pre-installed.
I installed them myself and it's about 1-2 mins per side with no tools involved / If your dealer will do it for you, for free like soxfan...great, but do not pay them to install...it's simply two plastic clips (slide in) in the lower portion of each of rear window frames and that's it...probably harder to put gas in your car
