K2 vs K4 -- Is it a BIG difference - any experience appreciated?
Old Jun 12, 2006 | 09:47 PM
Kens-E55's Avatar
2004 E55
Just had my K2 done and lov'in it!! My ? is: Will going to a K4 be a big noticeable difference, or is it purely upper end Hp and will only be noticed running thru the gears doing a 1/4 mile at the track??
ie: upper- end Hp (high revs) may be useless in the city as you have to be doing 80+ mph just to wind out 2nd gear!
Is the $8500 better used in other areas for performance enhancements
Any help appreciated!
Old Jun 12, 2006 | 10:19 PM
m52e55's Avatar
'11/E63-Former car: '05 RT4 E55, Sprintbooster, Phenolic Spacers, RT IC /Secondary HE & BMC Filters
congrats , Ken. envious. still trying to convince boss here about k1 (maybe k2). how did you badge car (if at all? (Kleeman (<) K55 S2) heard that in CA, that for street/emission, that Kleeman is only approved/licensed mod? checking on this...
Old Jun 12, 2006 | 10:42 PM
Rock's Avatar
Administrator
Drives Slowly
If K2 takes you to 570-580hp at the crank then I would expect K4 to take you to 610- 630hp. I would not expect the butt dyno to notice a big difference. The highest trap speed I have seen on an E55 (without N2O2) is 123MPH. K2 cars can accomplish this. I have not seen a K4 car run a higher trap speed.
Someone prove me wrong.
Old Jun 13, 2006 | 01:25 AM
jamusa's Avatar
I have k4 installed in my e55 and make 500rwhp,and 640rwtq .The car makes so much torque that even with esp on it cannot control the spinning.Cory at Kleemans states that the computer is having problem compensating for that amount of torque,not to mention the fact that after looking on my dyno sheet he thinks its one of the strongest yet.........but to answer your question,yes the k4 makes a difference.Especially on top.....the car charges like a bull with k4.
Old Jun 13, 2006 | 07:38 PM
DerekFSU's Avatar
To my knowledge, NOT ONE SINGLE PERSON with K3 or K4 has stepped up to the plate and run their frickin' car at a track. Dyno's are fun but outside of tuning and showing before/after, they are useless.
Put it on the track and you'll find out if $7k camshafts are worth it or not. Will someone PLEASE step up?
Old Jun 15, 2006 | 10:10 AM
E55 RUSS's Avatar
E55K
Camshafts should make 55 faster on TOP....
Old Jun 15, 2006 | 11:37 AM
dragonAMG's Avatar
12' C63 P31, 06' Supercharged Range, 08' BMW 550i
Take it to the track. We are all dying to see 1/4 numbers.
