*** 160 Thermostat ***
Old 08-21-2006, 08:16 AM
stevebez's Avatar
No longer stock '06 E55, A3 3.2 Quattro, LRD4 HSE, R107 280SL
I am not sure what diff the thermo mod does once the engie is at opps temp - thermostat is from my understanding a device that gets the engine to normal opp temp as quickly as possible,and the assumption is normal opps temp has to be somewhat above the thermo's opening point. I cannot imagine teh thermostat contantly opening and closing as the motor cools and heats up ... or is this typically the case?
Surely if the engine normal opp temp is ~200deg F (with a stock 190deg point) , then a 160deg thermostat would not do much once motor has warmed up...?
What am I missing ?
Old 08-21-2006, 06:31 PM
dsc
dsc's Avatar
2004 E55
PTE, I'll give the 160 a try if you're willing. What do I do? Check your PM. Thanks.
Old 08-21-2006, 06:46 PM
vader's Avatar
04 E55
The faster the car gets to operating temp the cleaner it is..a 195 will cycle to KEEP the temp at 195.... 165 will open sooner and allow the car to come down to whatever temp the engine wants to be at determined by load..OAT etc. but no lower than 165...
Old 08-21-2006, 07:01 PM
Kens-E55's Avatar
2004 E55
Let's not overlook one important feature here???
The lower the coolant temp....the cooler the intake charge will be!!
If this works...we can start "tweaking" a little more timing or boost
Old 08-23-2006, 05:25 AM
E55 RUSS's Avatar
E55K
If it works...
How much is the whole set up including the parts ???
Old 08-27-2006, 10:32 AM
PTE
PTE's Avatar
05 ML-500 , 03 CLK5.5 AMG has left the Garage
160* thermostat mod delivery update
Good Morning Folks:
I just finished up some assys yesterday and have contacted most of the inquirys.
MRWeers {Griffin337}you are done & e-mailed
430 Waiting for assy from Germany????
E55 baller , done & e-mailed will send out tomorrow
dsc (Chicagoland) you are done and E-mailed
DKM (Las Vegas) your next
Did I miss anyone? Please contact me AT {tynerfla@bellsouth.net}
Old 08-27-2006, 01:27 PM
  #32
jamusa's Avatar
PTE
I received mine yesterday(Friday)and i should have it installed by Monday.
Thanks for everything.....will keep you posted on how it works.
Old 08-27-2006, 03:16 PM
  #33
430
430's Avatar
SLK32
PTE -- Sent you an email.
Thanks for the update. I am looking forward to the part.
Old 09-01-2006, 02:27 PM
  #34
jamusa's Avatar
PTE.....I have installed the 160 degree thermostat in my e55,and yes fellows the car runs significantly cooler.My car used to run 88-90c,now it runs 82-84c.
I do not feel any additional hp,but its a peace of mine knowing that the car is running cooler.
Thanks again PTE........For those of you who has not yet have the install,you need to give it a try.
Old 09-01-2006, 02:54 PM
  #35
Kens-E55's Avatar
2004 E55
PTE - I sent you a PM concerning the 160 stat.
Please check your mailbox - Thanks a bunch in advance
Old 09-01-2006, 03:42 PM
  #36
PTE
PTE's Avatar
160* F thermostat
Got your message and answer sent. There was a small write up in Benzworld W-210 Thanks for your inQuiry
___PTE___
Old 09-08-2006, 06:55 PM
  #37
PTE
PTE's Avatar
160* thermostat
Hi Guys ;
Kens E55 & Dinko You guys are ready for local pick up. Thanks ___PTE___
Old 09-13-2006, 10:58 AM
  #38
vrus's Avatar
2003 E55 AMG
The dealer installed my 160 Thermostat and I just had a chance to drive it a bit.. It definitely works!! My car is at 80C- 81C while cruising and goes up to 84C - 85C when hard on the throttle.
This is a great mod for our heat-soaked cars.
Old 09-13-2006, 11:07 AM
  #39
dinko's Avatar
CLS55
Patrick, like I mentioned in another thread, thank you very much for the 160 Thermo. I am a sucker for little mods on my car, and I notice this one whenever I drive the car.
You're the man!
Old 09-13-2006, 11:49 AM
  #40
Kens-E55's Avatar
2004 E55
You're the man!
Ditto that!!- Patrick many Thanks as you make this easy!!
Old 09-14-2006, 01:10 PM
  #41
SSM AMG's Avatar
2004 S55 AMG
PTE Will this fit a S55?
Old 09-14-2006, 05:01 PM
  #42
PTE
PTE's Avatar
160* for a S-55
I'm on Vacation so I'm out of the State if you could please get the Part number I'might be able to comfirm it. Other wise it will be after the 27th.
Thanks to All. ___PTE___
Old 09-14-2006, 08:05 PM
  #43
e55 baller's Avatar
W221 S65 AMG
I had it installed today...running 78C...a full 2-4 bars lower than average!!!
Old 09-14-2006, 09:52 PM
  #44
dinko's Avatar
CLS55
PTE, do you know anyone at MB of Palm Beach that could do the fan mod? Also, could anyone please explain in more detail what the fan mod does for the most part?
Quick Reply: *** 160 Thermostat ***
