20" Tire Size?
What do you guys run on your 20" wheels?
http://www.michelinman.com/specs/pil..._ps2/2958.html
Ideally you want the same diameter wheel/tires diameter as stock. You will change your effective gearing, suspension geometry, speedometer and odometer setting by getting out these parameters. Your revs per mile need to be the same (or very close) to the stock set up.
Front: 245/40ZR18 809 rev per mile
Rear: 265/35ZR18 814 rev per mile
BTW There are a lot of threads regarding this subject in the archives of this forum.
245/35 = 26.7 diam.
255/30 = 26 diam.
