Taking my E55 in for service...what are my chances?
![Question](https://mbworld.org/forums/images/icons/icon5.gif)
What are my chances if I tell them, DEMAND, that I have no ECU flash/recall under ANY circumstances. I was planning on
1) Telling them in person
2) Taping the OBD2 port w/a post in note
3) Putting instructions on the steering wheel not to FLASH the ECU
4) Putting instructions in the engine bay not to FLASH the ECU
5) Reminding with Voice Mail & Email
6) Requiring them to sign a document stating that they will not flash the ECU
I am parniod as you can tell. Losing significant HP is equivalent to losing all the mods $$$$ that I have spent on the car.
I am having the "C" service tomorrow as well as the Evo rotors and brake pads installed on all 4 corners.
2008 E63
All depends on the dealer. I had mine in last week for service. The dreaded air pump campaign came up and I told the service writer that under no circumstances would I allow a re-flash. The writer talked to the technician who told him without re-flash it was not worth doing. I told the writer to not do it. They agreed and the campaign will remain open no questions asked. Props to MB of St. Clair Shores. Now I just have to get them to do my planned Kleemann mods!
1 Post
2009 C63 Black on Black
![Thumbs up](https://mbworld.org/forums/images/icons/icon14.gif)
![poke](https://mbworld.org/forums/images/smilies/stickpoke.gif)
Yeah I think that is my only option too. I am drafting a letter now and will require my service manager to sign it.
Even if he signs it, what are the legal obligations? "Return my car back to the pre-flash" I am not a lawyer and do not know how to add terms in it other than to scare them with the letter.
Subject: 2003 E55 AMG Vin #
I am requesting by signatures below that [Dealer] will not under any circumstance flash the ECU of my Mercedes Benz E55 AMG.
Doing so will cause an irreversible change to the current ECU program.
As a result I am requiring that [Dealer] keep all campaigns (e.g., air pump campaign) that require or result in an ECU reflash open with notes not to perform the campaign at my request.
Thank you,
Me
Signature ________________________
Date ________________________
Assistant Service Manager
Thank you,
Me
1 Post
![Cool](https://mbworld.org/forums/images/icons/icon6.gif)
![action](https://mbworld.org/forums/images/smilies/action1.gif)
![slap](https://mbworld.org/forums/images/smilies/slap.gif)
I think you bring too much attention to your car and your mods if you don't let them reflash your ECU.
Do what I did... its super easy... let them reflash the ECU, drive it home, take your ECU out (2 minutes), fedex it to Cory at Kleeman where they will put the original K2 flash on it and fedex it back.
Worked perfectly! And now you're on record as having the flash done!
Loren
2003 Cobra
Can someone explain what changes the ECU flash does?
I know some are stating power loss, Someone in another post stated you lose the ability to turn off the O2 sensor code if you remove the cats. What else?
Is the power loss thing been proven?
2003 Cobra
Loren
Loren
Originally Posted by PARALYZER
Doesn't Cory have to have the original program first in order to be able to flash it back in the car after the update?
DO NOT let them flash your car, even if your tuner has a copy of your original software. for many, worrying about the attention this may bring to your mods is much easier than the alternative...i promise!
Nope... they literally just wipe it all with the K2 flash that previously worked... I learned that it is the standard K2 program all of us got before the ECU reflash crap by MB....
2003 Cobra
it's not that easy and yes cory will need to have an original file of your software (maybe not your original file but one that matches up with your vehicle).
We have the same K2 code. Even if they don't have the original K2 file they flashed you with (which they do, or where ever you had it done should have), they still just flash back the same darn K2 code every one of us has had for some time.
That's why the "new" K2 flash does not work on some people's cars... mine, for example. That code is the same and takes the new MB flash into consideration. Well, it works on some cars (Rocks), but not on others. Those of us that it doesn't work on have no supercharger and check engine lights. Why? Because MB has several new flashes for our cars, and it differs by VIN. Who knows why... but the bottom line is that the single new K2 flash... which is again, identical in each instance... will not work on those cars that get a different MB flash.
The point is the K2 flash from Kleeman is pretty much the same across the board unless you had some very special tweak done custom...
Loren
2003 Cobra
Loren
If my car is bone stock, and I want my original program back on the car after the reflash, Cory does NOT have this right? You would have to send it to him before the reflash from the dealer correct?
Loren,
I may have read this too fast but I see in one instance above that the reflash worked w/ the old K2 from Kleeman, then lower that it doesn't work?
The dealer is mod friendly and know my car is all jacked up....they should be cool with this. I just don't want it happening by accident by some technicial that didn't get the 411 from my service manager.
So bottom line, if they F it up...I will be able to get it working with the old K2 software?
2003 E55 & 2014 GL550
Just my 2 cents. I say you ask/watch the rep type in the computer not to reflash you, then just a REAL friendly post it on the ECU, you should be okay. Forms and notes all over is just askin for some punky tech to flash you out of spite. Good luck man
I agree just be as friendly as possible. I always use the same service advisor and technician whenever my car is at the dealer. It all depends on how helpful they want to be, like showing that the recall work was completed when it really wasn't.
Loren,
as for restoring the stock profile after the ecu flash... I would assume that Cory, Brandon and co have a zillion stock ecu files laying around... but it never hurts to merely ask them. I can't see why reverting back to stock would be any more difficult than any other flash... and I do know they keep all the stock profiles of every car they modify. So, they have my stock profile, my K2 profile, etc...
Loren
2015 S212
Loren is correct. If Kleeman chooses to do it is another story (not that they won't). but technically, they can.
I would NOT get it written on the record. I would have it agreed on the side. You never know when and if MBUSA's rep will review your record.
By the way, how much is the dealer charging for the Evo rotor install? Do you know if the AMG composite brakes will fit and are available? Would you mind asking your service rep, since it seems you have a very mod friendly place?
F248 F1
Why not take the car to an independent Mercedes shop?
They will listen to your request, and get the job done just as good if not better.
If you take it to the stealership, Hmm tell the service advisor not flash the ECU, and get some ‘danger’ ‘do not remove’ tape and wrap it around the ECU box? (put it on before you go to the stelaership) so you will know if they tinker with it or not ? haha
Are you afraid of them updating the new ECU with the software that we have a lot of members complaining that they can’t break the rear lose anymore – the so called ‘de tuned’ version, that no tuner can crack the code yet?
good luck in getting you car done !
Please explain why? If the original program can be loaded back on, whats it hurting? Please forgive me for asking so many questions. I want to know as much as possible before pulling the trigger on this purchase.
