Performance Modifications for E63
I'm assuming Renntech, Kleeman and the rest will come out with something. How can you up the HP and speed without causing a transmission problem?
"Though the new gearbox is far more efficient than the five-speed, and though it was not built to handle the massive torque of the supercharged engine, its limit of 542 lb-ft, say Mercedes engineers, gives it the required durability to handle the 6.2's far-from-paltry crank twist."
so another 50lbs of tq will be doable without hitting the limit.
s yet, unless they are using the same airbox as the 5.5 (not likely)
Should be soon though.
Renn and Klee are burning the midnight oil I am sure.
Secondly, if you're that close, your probably gonna tear up something anyway. There is not enough of a safety margin to allow much HP increase unless your methodology does not increase torque.
How do you increase HP/performance without increasing torque?
See Also: E60 M5.
See Also: E60 M5.
I'm sure someone is working on mods for the e63. This should include:
Headers (supersprint had a mock up 4 months ago for the 63)
Cams
ECU program
Lightweight pulley
TB
Air Filter & Box
It would be safe to say this motor should have the similar hp (+or- a few) results that a new z06 would produce with similar mods. Either way the 63 motor should be a screamer!!
Gentlemen, prepare to void those powertrain warranties.
