SL65 wheels on E55
Old Aug 25, 2006 | 03:54 PM
vader's Avatar
04 E55
SL65 wheels on E55
K I searched and can't seem to find a definite yes or no on this swap...will ET30 and ET31 offsets on our E work or am I just asking for problems ?
Old Aug 25, 2006 | 04:12 PM
stevebez's Avatar
No longer stock '06 E55, A3 3.2 Quattro, GLE 400d, R107 280SL, Golf Polo
Well 19" variety in 30 & 31 offset is what AMG and tirerack spec as the correct offset.
Rafal has 38 offset at rear using 285's giving around 4mm clearance from wheel arch. He says 285's on 31's will get chewed up under compression by the wheel arch. Spec rubber on this rim is 275's (maybe this is the max you can go) and then you will be hunky dory... or so it seems.
I am still bewildered why tirerack and AMG spec 30 & 31's for the e-class. I did not know you had a choice to be honest.
I have a set (19" amg style IV splits 30 & 31 offset with 285x30x19 B/stone re050a's) sitting in my friends garage and we will soon see how poorly they fit.
Please advise if you can find any more info.....
Old Aug 25, 2006 | 04:15 PM
2K6E55's Avatar
AMGs
I have the same question too but I dont know the answer. My neighbor has an CL65 and his wheels are just sitting in his garage, at one point he wants to sell them to me but I dont know if they will fit. Those wheels are HEAVY though!
Old Aug 25, 2006 | 04:38 PM
dragonAMG's Avatar
12' C63 P31, 06' Supercharged Range, 08' BMW 550i
Originally Posted by 2K6E55
I have the same question too but I dont know the answer. My neighbor has an CL65 and his wheels are just sitting in his garage, at one point he wants to sell it to me but I dont know if they will fit. Those wheels are HEAVY though!
Easy way to find out -- Put them on real quick since they are sitting in your neighbors garage.
Old Aug 25, 2006 | 04:45 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
YES The R230 SL 65 Two Piece Wheels WILL Fit a W211 as I have them on my wifes 2006 W211 ....... Also have the Brakes that go with the AMG Rims..
WOW What a difference!
Old Aug 25, 2006 | 04:49 PM
stevebez's Avatar
Mark are those 19"'sx9.5xet31's right ? What size tyres do you have fitted ? Is your suspension lowered ? Any rubbing at all ?
Old Aug 25, 2006 | 05:46 PM
2K6E55's Avatar
AMGs
Hahahaha... Right but none of us want to do the dirty work so we just stared at them hoping for some magic.
Old Aug 25, 2006 | 07:02 PM
Efivefive's Avatar
E55 AMG
I think I might be able to help here!
I currently have the SL65 wheels on my car.....I am running 255's & 285's bridgestone re050's.
I found the wheels did not rub until I lowered my car. However, there is a fix for this, I found that moving the et31 to the front and running et30 at the back eliminated the rubbing....you can do this by simply taking the wheel apart(undo all the torque bolts) and reversing the offsets. I also found the handling on turn in improved....perhaps because of the wider track the et31's gave me at the front??
I hope that makes sense???
Old Aug 25, 2006 | 07:24 PM
2K6E55's Avatar
AMGs
Very nice. What kind of lowering module are you using?
Old Aug 25, 2006 | 07:35 PM
Efivefive's Avatar
E55 AMG
Thank you.
I have the Kleeman lowering module, the car is in comfort mode while running in the picture. I will take some more pics in sport 2 and with engine off (dumped) and post over the weekend.
i read in your post that you have some CL65 wheels available to you??....I don't think they will work because the CL and S have a totally different offset to the Sl and E?
Old Aug 25, 2006 | 08:19 PM
jsloan01's Avatar
2025 CLE 53 AMG
EFFING beautiful
Old Aug 25, 2006 | 08:49 PM
vader's Avatar
04 E55
Great post...and thats the problem for me..I don't want to dick around and MAKE them work right with my car being lowered...they really look good on a the E though...
Old Aug 26, 2006 | 12:32 AM
kaze81's Avatar
Mercedes
2K6E55: check your PM box please..thanks
Old Aug 26, 2006 | 02:41 AM
Rafal's Avatar
2017 S63 Coupe Iridium Silver
Is this some kind of a gag? Somebody might actually follow this advice
By moving ET31 to the front you are making the front track narrower, not wider than ET30.
ET30 on the rear will rub more than ET31 ie. 1mm more out.
By undoing all the torx titanium bolts and swapping the centres you have ruined those wheels. Just put them on a balance machine and watch the "Mexican wave"
Old Aug 26, 2006 | 12:57 PM
Efivefive's Avatar
E55 AMG
gag???..........Never!!!
Firstly your explanation of my wheel offsets is all wrong!....it is true for other wheels but, the original SL65 wheels work on a reverse offset principle! (et31 sticks out more than a et30)So my comment about the track being wider is correct!! (I can take some snaps if you wish)
Secondly, I don't see how I have ruined the wheels by undoing the bolts??.....surely split rims are just that........split rims!.....which gives them the ability to be split???? e.g. some of the guys on this board have HRE split rims which they have had to send back to HRE to be repainted.....do you honestly think they could do this without splitting the rim???......or do all of these people have "ruined" rims???
I did not imply that people should sit at home and split these rims!!!
......I had a specialist wheel place who know what they are talking about do this job for me.......i.e. making sure all the bolts are inserted with a threadlocker and all tightened using a torque wrench to xxNm.
FYI I witnessed all the wheels being balanced and no there was no mexican wave!!!....and so there shouldn't.....these are original amg split rims (not replicas)......there is absolutely no harm in taking them apart provided the correct tools are used!
Old Aug 26, 2006 | 02:44 PM
vader's Avatar
04 E55
If the SL65 wheels have a reverse or negative offset I would think they would have much more lip...either that or they would have a really thick center hub. 31 positive would be close to rubbing my wheel well lip where a 39 does not. The higher that number goes..the more the tire gets sucked into the well...opposite for a negative offset. Higher number sticks the tire out of the wheel well. 65 wheels sure don't LOOK like they are negative offset wheels.
Old Aug 26, 2006 | 06:42 PM
Efivefive's Avatar
E55 AMG
Alright guys!!....this is the last thing I wanted!....messing with senior members on this forum!....honestly!!!
I agree with what you guys are saying about offsets 100%!....however it doesn't apply to these wheels!
I have a quick way to resolve this.......on one side I will put an et31 (285) and on the other side I will leave the et30 (285) and take a couple of pictures.....it is very clear that the et31 sticks out of the wheel arch more than the et30 hence why the et31 rubs and the et30 does not. Also, the sl65 wheels do have quite a thick center hub (probably why they are so heavy), amg varies the thickness of the center hub to change the offset on these wheels....for e.g. the center hub of the et31 wheel is thicker than that of the et30 (I have seen the et30 and et31 standing on their hubs side by side and the et31 stands higher). The lip size is determined by the J size.....i.e. 9J, 10J e.t.c.
Vadar you are right this method does involve alot of dicking around, but I just had to have these wheels, with the 255 and 285 tyre combo.
I will post the pics in the next couple of days.
Old Aug 27, 2006 | 01:09 AM
juicee63's Avatar
2011 twin turboed prius
I put them on my E55
I won't say it was trouble free but seems the tire shpo forgot to put the tpms back on, 1 year later I was sick of the tpms light so I took it in the sevice guy calls and says "you do not have tpms on this vehicle" No worries as long as you do not lower the vehicle
Old Aug 28, 2006 | 08:47 AM
stevebez's Avatar
All will be revealed / confirmed in a few days when I put these wheels on my car .... (my car is not lowered - and I am not going to lower it anyway).
255/30/19 on 19et30's and 285/30/19 on 19et31's. B'stone Re050A's.
Tyre shop says 245 & 275 are correct sizes... but will see how we go - maybe I can get away with it.
Worst case I put on 275's at back.
Old Aug 28, 2006 | 09:53 AM
Yes Factory SL 65 Rims/Tires with the Stock Size Tires 245/275/19 Car is NOT lowered..NO Rub even with Five adults .....Dont think I Will Lower the car as its my wifes car...
