*** CA Speedway Results ***
Quick points / summary:
1) I'm no expert, but the consensus was that the track sucked... both the early misty weather... and just the track. Of the two lanes, we were on the left... and it had tons of visible rubber / buildup compared to the right lane which was being "saved" for the NHRA. Josh and I took early morning stabs, and we're still sliding back and forth at 70, but managed repeat 115 times at dismal 13.4s! They were not comfortable runs... slip sliding away. I could go down Ventura Blvd and feel more comfortable, no joke. As the day progressed, it only got marginally better. Yes, the moisture was a factor... our 60 foot times were horrible all day long, always 2 or higher. But I think the actual track was an even worse factor. Not an excuse... just keep it in mind when you look at all the times I'll post later... EVERYONE underachieved across the board, and there were some squirrelly rides out there. Like JRocket said in the other post, the 1st half of the track just sucked... like the rubber on a playground... the 2nd half was nice. So, we were basically skating on some dragster's aftermath from the day earlier.
2) E55 v E63. While the 63 was best at 13.279 at 109.27, most of the E55 runs were close as well... only occasionally did either of the 55s dip down to 13.1... but almost always at the same speed...107-110. The best stock E55 run with no drag radials: 13.158 at 108.32. So, comparative based on the track... there was an edge to the E55s in times, but nothing to do cheers about as the 63 was right there MPH wise. Not one stock E55 or E63 broke 13... and JRocket is no newbie.
3) Drag radials helped the K2 cars... we got into the mid twelves quickly, but despite monster tire warming, the suckers still would break loose with ease. ESP OFF with drag radials hot and sticky was what I was led to believe would be the trick. Nope, you had to feather them out to 30 or 40 as well, or you'd spin. Both Dragon and I had our best runs after heating up in dyno mode, turning dyno mode off, then running with ESP ON. Trust me, we tried every type of combination imaginable. There is also a difference between K2 and K2 post MB ECU flash (sent to Kleemann for reprogramming with the new K2 program) cars. Josh would continually trap at 118-119, while I would start at 115-116 and fade down to 111-113. My best was 12.4, Dragon / Josh just missed 11s at 12.01 on one of his very last runs of the day (and the best of all cars). He drove mine as a test and replicated my 12.4. Imagine being told that of this group of 10, 12.01 would be the best. The track was very frustrating. Your local freeway onramp is prepped better.
4) 911 and CLS checked out early. The M5 has a bad day initially, then approached stock E55 and E63 runs with superior trap speeds, but slower times. The CLS was close to the E55 and E63 as well... times a tick slower, but trap speed right there. The M6 was the most impressive stock car... a best at 12.61 at 118. Incredible top end.
Thanks to everyone who helped today... despite the frustrating track and near wall collisions, it was a great experience and one hell of a lineup. Hopefully we'll be able to do it again at another track soon... one that doesn't look and feel like a non-stick frying pan!
Results to follow shortly...
Loren
Here they are, sorting by TIME. These are the top 3 1/4 times for each car. They do not have the fastest MPH runs (mine for example would be 116 for all 3) because those times were worse than those listed here. As you can see, the track affected every one. If anyone finds a typo or I missed a ticket, PM me with the ticket number and I'll make the change... but I think this is pretty accurate.
By the end of the day I was consistently putting down 12.0x @ 119.
Just to give you an idea of how ****ty the track was ... my best 60' was 1.997 and had an average 60' of 2.2. My 60 ft. ranged from 2.2 - 2.5. TERRIBLE!!!!! If the 60' was where it should have been 1.8 my 12.0 run would have easily been an 11.6-11.7. As you know... it's all about traction in these cars.
The 60 ft.'s of 2.2 tell the whole story on why our 1/4 times were so high.
By the way my buddies m6 pulled a 12.9 @114.. very impressive on this track.
Had a great time guys... enjoyed meeting everyone!
My take on the track.First off I checked the elevation at the starting line and then again at the finish lights,5ft raise in elevation.Somebody had said the NHRA allows a 9 ft variance at all sanctioned tracks,true or not I don't know.I did confirm my readings with another individual at the track and it just so happens he works there also...so take the info for what its worth.A few mph trap speed if you ask me.
The track is a fairly new track,it has also been sitting without any action for a couple months now.Meaning the wind blows frequently in that are and daily too.So what we had was a track with decent rubber layed down but allot of sand and dirt embedded into the vht and rubber.NOT good way to start and day.The there was the high humidity and slight drizzle this morning,another bad thing for racing,add all of that together and you get what we had today in the results.I see the trap speeds being down due to bad weather and up hill track,more weather than up hill though.One thing that was noticeable is that all of the cars were running slower across the table,meaning not one but all of them the times were off.I think .4-.6 of a second could be taken off the ET's.It wasnt about who the best driver was today or who had the fastest car(kinda),with more practice and a better prepped track any of these cars could have gone a little quicker.After I left the track I called a few of my friends who have rented the track before(7-8 second cars)and they both gave me what I already knew,the track doesnt get prepped well enough for private track rental days.Both of these guys have gone in the 7's on normal race days there,top of their classes.I wouldnt say it was all of the track personells fualt though,they did spray the track and such,but at big events the track gets allot more back too back usage thus keeping the track surface warmer and stickier.Bad part is on a day like that you would have only got maybe 4-5 runs for the entire day!!!!
I had fun all day long!
Well, here are some of the action shots I have. Sorry Josh, you had quit running when I was doing these so I don't have any good ones of your car in action other than on video.
I may add more to THE ALBUM if I find more pics on my other camera but I'm in need of sleep so that's where I'm headed!
Info@RoseConsulting.us
Unlimited mailbox size, so send as many / much as you like.
Thanks for taking them... and great job with the car... impressive given the numbers of all these pumped up engines and the track conditions!
Loren
Loren, what are you going to do about your K2 issue? I guess I'm in the same boat as you.
I assume that Josh never had the MB re-flash completed?
...........So, M5, E63, and post-mb flash stock E55's are similar. The E63 is definitely not faster than the E55 and all those published numbers for the e63 that put it in the cruise missile category are apparently false. The post mb-flash E55's don't have a huge margin to brag with.
...........post mb-flash K2 is slower than reprogrammed post-mb flash K2. For those that still think that nothing happened to their engine ECU during the recall work, you may wish to think again.
..........The M6 is the fastest stock car by a wide margin.
Ted
Ted
Well said.
I regret that we were not able to test the 0 - 60 times yesterday, because that was the one factory quoted number that put the E63 ahead of the E55.
His best time was 12.997 @ 114--- Great pics Ling and thanks for sharing. The cars all look amazing.... I guess I'll have to use Loren's car pics as my desktop background then
I can't believe you didn't tell my *** to lineup and run for an action shot pic.
Anyways... the M6 and I ran today on the steets when we got back to his house. Just to give you an idea of the difference in real world power between yesterday's track numbers of 12.9 @ 114 (M6) and my 12.0 @ 119 .... I spanked him by 12 cars lengths.
Ted
Yeah I know, I should have told you to line up but trying to get footage/pics AND participate gets a little hectic. Next time. Also, do you guys have the same set-up? I thought Loren's was different in order to meet California's auto emission requirements.
Way to represent Las Vegas. I'm in Utah this weekend but when I get back, we need to get out and run. Your car looks to be quite strong. I'll give you a call sometime next week. I should be able to get at least 2 cameras so we can get a decent video.
Loren
