Dynamic Seat Control Gremlins
Old Oct 2, 2006 | 05:43 PM
Rudyrono's Avatar
2006 E55 AMG
While driving this weekend I lost air in both the driver and passenger seats. I looked down at the "Dynamic" controls and the red light was off on both seats. I pushed the button but nada. I pulled over, turned off the car and let it sit for a few minutes. I restarted (keyless) and still no go on the seats. I then restarted using the key and the seats came back to life. This happened twice this weekend. Now, it seems like my side bolsters are not coming on as strong in the turns. I went through the command screen and they're still set on "strong." Any ideas?
Old Oct 2, 2006 | 05:45 PM
Bipasha493's Avatar
CLS 55 AMG
same with me here, when making turns the bolsters are not pumping as much air as they use to when i got the car...still trying to figure it out
Old Oct 2, 2006 | 05:58 PM
Rudyrono's Avatar
2006 E55 AMG
I don't think it's because I'm getting used to it because I noted a distinct difference right after I had the problems this weekend.
Old Oct 3, 2006 | 07:32 PM
x-tian-230k's Avatar
CLK500/Range Rover HSE/E55 AMG/Bmw 328Xi coupe/BMW 4.8x/Bmw 335i/GS350/Audi S5/E350
You can set the setting for the dynamic seats in your commmand unit or instrument cluster? PLease let me know as I did not know this.
Old Oct 3, 2006 | 09:21 PM
Rudyrono's Avatar
2006 E55 AMG
Yes, you can use the steering wheel commands. Start with the menu buttons "far left" until you get to the "Settings" reading on the instrument cluster. Use the up/down arrows next to the menu buttons until you get to the "dynamic seat" controls. Then you use the +/- buttons to change from weak to strong. Pretty easy.
Old Oct 3, 2006 | 09:23 PM
Rudyrono's Avatar
2006 E55 AMG
Benz-O-Rama's Avatar
Had the same EXACT problem. Mine was fixed. Here is what they did:
211-800-20-78 Vacuum Valve
211-800-19-78 Vacuum Valve
36018 Perform test dynamic seat for leaks left front seat for code (9256 Leak A IR at cushion of left seat-lumbar bottom
Perform electrical test 12 volts power is ok
Perform leak test - Right front seat for code (9251 leak at right cushion for lateral support)
916685 Remove and replace left seat control module.
916690 Remove and replace right seat control module.
So, I don't speak Mercedes-Tech-a-neese but it looks like they replaced 2 vacuum valves and both seat control modules. This was done 4/24/06 and I haven't had a problem since.
Good luck
Old Oct 3, 2006 | 09:24 PM
Rudyrono's Avatar
2006 E55 AMG
Awesome! Thanks.
