Drag Radial Question
Old Oct 3, 2006 | 04:39 PM
dragonAMG's Avatar
12' C63 P31, 06' Supercharged Range, 08' BMW 550i
I did a search but couldn't find anything conclusive...
What BFG Drag Radial tire size would be best to run on the OEM E55 18" wheel (drag strip only)?:
265/40 R18
-- 26 lbs.
-- Diameter 26.2"
-- Width 9.5"
275/35 R18
-- 27 lbs.
-- Diameter 25.6"
-- Width 9.5"
295/35 R18
-- 29 lbs.
-- Diameter 26.2"
-- Width 10"
Old Oct 3, 2006 | 04:55 PM
AMGcrazy's Avatar
2008 E63
Looking into the same thing. I'm looking at Nitto 285/35/(Z i think)18
Old Oct 3, 2006 | 05:03 PM
rflow306's Avatar
2005 E 55
265/40 R18
-- 26 lbs.
-- Diameter 26.2"
-- Width 9.5"
275/35 R18
-- 27 lbs.
-- Diameter 25.6"
-- Width 9.5"
295/35 R18
-- 29 lbs.
-- Diameter 26.2"
-- Width 10"
I would go with the 265/40 R 18. The taller sidewall, in my experience, will work the best at the track.
Old Oct 3, 2006 | 05:56 PM
eLTURCOamg's Avatar
Merce-rati
PM LOREN, if i remeber correctly her bought a set for them to use at there private track day.
Old Oct 3, 2006 | 06:02 PM
Rudyrono's Avatar
2006 E55 AMG
I don't think the additional 3 mm of sidewall on the 265 would give you an advantage over the 295/35, especially since you're getting 30mm in width with the 295. If the 295 fits, I would use that. I have 315 Nittos on my F-body and when new, they hook up like a mad dog.
Old Oct 3, 2006 | 06:08 PM
dragonAMG's Avatar
That's exactly what I was thinking. A good friend of mine who knows his s**t told me that larger sidewall will only help in drag racing is if it's a true "wrinkle wall" tire.
Does anyone know if the 295/35/18 will fit?
Old Oct 3, 2006 | 06:32 PM
Jakpro1's Avatar
2003 E55 & 2014 GL550
Not sure the "best" but 275/35 R18 are the ones I ran at the track with no problems. Big D-FSU ran those too, before the MT's of course.
Old Oct 3, 2006 | 07:00 PM
Jrocket's Avatar
E55
275/35 R18
-- 27 lbs.
-- Diameter 25.6"
-- Width 9.5"
Best one too run.
Old Oct 4, 2006 | 12:29 AM
sly55's Avatar
05 E55, R33 GTR, R33 GTS-t
i too was noting the diameter.. if you can get traction, the smaller diameter is effectively like dropping your diff ratio a little bit, while small can help your 60ft time if traction permits, and will help the car rev out a little quicker. Not sure if the difference is that significant, but by the end of the track it may pay off...
Old Oct 4, 2006 | 01:17 AM
GTA23109a's Avatar
04 E55
I run 275/35/18s.
Old Oct 4, 2006 | 01:33 AM
medici78's Avatar
'03 G500, '13 G63, '17 GLS63,
I ran 275/35/18 on mine with no problems. Can't comment on any other size, but they hooked up great.
Old Oct 4, 2006 | 03:47 AM
FlyByNight's Avatar
05 E55
Originally Posted by Jrocket
275/35 R18
-- 27 lbs.
-- Diameter 25.6"
-- Width 9.5"
Best one too run.
exactly... that's what we were running at the track... 295s will rub and aren't worth the extra risk, aka, the wiggle...
Old Oct 4, 2006 | 09:23 AM
WayneE's Avatar
'72 Suburban
I run 285/35 18 Nitto drag radials as my street tires.
Old Oct 4, 2006 | 09:41 AM
JokerzWld's Avatar
2014 GL 350 on order
Drivers: call Luke at Tirerack-he sold me 17" BFG that work fine at Milan in Michigan. Joker
