Any Idea about Lowring the Airmatic!
Hi guys,
Any one have an idea i mean clear one that i can lower the Airmatic system.
actully i found many details but i am looking for the clear and simple one that gaves you direct the way of lowring.
Regards
Regards
1. push the airmatic button on your center console
2. renntech or carlsson lowering module
3. star diagnostics
4. washer method
i'm sure if you search any of those you'll find as much info as you need.
here's one to get you started:
https://mbworld.org/forums/w211-amg/107267-lower-your-e55-20mm-0-8-80-cents.html
3. star diagnostics
4. washer method
To bad you don't live in Maryland... My Mercedes tech installed adjustable links up front that allows you to set the front to any stance you want. On the rear he just put a slot on the axle to lower it to match the front.
I just had him install my pulley kit too. If anyone in the MD/VA/DC area wants his number let me know, he does all kinds of side work.
BMW E39
3. star diagnostics
4. washer method
https://mbworld.org/forums/showthread.php?t=107267
3. star diagnostics
4. washer method
Washer method here, been half a year and they're great. Though, if I had the money, I would definately do module.
Can you PM me, Quick? It would be nice to have a good contact like that
1 Post
2005 E55, 2004 E55(sold), 2001 Viper GTS, 2006 Viper VOI9, 1994 ZR-1 Corvette 2009 Viper ACR,
If I turn my car to sport II mode. The wheels practically tuck inside the wheel well (too low for me). why would you want to lower this car?? I wouldnt do it... but its up to you..
'03 G500, '13 G63, '17 GLS63,
Sounds like your car has already been lowered. Did you buy it new or used? If used, maybe the previous owner had it done. If new, then something's up. I've never seen a stock E55 sit low enough to tuck the rear wheels. My E55 is lowered and it doesnt tuck much, if at all.
2017 S63 Coupe Iridium Silver
Indeed, the front does not lower but the rear drops 10mm from Comfort to Sport 1. There is no further drop on Sport 2. Then at 68 mph there is another drop of 15mm front and rear, but that is rather hard to verify as the ruler keeps bouncing off the asphalt as I lean out of the driver's side door...
Super Moderator
Indeed, the front does not lower but the rear drops 10mm from Comfort to Sport 1. There is no further drop on Sport 2. Then at 75 mph there is another drop of 15mm front and rear, but that is rather hard to verify as the ruler keeps bouncing off the asphalt as I lean out of the driver's side door...
