K1 Dyno on E55
Green run is my baseline dyno. Yes I know. I have a low powered E55
But what can I do! The blue run is with the sprint booster installed. And the red run is with the sprint booster taken off. I understand that 403 rwhp is low for an K1 E55 BUT I am not dissappointed as my car is MUCH more powerful than stock. I gained almost 50 lbft of torque. I can definately feel the torque through out the power band. I mean the car keeps on pulling and pulling and doesn't stop. My dyno guy said that with the sprint booster the linearity of the throttle past 3/4 felt weird and didn't feel linear. Baseline dyno- 370 rwhp/410 torque
K1+Sprintbooster - 392 rwhp/464 torque
K1 - 403 rwhp/452 torque
What do you guys think? Let me know your thoughts
2) Ask if they can apply a smoothing factor of 2 to 4, then see what the numbers are. I think the peakiness of the chart is skewing the absolute #s.
This is also right where the dynos of the 63 cars have been. This is probably not a coincidence, given the nebulous role of the ECU update in fixing a potential emission problem and the timing of the recall with respect to the 63 engine introduction.
Anyway I am more and more pleased with the 478.5rwhp (on same Dyno Dynamics) from my Renntech mods. No doubt some of the 106.5rwhp I gained was related to reversing whatever electronic restraint MB had implemented.
Call the dyno shop and have them email you plots with CF=STD, smoothing=2, and include A/F ratio curves.
If it were my car, I would go back to the dyno and run again, with the pulls starting at 2500 RPM. I would also repeat the Sprintbooster experiment - there's a 15-20 HP delta from yesterday's dyno pull - you really need to verify if that is real or not.
I would also head for the track and verify the dyno numbers with 1/4-mile trap speeds. With 400 whp you should be in the 113-114 mph range, about 4-5 mph short of where a K1 car should be.
BTW, correcting to SAE standards does not always result in reduced numbers. If the temperature was higher than the SAE standard (77 *F), and/or the barometric pressure was lower than the SAE standard (29.235 in-Hg) on the day of the dyno, the corrected numbers will/can be higher.
I was hoping that the Kleeman ECU remapping would solve that whole ECU issue but it didn't. Again I am please with my new found power. Like I said before, it pulls and pulls and seems like it doesn't stop pulling.... either way, I think I am going to find a new dyno guy. Just to see if they corrilate in numbers...
It goes from "pulls" (K1), to "Amazing!!"(K2), to "Son of a b-itch!!!" (K3) to "MOMMMYYYYYY!!!" (K4)
Something is not right there....the power should be increased all the way from beginning to end over the green line, and I do agree the power drops off way too soon and too steep. Maybe the car isn't exactly in the dyno mode where traction control is still taking over.
Wayne
Wayne
