Rear Jack Point?
06 E55 SOLD, 89 300 SE 375,000 miles
I agree. I have only seen the 2 pads on each side of the car, and those are the ones I use that jack up only the wheel it is situated next to. In order to lift both front wheels you have to use a floor jack under the engine or under the rear axel fro the rear tires.
look under the front close to the oil pan and you will see a "pad" sticking down through the plastic splash shield. the "pad" is attached to the crossmember about 15 inches from the front air dam.
