EuroElites: RENNtech Stage 3 + RENNtech IC pump
2003 E55 AMG
HP seems to be ok, but the torque readings are very low.
Headers, ECU, pullies should be in the 540rwtq - 560rwtq.
Most stock cars dyno with 475rwtq or more.
Looking at the step-up for the torque curve from 2,000 to 2,500RPM the dyno operator may have been a bit slow on the WOT engagement and hence the slow ramp-up. It should be a fairly steep ramp at 2,000RPM to peak torque.
Jesse, this is a different shop.
Victor, i have to agree the the torque number is a bit on the low side. And you might be right on the dyno operator being slow.
Chris, the dyno charts show the pre mod and post mod with Stage III + IC pump installed.
Chris, the car is probably in dyno mod. I wasnt there at the dyno place today.
Fikse, Stage II consist of CF airbox, ECU and pulley.
Stage 3 : $9695 retail.
EuroElites will dynotune the car later this week. And will have another post mod dyno readings.
IC Pump
I also would really like some more info on the new RennTech IC pump. Even if it is a bit pricey, you can rest assured that if RennTech sells it, it will be a no-hassle, direct-fit, bolt-on, RELIABLE upgrade that delaership techs will be willing and able to install. From what I have heard about the "stock" IC cooling system on these cars, they sound like the Achilles' Heel. I think a great pre-mod "base" would be a better IC pump and one of Patrick's 160* Thermostats and THEN move forward with pulleys, ECUs, headers, and TBs.
It is a not a johnson pump. Rest assured.
Each car has its own behavior/personality. We dyno tune the car so that we are personally satisfied with it. Thats' EuroElites and Renntech main goal; customer service.
Also, dyno-tuning is included in the performance package.
Why do you need to dynotune the car? Doesn't Renntech already have this worked out for the Stage 3 mods?
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
So is the new Renntech I/C upgrade kit just a new pump and required fittings, or does it add an accessory heat exchanger and reservoir and separate the two water circulation systems like the Evosport kit ?
Surely for the asking price it cannot be just a pump !
