SBC Braking vibration
1 Post
CLK500/Range Rover HSE/E55 AMG/Bmw 328Xi coupe/BMW 4.8x/Bmw 335i/GS350/Audi S5/E350
Does anyone get vibration when pumping the gas pedal? If you are, do you know if there is a fix for it? I get this annoying vibration when i pump the brakes. Dealership tells me its normal.
first off what are u talkin bout when u said vibration when pumping the gas pedal? u meant brake right?
and why are u pumping the brake pedal? Ur not talking about feeling the sbc doing its self test are you?
'06 CLS55 P030
its a normal characteristic of the system however there are updated flex-lines and some mumbo jumbo for the pump unit that improves the vibs some...i'd just learn to live with it personally
The vibration you're feeling is your SBC pump self-testing itself. It'll do this at start-up or if you pump the brakes about 2 or 3 times and periodically while driving. It's normal. There is, however, an updated return line to your brake reservoir that has a "muffler" installed in-line to help reduce the noise/vibration felt inside the cabin.
'06 CLS55 P030
warped rotors is only felt while driving and holding pedal firmly which is clearly not what he is refering too...i know about the dtb too...the flex lines I mentioned are part of the solution...
'06 CLS55 P030
..and jangy after the dtb is performed you will still feel the pumpy pumpin kid..been there done that...sbc is sbc learn to like it or dont buy a 211 or 230...didnt you test drive your car b4 you bought it?
2015 S212
Me? You clearly don't do your research. I love the SBC. And no, I did not test drive the '04E500, '05E55, or '06E55 and yet I am somehow totally satisfied with it. I was just saying there is a DTB out for it. I wasn't complaining.
Mine ended up with warped rotors, which make the wheel shake, but that is simply because i am heavy on them. No complaints here, but thanks for the advise anyway.
What is this? Try to one up on Jangy week?
'06 CLS55 P030
I do the research...i do the actual work too...and hear the clients complain after the dtb is performed that "its still doing it"....mostly because they never had a vehicle that the brakes acted in this manner before and sbc system was never explaned to them properly...the vibe is not a problem...thats what it does. Sbc is the safest and most advanced braking system out there but the pedal vibration (not refering to a rotor pulsation) in normal and the dtb does not completely take care of this issue, thats the facts and I was just trying to tell the poor dude the *** truth. Get used to the brakes and their quirky characteristics...they are not all that bad once you get used to them...that is all im saying
