It is going to get turboed
Old Nov 23, 2006 | 08:40 PM
  #51
EUROTEK//AMG's Avatar
German
thats what I like less talk more pics.... Who's doing the job on your car? ;
Old Nov 23, 2006 | 10:28 PM
  #52
Ted Baldwin's Avatar
300ce
............good point. There isn't much to see right now. Engine is in the shop getting the cylinders "sleeved." Custom valves and valve springs being made that can with stand forced induction. Will post pics when done. All work is being done locally.
..........with a project like this that is part experimentation, I'll be very interested in everyones ideas even if it makes it seem like too much talk.
Ted
Old Nov 23, 2006 | 10:42 PM
  #53
gujupimpster89@'s Avatar
97 e420
hey do u have any pics of the kleeman 55, or any videos?
Old Nov 24, 2006 | 07:37 AM
  #54
300ce
Here are the pics.
https://mbworld.org/forums/showthrea...ight=ted+suede
Ted
Old Nov 24, 2006 | 05:26 PM
  #55
German
Originally Posted by Ted Baldwin
WOW! sick E55 Kleeman
do u still have the car ?
Old Nov 24, 2006 | 06:52 PM
  #56
300ce
..........yes, that is what is gettint turboed.
Ted
Old Nov 24, 2006 | 07:21 PM
  #57
97 e420
WOW THAT IS SICKK
Old Nov 24, 2006 | 07:39 PM
  #58
amgdriven's Avatar
w210 E55
Ted
refer to:
..........I already have close to 600crank HP with the current Kleemann S8 configuration. So it wouldn't make sense to aim for 500crank HP. Our engines can take the boost. The problem is with engine management software.
Ted
Old Nov 24, 2006 | 08:07 PM
  #59
German
Ted
lol...oh..sorry im MB noob..I thought u where talking about the 03-06 E55K
Is the motor going to be fully built ?
Are turbo exhaust manifold going to be tubular or cast ?
Whats kind of tunnig options do they make for MB ?
Old Dec 19, 2006 | 06:57 PM
  #60
OJwerks's Avatar
not stock.
updates??
Old Dec 19, 2006 | 11:44 PM
  #61
sly55's Avatar
05 E55, R33 GTR, R33 GTS-t
any ideas on what model turbo yet? The new GT-K range looks awesome, i have just ordered a GT-K850 for my GTR. The GT-K650's with the 0.68 rear should easily support 1000+HP in twin config, and should be plenty responsive. Is a 0.68 rear possibly a bit small, could "possibly" choke the top end if your boosting towards the upper limit of their efficiency. But for your target 1000, 2.7litres per turbo, sounds very nice!!
link to the GT-K's for those interested http://www.turboneticsinc.com/turbo_gtk.htm
Old Dec 20, 2006 | 12:36 AM
  #62
L8Apex's Avatar
05E55
Ted,
What mods do you have planned for the motor? Pistons, Valves etc. I'm sure heat will be a major factor for the build. Look into a set of iconnel valves and so1 coating for the combustion chambers, valves and pistons http://www.hpcoatings.com.au/pages/so1.htm . Good luck! Look forward to the updates.
Old Dec 20, 2006 | 12:51 AM
  #63
AdamG@NorCal's Avatar
EVOTECH Mercedes AMG
So far so good Ted!! Wow, looks good! Good luck!
Old Dec 20, 2006 | 07:47 AM
  #64
300ce
...........thanks for the replies. the engine is in the shop getting the following.
1. sleeving of the cylinder walls with coating
2. Low compression pistons. Planned compression ratio is 8.5:1
3. Custom valves and valve springs
......unfortunately, I am told that above things take about two months to fabricate
........the computer people are busy trying to figure out the engine management system to use
.........heat will be a major problem.....open to ideas on this and everything.
..........I have not decided on which turbo yet. I have been in contact with turbo technichs. The planned set up will be two large ball bearing turbos.
Ted
Old Jan 7, 2007 | 08:02 PM
  #65
OJwerks's Avatar
not stock.
so... im hoping that now that the holidays are over we get more updates on this......
as of "heat".... thats not such a big issue as it sounds..... by adding:
1. Oil cooler
2. Water/methanol injection
3. fuel cooler (cryo)
4. electric fans with more capacity
you cannot cut corners on the above... as that will ensure the proper wear of all parts, specially the turbos (oil cooler)... the addition of a turbo timer shoudnt be a bad idea...to cool everything once the car is shut off.
Old Jan 7, 2007 | 08:22 PM
  #66
300ce
1. Oil cooler
..............Thanks for the info. I have no plans to cut corners. This project WILL be completed unless it is physically impossible. Electric fan with more capacity is being done. There are some space considerations. Oil cooler, I did not think of myself, but I understand how it can be done. I'm afraid I know nothing about fuel cooler. Can you elaborate?
Ted
Old Jan 7, 2007 | 09:30 PM
  #67
German
Ted
http://www.designengineering.com/pro...asp?m=sc&cid=1
Old Jan 7, 2007 | 09:32 PM
  #68
German
Ted
U should looks into a twin Garrett GT30R or GT35R turbos.
What is your WHP goal ?
Old Jan 7, 2007 | 09:35 PM
  #69
German
1. Oil cooler
+ custom vented hood, Ceramic coating most parts and DEI heat wrap them also ...
Old Jan 7, 2007 | 09:39 PM
  #70
German
I dont know much about MB tuning.. but maybe u can have Renntech or kleeman custom tune your car ? or look into EMS ..like AEM (EMS), talk to the guys over at Evosport for that..
Why not use a single BIG turbo ?
Old Jan 7, 2007 | 09:55 PM
  #71
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
heat wrap can be a good way to ruin thousands of dollars worth of parts, specifically turbos and exhaust parts. imo, it should ONLY be used to protect parts from heat, not used on heat containing parts (anything to do with exhaust gasses). i don't claim to be an expert but i do speak from first hand experience with turbo and non f/i motors.
Old Jan 8, 2007 | 03:25 AM
  #72
300ce
.......Most of the turbo cars you see at the track are 4 or 6 cylinder low displacement cars. To get the power, these cars need larger turbos and a lot of boost than a W210 E55 would need. With my E55, we are starting with a 5.2 liter V8 engine that already makes 350HP stock. Getting to say 800RWHP with two relatively large but not extremely large turbos will be easy. This can also be done at much lower boost than these other cars. I believe that a turbo running at the same boost level as a Kleemann supercharger will generate twice the power. As you know, more boost equals more heat. At current time, the boost level we plan to use hopefully will not generate too much heat as to need cryo fuel cooler. Another thing also is that the car will be daily driven. We have our eye on the Mercedes S600 ans S65 as models. These cars can be driven all day long and have simple turbo systems.
Ted
Old Jan 8, 2007 | 11:57 AM
  #73
Mad TKD's Avatar
honestly ted you really dont need to worry about a fuel cooler. If he plans on running 40+psi then maybe but not at say 15-25psi i think. High octane can help in that are if needed
People have been running setups like this for years in other cars without that. Adding complexity will only make your daily driver less of one.
All you need to really worry about is making sure the engine has enough fuel and the right octane. Twin whatever turbos you run will be great and much smoother than a big single. My days in the supra world remind me how voilent a single compared to twins are. Plus you be able to run pretty low boost compared to smaller cc engines. Your really never gonna know what boost will give detonation at pump gas levels so untill you strap it to the dyno.......
1. correct internals
2. matching turbos for desired boost and drivablity
3. FUEL and Engine management
Thats all you need to really figure out. Your on the right path.
Old Jan 31, 2007 | 12:13 AM
  #74
OJwerks's Avatar
not stock.
Feb. is around the corner.... updates
