Renntech or Kleemann
E55
Sorry to reiterate a topic that is probably older than I am, but which company in forum members' opinion makes a faster performing car? Although Kleemann is highlight toughted on this website, I believe for those cars that have only an ECU and Pulley upgrade, Renntech has the quickest times (ala SGC, and Fikse). Please let me know if this isn't the case as I am trying to get to the bottom of this. I am not as concerned with the K2 cars as I dont think anyone would argue that the Kleemann headers are simply monsterous and if you are ok losing your primary cats that is the way to go. I am trying to determine if Kleemann simply does outperform Renntech on the track because if that is the case, I might simply consider starting from scratch and going to Kleemann. My alternative would be to lose my primary cats and see the difference in hp/tq and 1/4 mile times.
Administrator
MB Steve,
Pour yourself a glass of Ketel One and take a deep breath.
Why in the world would you ever consider removing your Renntech parts? You went with a great tuner and I'm sure in a side by side comparison you would find only minor differences between your car and a comparably equipped Kleemann or EVO car.
I think, as you have stated, the biggest difference can be found in the headers. I believe that this modification is what accounts for the slight 1/4 mile advantage a K2+ car may have.
I know you remember this awesome and extremely informative thread when "The Grump" was at his best.
https://mbworld.org/forums/showthrea...hlight=Headers
My suggestion:
1) Suck down at least three Ketel One's
2)Thank God!!! that you are blessed enough to even worry about something like this.
3) Add enough Renntech mods to polish-off Kleemann, Evo or any other tuner car that may challenge your beast.
My suggestion:
1 Post
STS,FGT,12C,P85D,M4
I think a lot of the differences between tuners can be related to the ecu programming. Every car can react a bit differently to mods, and sometimes a preset program for the ECU will not extract all the power the car could be making. Some tuners could be more conservative than others as well to protect the motor.
I remember reading a while back about a CLS55 that was tuned in the Tampa area. He said the tuner was able to really adjust some parameters to give him a lot more power than the general program from whatever tuner the products came from... Since I'm in RENNtech's immediate area, I had my car in their shop when their programmer from Germany was in town. I have no idea what was done programming wise, but I do know the car picked up 40+hp while I watched with just modifying the ecu programming and back to back dyno runs.
2015 S212
I agree that the ECU tuning is key. It has to match the conditions of use.
MB Steve,
My suggestion:
My suggestion:
Glad you didn't say Grey Goose!
Ketel One's all around!
E55
Thanks guys!! I think the key is probably to send my car to Renntech and have them tune my car personally. We shall see what happens when the tracks open up next month...
you might want to consider the bigger pulley that renntech is coming out with for the E55...i read that it should be out soon in one of the threads around here, should make a nice addition to the mods you already have...
E55
Next mods:
1) Larger Renntech Pulley
2) Renntech I/C
3) Renntech long tube headers (maybe)
I will probably have to wait at least until February though. Would like to test my car at the track before putting on these addtl mods..
.........the fastest cars in my opinion will be combination of ASP/Hennessey pulley with Kleeman set up including headers. Then add a larger intercooler of some sort. Everyone bad mouthed Hennessey when they were the first to come up with the larger pulley rquiring a smaller water pump pulley. Now Renntech has copied the approach and all of a sudden, everyone thinks it is okay.
Ted
Ted
04 E55
Consider?? I am on the waiting list.. (if there is one)
Next mods:
2) Renntech I/C
Next mods:
2) Renntech I/C
WTF am I reading this right ? Renntech came up with a LARGER crank pulley and water pump pulley ? I just gave my left nut for my Stage I no more than a few months ago...that really sucks big **** if its true...guess i better go look at their website.. Adam at Euroelites..is this the new deal ? Will they offer any upgrade for the saps that have the smaller setup ?
E55
They do not want to give this part to people running a car with a stock IC system. They feel it stresses the cooling system beyond what it was designed for and it makes the car prone to having very high intake temps. If you want to upgrade your IC system you can have the larger pulley but if you want to leave the IC alone you should not go any larger.
I think they are offering these larger pullies to press further on very modified cars. Its not really a new stage 1 but more of an addition to say stage 5 etc.
...........of course, what else are they going to say? Besides, there is nothing fundamentally profound about that statement. Any forced induction car suffers from heat soak issues including the AMGV8K cars. Larger crank pulley equals more boost and more heat and more lean a/f ratio. Using this as a way to sell their overpriced intercooler is good marketing, but nothing makedly insightful. People are capble of using these larger pullies and tunning their cars properly without buying a $15K Renntech intercooler. Many have also used these larger pullies without any ECU modification and are just fine.
Ted
E55
It is my understanding that the new pulley must come with their I/c pump upgrade which is similiar to the Evosport I/C upgrade. This is different than the Renntech SLR intercoolers. Timing of release is uncertain as far as I know. Could be months before it is released.
...........understood. The question is why is anyone waiting for a Renntech large pulley when the product has been available for years by ASP and Hennessey? My point is that this is nothing new or interesting for that matter. For those already have the Renntech or Kleemann ECU, just get the Hennessey or ASP pulley. No, we are all waiting for when Renntech says it is okay. No Brutus the fault is in us that we are underlings.
Ted
E55
Ted
Ted
Ted
Ted
S600TT, R350
There is a reason why most tuners keep the crank pulley similarly sized.
Going larger, like ASP (Hennessey), leads to kompressor clutch slippage over period of time.
Tuners already know it. If you are running ASP you will find out.
E55
I have ASP pulley and will be putting on my kleeman Headers w/downpipes. The ASP is a miracle worker for 800 bucks, I have not seen any other cheeper HP gain in these cars. I gained 30 RWHP just by a pulley, not including the ECU, if the clutches start acting up, then i will just take it in for replacement.
Ted
