Secondary heat exchanger
C32 AMG, C230 Kompressor, Grand Cherokee 5.7 HEMI
Does anyone know where I can buy a heat exchanger like the one evosport uses on their cooling upgrade package? or if evosport would sell it separately?
I currently have a secondary heat exchanger modification on my C32, but I couldn´t find one that had the inlet and outlet on the same side, so I had to run a line all the way to the other side, which I think is taking away the efficiency of the system, even with the bigger water pump I have.
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
Me gustaria saber cual es la bomba mas grande, marca y numero de modelo que tiene usted, sino es mucha molestia.
Gracias,
Ok, aqui está un link a la página.
Jabsco water pump
No la compre ahí, pero ahí vienen detalles. La compre en http://www.wmjmarine.com/ La verdad la bomba jala muy bien y no hace ruido. No embono así nadamás pero fue fácil adaptarla al C32.
English:
Ok, here is a link to the website.
Jabsco water pump
I didn´t buy it there, but there are the details. I bought it on this website http://www.wmjmarine.com/ The pump works really good and it ain´t noisy. It wasn´t a bolt-on but was quite easy to make it fit on the C32.
S600TT, R350
The heat exchanger from evosport will not work on C32. Not enough room to mount it with stock or even aftermarket bumper cover.
With only 350HP, stock exchanger - which is the same size as E55 - is more than adequate.
Go for more boost and more efficiency with Evosport Power Stages for more power, at this time stock IC system is adequate.
http://www.evosport.com/product/prod...VO.PER.M03.S01
Administrator
2020 Audi R8 V10, 2016 AMG GTS, 2018 E63S Edition 1, 2018 Porsche GTS Cab, 2012 C63 BS
Español:
Jabsco water pump
English:
Jabsco water pump
Jabsco water pump
English:
Jabsco water pump
Viva SLP
una cosa mas, Your english is outstanding.
