Stock front wheel/tire weight vs 20" HRE w/tire weight?
Does anyone know what a stock front wheel/tire weight vs. 20" HRE three piece w/tire?
Thanks,
Jason
I have both, but do not have them handy for weighing. When I rent the dragstrip again I want the lighter of the two options on the front of the car.
Thanks,
Jason
But if its soley performance then you need to get a 1 piece 18 inch wheel. As for the original question I have seen my factory wheel weighed ... it was 27 lbs and the rear was 29 lbs (E55). You can pull the tire specs from TireRack's site but I would guess their weight to be around 28 to 30lbs each.
I had my 18's for all of 3 days but to go up 1 inch in diameter and drop 7 lbs in the front and 9 in the rears has got to mean something and the sotp feel is that handling is better. Truly what has given my car the boost in the corners is the LSD.
I guess I will have to pull the rims/tires off and weigh them.
In the meantime if anyone has the info I would like to know......
Front stock wheel/tire weight?
Front 3pc. HRE 20" wheel/tire weight?
Thanks,
Jason
