TIRES too big?????? Will these Work?
Old Mar 28, 2007 | 03:24 PM
PerisanGodFatha's Avatar
is Sick as Fu*k
I was wondering if running a 285-30-20 rear and a 255-30-20 front would fit, or would it be a nightmare. the car is lower than stock...will I rub maddddllllyy, or will it be ok...which fitment would give the problem the 285-30 or the 255-30....THANKS
Old Mar 28, 2007 | 04:16 PM
pas's Avatar
pas
2007 S65, 2005 Nissan Armada
I had 245/35/20 and 285/30/20 the fronts were ok except at full lock the rear showed no signs of contact but the car had the rear end "wiggle" the wheels came off a CL600 so the offset may have been incorrect. My car was stock height. I went back to the 18's because the ride sucked. Looked good though!
Old Mar 28, 2007 | 04:32 PM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
if the offset is correct you will have no problem.
Old Mar 28, 2007 | 04:56 PM
mogz's Avatar
AMG
Why not 285/25 on the back? Ride is not that bad IMO...
Been driving for a week in mad downtown SF roads and it's not as bad as I expected...
Old Mar 28, 2007 | 05:37 PM
Efivefive's Avatar
E55 AMG
Running a 285/30/20 back and a 255/30/20 front would result in the back wheels standing taller than the front......is this something you are trying to achieve. The correct size would be 285/25/20 in the rear, remembering that the 25 height measurement is a ratio of the tyre width.
Old Mar 28, 2007 | 05:56 PM
is Sick as Fu*k
just came across a great deal on pilot sports but I was acually thinking of going 245-30-20 AND KEEPING the 275-30-20 ....I think 25 is way too thin, Mogz you know how bad LA streets are I wouldnt want to drive like a grandmother just to becareful with the wheels...i feel like Id have to with the 25 series...
Old Mar 29, 2007 | 12:04 AM
mht_v10's Avatar
w211e55
I guess it's depend on the offsett. I was using 245/35/20 and 275/30/20....the front rubs to the bolt when turning, and then I replace the front with 245/30/20, no problem afterwards, but now Im curious to try with 255/30/20 since the 245 is really thin compare to my rear tires....
Old Mar 29, 2007 | 12:07 AM
is Sick as Fu*k
i know korn55 is running a 255-30-20 in the front on his E63...maybe we can get his .02
