supercharger boost gauge
Old Mar 28, 2007 | 11:57 PM
mfissel's Avatar
2020 C63S Coupe
Has anyone installed some type of boost read-out from the supercharger? Where would one find an output that reads boost pressure?
Old Mar 29, 2007 | 03:34 AM
stevebez's Avatar
No longer stock '06 E55, A3 3.2 Quattro, GLE 400d, R107 280SL, Golf Polo
I use ScanguageII for boost and IATs ... plugs into ODBII port and there we go ... have it mounted on steering column below instrument cluster.
Temporary install - dont think I will ever make it permanent - but usefull tool. Its a bit slow even at its fastest update rate but gives me what I need. Update speed is around once every second - so can be a bit painfull when you want more detail. Also you cannot dump data down to PC - that would be handy as sometimes you cannot watch all data items at the same time - it also cannot recall recent max / mins - which I find odd.
It does what I need (I basically wanted an IAT and Boost guage) and I just dont fancy driving around with a laptop in the car!!!
BTW is there any datalogger that gives you A/F ratios ??
Old Mar 29, 2007 | 11:19 AM
dsc's Avatar
dsc
2004 E55
I'm pretty sure US E55s don't give boost pressure info via the computer. I believe the only way is to do a physical tap.
Old Mar 29, 2007 | 11:41 AM
rflow306's Avatar
2005 E 55
You can get manifold pressure via the obdII port with any generic scanner. You have to convert the values to psi and subtract atmosphere but there are a few scanner programs that will display in psi.
Old Mar 29, 2007 | 01:24 PM
dsc's Avatar
dsc
2004 E55
So Steve, does the ScanguageII convert then?
Old Mar 30, 2007 | 06:38 AM
stevebez's Avatar
ScanguageII shows total PSI .. so u need to subtract atmos ... but this is no big deal.
Can be found here ....
http://www.scangauge.com/
Old Mar 30, 2007 | 02:59 PM
pshek's Avatar
2003 C-Class Sportcoupe
I have the carchip e/x. It is not a realtime display like the scangauge, which didn't work on my car, but it is a data logger that can log and download to PC via USB port. It logs up to 300 hrs (individual engine start-stop runs) before writing over old data. With CarChipE/X with Alarm you'll also be able to monitor any four out of 23 user-selectable engine parameters(MAP, RPM, etc). I bought mine at CompUSA.
I didn't realize that you had to subtract atmospheric pressure. I was looking at my old MAP graphs and it showed 20-25 psi at times.
Old Apr 3, 2007 | 01:21 AM
NOEZWA0UT55's Avatar
mazda
Omg dont let the dummy with the supra find this post! he will hate on you like he did me. We need guys like to to make the world go round lol
Old Apr 3, 2007 | 09:37 AM
Cylinder Head's Avatar
'19 E63S, ‘16 CLS63 RIP, '09 E63 Gone, '06 M5 Gone, '97 Supra TT Gone
They're talking about it for tuning purposes, not to impress Johnny Tran and his crew.
Old Apr 3, 2007 | 11:38 AM
stevebez's Avatar
The Scanguage does what I need - Boost & IAT and timing but I have not got a handle on how timing varies at WOT vs IAT vs Boost. Thats why it would be great if you could dump this data somewhere to review later.... the Scanguage should have a USB memory stick port where it can dump a rolling few hours of data ... should be simple as making tea to put that together.
O well ... mbe I need the autoengenuity scantool for this ... - looks the part.
Old Apr 3, 2007 | 02:43 PM
mazda
lol
Old Apr 3, 2007 | 02:45 PM
lol
I know you love the F&F reference.
"They've got 3 civics with Spoon engines and MoTec system exhausts!!"
Where the hell did they come up with the dialogue for that movie??? MoTec exhausts??? And since when did Spoon do anything having to do with tuning the **** out of an engine?
