Sprint Booster where to by other then SLKfans
Old 04-01-2007, 10:00 PM
bfnnrgn's Avatar
SL65
Originally Posted by jangy
I drive mine like I stole it. All day everyday.
I don't, wish I could. I also wish I could replace the computer with a throttle cable and be rid of a lot of this computer intervention to begin with.
Old 04-01-2007, 10:09 PM
x-tian-230k's Avatar
CLK500/Range Rover HSE/E55 AMG/Bmw 328Xi coupe/BMW 4.8x/Bmw 335i/GS350/Audi S5/E350
Jangy,
The kick down switch is TRUELY just a button that has nothing connected to it. It might be different in the 03-04's. I think u drive an 05. The kick down switch is acutally the movement in the gas pedal going pass a certain point.
You seem very passionate about how the sprint booster works and how its not a mod but for a person who has and ECU done up by Kleeman, I love the sprint booster. The ECU remapping doesn't do much about the lag time. If I want to take the jerkyness away, i drive in C mode. STill very responsive and drives likes like a differnt animal. Even without the sprint booster, I try to smash the gas pedal, there is still a little bit of lag time. Sprint booster gets rid of that lag time..... anyways, I understand that you are not a fan of the sprint booster, but major of people who actually have and use the sprint booster everyday, I can safely assume that we are very happy with it....
Old 04-01-2007, 10:16 PM
Kev04C320's Avatar
'09 911 C4S
I'm still doubtful that the kick down switch does nothing. It's been proven in the Porsche 997TT Tip that if you depress the accelerator all the way down, it will result in worse 1/4mi time than if you don't step on it all the way, and it is equipped with a similar kick down switch.
Old 04-01-2007, 10:34 PM
bfnnrgn's Avatar
SL65
The 911 may have something there, but our cars do not. It's just a dummy button on every car I've taken the pedal out in. That's not to say that the position sensor in conjuction with the throttle computer doesn't do something when the position of the throttle enters the range where the button is, but the button itself has no function. Get a socket wrench and pulls your out, takes 5 minutes and you'll see.
Old 04-01-2007, 10:44 PM
Kev04C320's Avatar
'09 911 C4S
Thanks for reminding me that I don't have beast right now
https://mbworld.org/forums/w211-amg/184711-beast-got-hit-last-night.html
I'll do that once I get my car back. Thanks.
Old 04-01-2007, 10:57 PM
jangy's Avatar
2015 S212
Originally Posted by x-tian-230k
Jangy,
Actually, I know lots of people that like it and have had my throttle response reprogrammed in older cars. i simply do not like it from a performance perspective on the E55. the "lag" that is there has NOTHING to do with the sprintbooster being there or not. It may SEEM to go away with the sprintbooster, but that is simply not possible, since the lag comes from the SC clutch AND TQ converter. In my case, I am big on handling and driving the car the way it was designed. If it truly is a DD, then sure, I can see where the sprintbooster can make it more palatable.
Interestingly enough, another issue I have with the sprintbooster and all the ECU tuners is why would they not program in an ideal throttle curve? I hate how incomplete and vague all the tuners are with their probgrams. All we (the customers) want to know is how much does it cost and how many HP it gives, but that doesn't translate into faster lap times.
Different strokes for different folks. Reality is that the sprintbooster is a cheap mod that has no irreversible detriment to the car, so i do not mind people geting it. I just find it funny that everyone is trying to get their cars to do the opposite of what I am. I want MORE modulation of the throttle not less.
Old 04-01-2007, 10:59 PM
  #32
jangy's Avatar
2015 S212
Originally Posted by bfnnrgn
You don't take the button out, but it's attached to the pedal and the entire assembly has to come out when you install it. You can then examine it. It's a thin piece of plastic and once it's off you can see there's nothing attached to the button. No wires, it sits there all by itself. A socket wrench and 5 minutes and you can see it for yourself.
I have and will. I got all pissed that my car had a bottle cap placed over the button during a dyno run and so i did take mine apart and look. As you say, 5 minutes, so I'll post pics.
Old 04-01-2007, 11:01 PM
  #33
jangy's Avatar
2015 S212
The intervention can be overcome. why don't you drive it hard?? Hehe!! maybe that is what the real problem is?? To each his own, bro. do what you do.
Old 04-01-2007, 11:09 PM
  #34
EX-BEEMER's Avatar
'08 SL550 Sport, '11 BMW 550ix M sport
I've installed a S.B. on my ML63 and absolutly love it, but I'm not sure I would do it on a S.C. 55 motor. My E55 had traction problems stock from the factory. To add a S.B. might make it more twitchy yet.
An E63 would probably benefit more. Less torque down low where the Sprintbooster shines.
It really works well on my AWD ML63. 4 other ML63 owners installed units within the last weeks and all love it.
You may also try Stealthauto for acquiring a S.B. He's becoming the USA distributor. (Also a MBworld sponsor)
Old 04-02-2007, 03:17 PM
  #35
Jany,
Did you remove the kick down switch yet? Is yours differnt than ours?
Old 04-02-2007, 05:06 PM
  #36
phatmitzu's Avatar
2005 E55
Question:
Does the TB open 100% when we only press the gas pedal down to the kickdown button? Or do we have to actually press down the kickdown button everytime to WOT?
Old 04-02-2007, 08:16 PM
  #37
jangy's Avatar
2015 S212
Originally Posted by phatmitzu
Question:
right now there is confusion on the kickdown button the E55. Some say it is a dummy button, which wouldn't do jack to your TB valve. i don't know that it should. i assumed it was for TCU more.
Old 04-02-2007, 08:17 PM
  #38
jangy's Avatar
2015 S212
Jany,
Not yet. I been at work all day. i'll do it and tell. What I can't figure out is why the OEM part has the wire plugs on it if you guys say there are no wires running up to it (from behind). I know the front doesn't have connections.
Old 04-02-2007, 09:18 PM
  #39
Roupin's Avatar
a toy
The kickdown switch works on my 07, so everyone who's complaining about it just isn't driving hard enough.
If you drive aggressively, the car will downshift hard without the kickdown pressed...BUT it will not hold the lower gear if you ease off the gas. With the kickdown slammed, it will still hold the lower gear for a good 3-4 seconds, even after completely getting off the gas. It serves a purpose in my car.
The only thing I can think of is some of you guys just don't drive hard enough, and your cars are in "pu$$y mode"
As for SprintBooster, it's a GREAT mod for those of you who are terrified of the gas pedal. Don't EVER consider that a real mod though, since it only makes a difference on the driver, not the car.
Old 04-03-2007, 01:45 AM
  #40
jangy's Avatar
2015 S212
Alright, my boy (anothe member here) is going to send me his unit to test and tell about. I'll eat my words, if it deserves props.
Old 04-03-2007, 08:45 AM
  #41
EX-BEEMER's Avatar
Say what you will, I agree it not a performance mod. I just prefer my performance a the top of the pedal instead of the bottom.
Old 04-03-2007, 09:35 AM
  #42
I dont think the discussion is around the kick down button and if it works or not. I believe the discussion is around if the kick down button actually is a button that triggers the down shifting or if its a dummy switch. In taking my accellerator (sp?) assembly apart I found that the switch in MY car has no wires attached to it. I believe that the button is there to mark a certain point in the accellerator pedal. As it goes past that point, it will automatically kick down a gear or red line.
Seconly, the sprint booster does modify your vehicle in some way, shape or form. So I am not sure why you wouldnt call it a mod(ification). Again just my opinion.
Old 04-03-2007, 09:56 AM
  #43
Benz-O-Rama's Avatar
Check your PM...
I'll send it out this weekend.
Old 04-03-2007, 10:11 AM
  #44
Ohh yeah.. Clay-mon is steppin up to the plate...i remember when i had to persuade you to get the S/B... u haven't driven in to any living rooms yet! hahaha... now get off ur butt and post some pictures of your great adventures in to south america fooooo!
Old 04-03-2007, 10:24 AM
  #45
dsc
dsc's Avatar
2004 E55
Alright Jangy, I'm counting on you. Give an accurate review as to what it actually does.
Old 04-03-2007, 10:43 AM
  #46
I know this waaaaay off topic but here's an appetizer:
https://mbworld.org/forums/showthrea...ghlight=brazil
Old 04-03-2007, 12:20 PM
  #47
jangy's Avatar
2015 S212
I will. I'll let you all know exactly what i do and don't like about it.
Old 04-03-2007, 01:04 PM
  #48
Saw those bro....need the top secret secret ones that you have to email me!! heheheh
Old 04-03-2007, 01:37 PM
  #49
Ehem....
Check your Gmail
Old 04-06-2007, 09:50 AM
  #50
Sprintbooster sent this morning. I've also put a coupon in the box for tirerack.com, you're gonna need it
Quick Reply: Sprint Booster where to by other then SLKfans
