Pulleys??
Old Apr 8, 2007 | 01:37 PM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
Originally Posted by jangy
If it trully is simply, fuel economy, then mine will be a fixed system as soon as i can get it done. I'll let go of some mileage any time to get a smoother engagement. I use mine in th etwisties and having the SC be so "on-off" can be rough to handle. i know that is inherent in SC engines, but that is the pig I chose.
i'm sure there is some epa bs that goes with it but i've often thought about the same thing you mention except with a toggle switch like mad maxx to override the clutch. this way the car behaves normally except when i want the s/c on all the time. i still see a problem getting someone to write software.
Old Apr 9, 2007 | 12:32 AM
jangy's Avatar
2015 S212
That gets a little deep for me, but i wouldn't mind a more aggressive clutch trigger.
Old Apr 9, 2007 | 04:22 PM
phatmitzu's Avatar
2005 E55
By the way, since I'm getting raped for questioning the paradigm here... why do we have an SC clutch? Why not have the thing just spin?
At what RPM does the SC clutch engage?
Old Apr 9, 2007 | 06:54 PM
jangy's Avatar
2015 S212
I'm not sure, but recent rumor has it at about 1500 revs/min. I personally think there is more to it than just RPM. Isn't that what adaptive driving is all about? I assume it is "programmed" to turn on and off. The main issue I would have with having it be fixed is the safety feature of shutting it down when the temps rise. I would need to setup a separate temp system or something. To be honest, I doubt i would be the one pioneering such a mod. I am just cusrious is all.
I'm still after a 170mm with nice dampening.
Old Apr 9, 2007 | 07:07 PM
chiromikey's Avatar
iirc, the lowest rpm for a stock 55 is 1750 and renntech lowers that to 1200.
Old Apr 9, 2007 | 11:10 PM
mclarenm8d's Avatar
2003 CL55 Kompressor Horizon Blue Metallic
I've heard that as well but ... in manual mode 4th gear, the SC definitely engages before 1750.
Old Apr 9, 2007 | 11:48 PM
  #32
2MANYCARS's Avatar
20+ to list......
I think it's more than just removing a clutch, meaning the whole ECU has to be remapped, not to mention the clutch is probably one of the important pieces that the ECU chooses how the car is run. Too complicated for me, I'm used to roots type blower with no clutch, so I can say I'm still living in the stone age. hahahahaha.
