How to remove double sided tape?
Old 03-31-2007, 05:11 PM
jangy's Avatar
2015 S212
Hi all. I took the center of my three piece rear spoiler off, since it was not properly installed. I plan to clean it up and re-install it. How is it best for me to clean the double sided tape that stayed on the paint? I was wondering if there is a product or method?
Old 03-31-2007, 06:20 PM
rlee02135's Avatar
2004 C32 ///AMG
heat it up with a hair dryer, then wipe it with a terry towel and rubbing alcohol
looks like the renntech spoiler was better (haha j/k )
Old 03-31-2007, 08:25 PM
m3tonyh@verizon's Avatar
'03 E55
Easy with the hair dryer Rubbing alcohol and a plastic razor blade and it will come off
Old 03-31-2007, 08:28 PM
health services's Avatar
The auto body shops uses a tool that is basically an eraser on a wheel. Use this on SLOW speed drill. If you track down a tool truck they are about $30. Then use a solvent and a soft towel like wd40 to remove what residue is left.
Old 03-31-2007, 09:04 PM
W211 Ryda's Avatar
2004 E320
Best bet would be an eraser pad like one of these.
http://autobodysupplies.safeshopper.com/24/140.htm?416
Pretty sure you could get one from Tri City Paint on Miramar Rd.
Old 03-31-2007, 11:13 PM
jangy's Avatar
2015 S212
I bought some Goof Off. Should I not use it?
There is no fin out there that has the fit, finish, or feel of the MB one, much less RennTech's one. If I wanted a one piece lip, I'd get the e63 one LOOOONG before any other.
Old 03-31-2007, 11:18 PM
PlayboyDiddy's Avatar
2005 E500 AMG Sport
I've used Goof off on my previous Mercedes with no problems. I would try it first on a small unseen area just to play it safe though. If all works out, it should easily take off the left over double sided tape.
Old 04-01-2007, 12:24 AM
vader's Avatar
04 E55
Try Tarminator to loosen the glue....or some other tar remover. At least its safe on the finish .
Old 04-01-2007, 12:28 AM
psk145's Avatar
2006 E55
some heavy test fishing line always works for me
edit: never mind, didnt pay attention it was already off
Old 04-01-2007, 12:37 AM
That’s what I was talking about! But don't use it with a high speed die grinder like the one in the picture. Otherwise you will be guaranteed a burnt spot on the finish. Ask me how I know...
Old 04-01-2007, 01:52 AM
Can Drive 55's Avatar
2005 E55
I think Goo Gone is less aggressive than Goof Off. I have never had it damage anything. I really don't know if Goof Off will damage the finish.
Old 04-01-2007, 02:01 AM
cicbenz's Avatar
1973 Yugo
How do you know, how do you know??????
Old 04-01-2007, 02:07 AM
jangy's Avatar
2015 S212
I'm just pretty sure that Goo Gone won't cut it. I may should do th eheat and wipe thing, then goo gone? I just don't want to screw up any more paint than is needed, even if I do plan to keep a fin on it.
Old 04-01-2007, 02:17 AM
NOEZWA0UT55's Avatar
mazda
ive done alot of this double sided tape removal and my finger used to go numb until i came up with this technique, heat up the double sided tape with a heat gun, hair dryers take to long, then spray tar and bug remover on it, wait about a minute and use a terry clothe towel to rub it away, it should break loose and come of rather ez. Good Luck. and if that doesnt work use the grittiest sand paper you can find lol jk
Old 04-01-2007, 02:23 AM
jangy's Avatar
2015 S212
Sounds like the verdict is to use heat and Goo Gone, before I try Goof Off. I know Goo Gone or Bug/Tar remover doesn't hurt my car and I have a heat gun, so may as well.
Thanks all for your input.
Old 04-01-2007, 05:40 AM
SAMSSONZ's Avatar
OO7 CLS63///G55TANK ///S80-T6///R1///R6
Try paint thinner, nothing works better...
Old 04-01-2007, 06:19 AM
Rafal's Avatar
2017 S63 Coupe Iridium Silver
Turpentine works for me
Old 04-01-2007, 07:53 AM
Ted Baldwin's Avatar
300ce
.......pretty certain about this one. Use a hair dryer as has been suggested. Heat it up and it will come off. I have used it to remove the roof wing on my CLK before. If there is any remaining tape, heat it up again and rub it off with your index finger.
Ted
Old 04-01-2007, 08:49 AM
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
Wow, what is up with the heat guns? If your double sided tape is a 3M product then use the product below. Install the cap / applicator and wet the doublesided tape or what ever is left, come back in 5 min and lift the remains of the tape off. Never heard such wack! heat gun, buffer ball, plastic razor, die grinder, alcohol, get the right tool for the job.
http://solutions.3m.com/wps/portal/3...izePageHandler
Old 04-01-2007, 09:07 AM
300ce
............I am not sure who mentioned a heat gun. I don't even know what that is. What many have used is a hair dryer and it works. Of course this not the only solution. The reason a hair dryer is probably a better option is because presumeably one is removing a piece of trim from their car. In that case the double sided tape is under the trim and not accessible to the various liqiuds and gels suggested. Just heat the trim piece with hot air from a redular ladies hair dryer(no guns) and it comes off. very easy.
Ted
Old 04-01-2007, 11:30 AM
jangy's Avatar
2015 S212
You input is appreciated, alothough not your pompous attitude. Take a good look at the MSDS o the product you suggested. It is simply another name brand for the exact products we are discussing. Thanks again for your input and actually, you have been quite knowledgable and helpful on other subjects as well. Just please quit with the "I am so awesome, you so dumb" mode.
Here is the active ingrediants of what you posted:
Ingredient C.A.S. No. % by Wt
XYLENE 1330-20-7 30 - 60
NONANE (ALL ISOMERS) Mixture 10 - 40
OCTANES (ALL ISOMERS) Mixture 10 - 30
ETHYLBENZENE 100-41-4 5 - 20
TOLUENE 108-88-3 0.5 - 1.5
BENZENE 71-43-2 <= 0.1
Old 04-02-2007, 02:51 AM
SAMSSONZ's Avatar
__________________
Are those the ingredients for making a bomb? Theres some subliminal **** goin on here.
Old 04-02-2007, 08:35 AM
mazda
lmfaooooooo that **** is funny
Old 04-02-2007, 08:40 AM
The Godfather's Avatar
4 wheeled car.
Use Goo Gone.
Old 04-02-2007, 08:41 AM
4 wheeled car.
Goo Gone I Sed!
Quick Reply: How to remove double sided tape?
