*** Custom Paddle Shifters ***
Rating: Thread Rating: 4 votes, 5.00 average.
Old 02-02-2009, 01:15 AM
  #526
The Godfather's Avatar
4 wheeled car.
So whatever happened with that stuff? And ever got to get em to fit on an 03?
Old 02-02-2009, 02:11 PM
  #527
obsidian05e55's Avatar
C63, Grigio Medio E46 M3
+1.. They still have my $150 deposit.. Not that i care about that.. Just wish the paddles worked for us E guys..
Old 02-02-2009, 02:16 PM
  #528
Super Moderator
MJ50's Avatar
bone stock E55 AMG
+1
Old 02-05-2009, 10:19 PM
  #529
lkirchner's Avatar
Several MB's Superperformance MK III Cobra
Originally Posted by vrus
I originally ordered the AMG Aluminum Paddles that come on the new cars but because of the wiring differences, they dont work on all models and years.
Because of this, I went looking for an alternate solution.. I am having custom CNC cut Paddles made which are super high quality. They are made to fit in the STOCK mounting location WITHOUT any cutting, hacking ,slicing, or wiring changes. The paddles were designed to be a "button" replacement and have no electronics.
The first production ready prototypes were installed and tested on a car for quite a few weeks to make sure durability, quality, and overall look & feel were perfect!
We are making them in 2 finishes.. One finish will be Piano Black, and one will be a standard aluminum look like the factory piece. They weigh more than the stock plastic versions but a little less than the heavier aluminum paddles.
Alot of attention was paid to the click and feel to make them as perfect as possible.
These will work in the following cars: C(203) CLK(209) E(W211) CLS(219) SL(230) CL SLK 55/65 AMG for sure. Possibly newer 350 550 models with buttons.
Let me know what you guys think... I really value your input..
Here are a couple of pics of the piano black versions:
I received my paddle shifters for my SL55 and attempted to install them without any luck and I am quite adept at auto anythings!!! It did not work and I totally screwed up the downshift button. On the positive side the upshift worked.
I inquired through the AMG private Lounge and went down the merry road as to the proper part numbers. As it turned out all of their info was incorrect until they finally acknowleged that I needed to buy the entire wheel. I had almost given up that the only solution was to get the entire wheel at a cost of $ 2,200 and that was something that I was not going to do. As an after thought I called my Service Advisor and asked if the button that I broke would be covered under warranty. Today I had my new wheel installed under warranty and am again a 2 button user!!!!
I continue to be impressed with the service that I have received from MB of Sacramento on the 5 cars that I have purchased through them. As an aside I had 2 Lexus during the same time period and their service, shall I say politely say"SUCKED" in comparison.
Old 02-06-2009, 05:19 AM
  #530
W211 BEAST's Avatar
2006 E55 BEAST
I'm not about to read this entire thread...
How much are these? I see that they fit the W211 E class.
And about how long will it take a shop to install them?
Old 02-06-2009, 11:32 AM
  #531
Andy0331's Avatar
'08 CL63
You should probably read the last few pages, if not the entire thread, but I can sum it up for you.
They are not made for the E class. Install times & success appear to be hit & miss.
They look cool, but I will avoid them until proven/tested.
Old 02-07-2009, 04:09 AM
  #532
W211 BEAST's Avatar
2006 E55 BEAST
Thanks Andrew.
I asked because I saw in the quote in post #529 that they fit the W211. These look cool and I think that if you use the paddle shifters at all you need these as apposed to the buttons. But +1 on waiting. I dont want to mess up my car.
Old 02-07-2009, 12:12 PM
  #533
bobgodd's Avatar
2004 E55
Just install the E63 paddle shifters.
Old 03-03-2009, 01:20 AM
  #534
slowrey's Avatar
2006 Mercedes C55 AMG
Too bad a refund wasn't available by Vrus. I bought them and then decided against them and couldn't cancel them even though they weren't shipped yet.
Old 05-06-2010, 12:50 PM
  #535
xpl0sive's Avatar
CLS55 AMG
are these still avaliable? i want to replace the buttons on my wheel in my R171 SLK55
Old 02-10-2012, 12:23 AM
  #536
Etienne Cronje's Avatar
SLK55 & ML270CDI
Hi Guys Is there in body that can forward me contact details of VRUS.
I have a 2005 SLK55 and would realy like to do this conversion.Living in the good old RSA we can not get these aftermarket part easily.Please help
Old 02-10-2012, 11:14 AM
  #537
lkirchner's Avatar
Trust me they do not work and I also think VRUS is no longer in business.
Old 02-10-2012, 05:54 PM
  #538
320 dreamer's Avatar
2003 porsche 996 turbo
i have a buddy who can make the paddles work for the slk55. if theres enough interest he make build some kits. he built a kit to install paddles in my slk32 which never had them. they work flawlessly
Old 03-20-2012, 11:10 PM
  #539
MB2005AMG's Avatar
MB E55 AMG-2005
I would like to have a set as well...
I did not read the whole... I have a 2005 E55 (w211) and I would like to purchase a pair of steering paddle shifters. Was the manufacturing ever completed and is it availble to purchase? I have not seen any photos but based on some of your feedback it is a nice addition and high quality. Please let me know the details to purchase and if you could share some photos it would be great.
Old 03-21-2012, 02:26 AM
  #540
grimm's Avatar
2005 E55, 2002 GT2
You're better off just getting a set of the E63 paddles and swapping in the switch from your OEM buttons. The E63 electronics switch doesn't work with our E's for some reason. A bit of fabrication is required (milling down the ridges in the paddle as well as the plastic retainer and filing/sanding down the PCB that the switches are soldered to). There is a DIY on this board that shows you what you need to do.
It's what I followed to do mine.
Old 03-21-2012, 06:12 AM
  #541
talk to ivan @
dct. my buddy is building a plug and play kit for the swap with no fab work needed
Old 03-21-2012, 09:57 PM
  #542
MB2005AMG's Avatar
MB E55 AMG-2005
Thank you for both of your responses!
GRIMM-Sorry what is a DIY to review the fabrication and how do I get there?
320dreamer- how do I get a hold of Ivan on the kit?
Thanks for your support, I'm new to the forum.
Old 03-22-2012, 02:31 AM
  #543
grimm's Avatar
2005 E55, 2002 GT2
DIY: Do It Yourself
Here are the threads I referenced:
https://mbworld.org/forums/2756226-post12.html
https://mbworld.org/forums/w211-amg/...lled-pics.html
Old 03-22-2012, 06:24 AM
  #544
dctmotorsports a vendor on this forum
Old 03-22-2012, 09:29 PM
  #545
MB2005AMG's Avatar
MB E55 AMG-2005
Fantastic, I can do this!
Old 04-19-2012, 04:10 PM
  #546
maverik259's Avatar
05 C230K SS (sold), 06 C55 (sold), 08 Yamaha R1 (sold), 16 X5M
ya pretty sure they gave up on this awhile ago! it failed several times and eventually vrus just stopped posting so i think its safe to assume he's gone into hiding or has been otherwise detained...
Old 04-27-2012, 05:43 PM
  #547
latemodel21's Avatar
2003 SL55 / 2002 SLK32
Here is some info on the module that allows plug-n-play replacement of the old style buttons with the new AMG aluminum paddles.
You can contact Ivan at sales@dctms.com
or you can send me a PM if you have any questions
Chris
Old 12-26-2012, 12:51 AM
  #548
john0183's Avatar
2003 E500 sport
Hi am interested in a pair also how much would it be for a w211 2003 e500 and would it work without any cutting and is it plug and play please respond thank you.
Old 12-26-2012, 12:30 PM
  #549
maverik259's Avatar
lol please read before posting, this doesn't exist anymore...
Old 12-26-2012, 02:30 PM
  #550
actually it does. chris(latemodel21) has been building kits for ivan at dct motorsports. plug and play . he built me a kit for my slk32 when i had it. he knows what he is doing
You have already rated this thread Rating: Thread Rating: 4 votes, 5.00 average.
Quick Reply: *** Custom Paddle Shifters ***
