Totally bummed with new HRE’s
Tomorrow, I am having new PS2's installed on my BBS LMs. Front and rear wheels have a 32+ offset. Sizes will be 255/35/19s for my 8 1/2, fronts and 285/30/19 on my 9 1/2 rears.
My MB master mechanic thinks............................. it will work!!!
Jangy states............................................ ..it might work???????
Rafal warns............................................. .....it wil rub!!!!
I look at it this way............. the worst case scenario is that someone from MB World gets a hell of a deal on new PS2s. Now, is that all bad?
Let me know. I'm dying to know if my program is right.
Hmmm, I wonder what they will say to the other memeber that has his rears poking out? Two different vendors and HRE wasn't involved? OK. I say you ask HRE to recommend the ideal offset and have it done (not at your expense). HRE has done many of these sizes. Hell, take a look at VIC55s and have them match his offset. These sizes have been out for years. I find it hard to belive that a vendor gave them bad numbers and they didn't question it?
You might be right. The barrel change alone might not fix it but perhaps a combination of the barrel change, tire brand/size change, and (hate to say it) but rolling the fenders might make it work. I know some of you are hesitant to roll the fenders but it is really a painless process if done correctly.
The reason I bring up the tire brand is because of the difference in sidewalls and variations in width between brands. Notice the difference in sidewall structure between your tires (on the right) and the T1R's.
I take your word for it but they dont look to be that bad?
The centers are what needs changed if you have to run that size tire and brand.If not as some have said,a tire brand change might be what you need.Worse case deal,you might be able to shave the rotors 1-2mm and the wheel 1-2mm.Not the best way and i cant say if its positively safe or not.1-2mm might not be too harsh though.
No I’m not telling you the location of my local dumpster…But I sure as hell am frustrated.
2) The fronts do not rub
3) Several people have 285/30 on 19's w/out rubbing
even though they were made specifically for a C32....
think i'm going to switch to Toyo's or Falken's
What color are your HREs now? Post some pictures.
I ordered 843R's for my 65 thru a vendor because of the deal I wanted and HRE made them to the vendor's request even though I found out later HRE told them it may rub. The wheels came in as requested with the specified offsets. The wheels rubbed and I had to make some fender mods. Even though I wanted HRE to make the adjustments for free it wasnt their fault.
If HRE made the offsets wrong versus your vendors request then they need to fix them. But now you have painted them and had the dealer shave the back pads? Too many parties involved it might seem? I feel for you Greg as all you wanted was a nice set of wheels.
My dealer told me he ordered wheels to fit an E63. Assuming HRE knew the wheels were going on an E class Mercedes, aren’t they at fault? I’m sure they have made hundreds of sets of wheels for the W211 E class (and they should know what fits and what doesn’t fit). As I said, I don’t think that 275s would have fit, although they will probably fit now. Funny I went to Cars & Coffee today and there is a guy with 295/25/20 on 10.5 inch wheels on a lowered E class (no rubbing on his car).
It wasn’t my suggestion to have the wheels shaved. It was the dealer who told me he could make them fit by shaving them 5mm. Because of the 5mm shave I have a bigger problem. Now I don’t think HRE can fix the wheels. Before they were shaved, HRE could have changed the barrels to a 3” outer and 7” inner. I don’t think that will work now as there isn’t 1/2 inch between the wheels and the calipers.
Your right all I wanted was a nice set of wheels.
I think you are correct that now due to back pad shaving you have an issue with them getting fixed. I just ordered new faces for my 65 with a little less aggressive back pad so the rubbing will go away. HRE was willing to work with me but I still have to pay because my retailer turned in the specs (I have worked a deal with him to compensate for my costs of the re-do). I know I went for an aggressive set up and once it didnt work I figured I better just have HRE fix it.
Sorry for your troubles, it just sucks.
