20s VS 18s at the drag strip
06 EuroElites E55
hopefully rogerv calls me this next week for a run at sac. if he does i will leave on my 20s to get some numbers then on june 2nd when we run again i will have my stock 18s with DRs on. should be intresting to see the difference. on that note i need to get some DRs what size and brand do you guys recomend? and do you leave the stock conties on front? thanks for your time.
2003 E55 & 2014 GL550
Noticed that nobody replied.
I would just go with the standard BF Goodrich TA Drag Radials.
275/35/18 will slip right on stock rims.
You will FREAK at the difference. It really is incredible.
MAKE SURE you get Drag Radials and not Drag Radial 2's.
Luke at Tirerack usually keeps them in stock for us
Pic of what you need below.
![](http://www.tirerack.com/images/tires/bfg/bf_gforce_drag.jpg)
Drag Radial 2 below
Drag Radial 2 below
![](http://www.tirerack.com/images/tires/bfg/bfg_gfc_drg_rdl2_ci2_l.jpg)
06 EuroElites E55
**** it, drag with the 20s and ball in style style. I can bet u that ur e55 w/ 20s will look sicker than all ALLcars...
I just picked up a set of 20" HRE 840 3 Piece wheels and the car feels way faster and responsive. No seriously i bull **** you not. 20s vs 18s and the 20s are still lighter....
I was previously on a set of oem 18s with ps2s and a 275 rear, the ps2s were hands down the best tire i had ever sat on. They were really just beyond what i thought was possible. Ice cold tire, wot and you had minimal traction problems on a warm day. I love em.
My new tires are 20" Pzero Nero now and they are alot softer, however the grip is not there vs the ps2s....
![action](https://mbworld.org/forums/images/smilies/action1.gif)
06 EuroElites E55
thats all im tryin to do give a lil data about each size! if my 20s are close to the 18s (.3) or less im keepin the 20s if the 18s are faster by more than .3 im gettin a set of 18" renntech moonlights.
06 EuroElites E55
2015 S212
I wouldn't use straightline to decide on wheels. If you like the looks of the 20s, then just decide if you like the drive and handling. Who gives a rat's nut if it is really .3 quiker or slower in a straight, if you love it? Oh wait, I would...but .3 is quite a bit and I dunno what 20s do to that. What is your overall rolling diameter? That will tell you how far off the gearing is, then the only thing left is the centrifugal force differences in different rim diameters.
