••• Project Stock to Awe •••
#304
Can you please elaborate? Which part of the diff was chewed up? The weakest link I have found in my car is the axles but I already have a quaife in the diff. Did you shear the main gear in the diff? You should definitely get a quaife in that bad boy if you haven't already
#305
MBWorld Founder
ones too fast according to CHP!
#306
MBWorld Founder
We sent Finny a stocker that we had on the shelf.
We have the quaife that we offer currently and two new options coming in the new year.
Brad
Brad
#309
Ran into a few complications where all the problems were solved. Just waiting on some custom engineered parts being made.
I have plenty to share so when the Diff is done I'll post it all up with plenty of pics.
Pending Posts:
• Diff mod and info for 02-03 w211's.
• Cheep do it your self EPC, DAS & WIS system.
• Rear camber kit install.
• Bypass valve investigation.
• Quarter and Dyno data.
Cheers!
Finny
Pending Posts:
Cheers!
Finny
#310
MBWorld Founder
Pending Posts:
Cheers!
Finny
Pending Posts:
Cheers!
Finny
thanks
Brad
#311
Pending Posts:
Cheers!
Finny
Pending Posts:
Cheers!
Finny
#313
![Thumbs up](https://mbworld.org/forums/images/icons/icon14.gif)
My single spinner rear end finally gave in under the extra HP injection. I had a Quafe on stand by but didn't get around to changing it over until self destruction of the old unit.
Anyway after removing the stock Diff I then realized it was an inferior model as I had an 02 build which came with a weaker design compared to the newer 30 spline version. MB changed the Diff spec some time in 03 I believe but not to sure when.
After inspecting the old unit there was no recoverable parts so I found a good unit on Ebay from Evosport. Thanks fellers!
So what's the big deal here?... the old Diff uses a 27 spline two piece axel and the new version uses a 31 spline one piece design. The MB stealers wanted to rob me for a set of one piece types so I decided to make up a set of adapters that would fit the old axels with 30 splines. See the following photos.
![-_mgl9278.jpg](https://mbworld.org/forums/attachments/w211-amg/407449d1542334725t-ooo-project-stock-awe-ooo-_mgl9278.jpg)
Out it comes... Notice the the two piece design.
![-_mgl9280.jpg](https://mbworld.org/forums/attachments/w211-amg/407450d1542334725t-ooo-project-stock-awe-ooo-_mgl9280.jpg)
Oh! What's in here? A few lose bits from the free wheeling carrier.
![-_mgl9291.jpg](https://mbworld.org/forums/attachments/w211-amg/407451d1542334725t-ooo-project-stock-awe-ooo-_mgl9291.jpg)
Crunch! a missing tooth.
![-_mgl9287.jpg](https://mbworld.org/forums/attachments/w211-amg/407452d1542334725t-ooo-project-stock-awe-ooo-_mgl9287.jpg)
The centre pin slowly chewed its way through by a shearing motion.
![-_mgl9282.jpg](https://mbworld.org/forums/attachments/w211-amg/407453d1542334725t-ooo-project-stock-awe-ooo-_mgl9282.jpg)
Part of the carrier gear not looking to healthy.
![-_mgl9276.jpg](https://mbworld.org/forums/attachments/w211-amg/407454d1542334725t-ooo-project-stock-awe-ooo-_mgl9276.jpg)
Quafe awaiting a new home.
![-_mgl0980.jpg](https://mbworld.org/forums/attachments/w211-amg/407455d1542334725t-ooo-project-stock-awe-ooo-_mgl0980.jpg)
The old 27 spline axel with chew marks on the shaft. This was forged and then rough machined. The spline was rolled then flame hardened from very mild steel. It's done this way for efficient mass production reasons which suites the spec.
![-mgl0952.jpg](https://mbworld.org/forums/attachments/w211-amg/407456d1542334725t-ooo-project-stock-awe-ooo-mgl0952.jpg)
The local engineer cutting away.
![-_mgl0981.jpg](https://mbworld.org/forums/attachments/w211-amg/407457d1542334725t-ooo-project-stock-awe-ooo-_mgl0981.jpg)
This spline was tool cut then induction hardened from 4130 billet steel. The old axels will twist off before this fails.
![-_mgl0978.jpg](https://mbworld.org/forums/attachments/w211-amg/407458d1542334725t-ooo-project-stock-awe-ooo-_mgl0978.jpg)
Stock on the right. Longer spline and 2mm thicker on the left.
![-_mgl0979.jpg](https://mbworld.org/forums/attachments/w211-amg/407459d1542334725t-ooo-project-stock-awe-ooo-_mgl0979.jpg)
The left axel has more meat in the flange area as well.
![-_mgl0985.jpg](https://mbworld.org/forums/attachments/w211-amg/407460d1542334725t-ooo-project-stock-awe-ooo-_mgl0985.jpg)
All ready for transplant. Lets see if the axels hold up...
#314
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
Sweet!
Go Finny, I don't recall ever seeing a carrier shaft dance completely out.
In defense of your old 3rd member was it not twisted out of the car once?
Nice flanges, FWIW I understand AMG offers a Euro axle that is stronger.
#315
none
Finny, Very impressed. I love the "from A to B" format that you follow. Great R&D on your end. If you don't mind me asking do you work in a tech/engineering field of something similar or are you just a die hard fan? You've taken a much better approach to creating some of these parts than 90% of the "mercedes tuners" that offer their own parts. So very delighted to see your posting again.
How much longer did you make the spline?
What apple program did you use to autocad the SLRintercooler trial piece?
Awesome
Awesome
#316
NICE!!!!! Love the conversion part, very nicely done
#321
1 Post
'10 Panamera S, '06 AMG CLS55, '07 Miata MX5, '02 MB SPRINTER, '99 Spec Miata Race Car (2X)
As always Finny - great respect. Wish you well on this journey that have been taking us. We wait with bated breath for your next post!
#322
DAS for the masses...
I picked up a couple of old DAS units from an Auction a few years ago and when I tried to upgrade the software recently to the newest version it all hit the fan!!!... so after many nights trying to hack the system I finally conceded defeat, all was to hard. After doing some goggling I found this guy in the UK who seemed to know a bit about the software where I then contacted him and explained all the problems. Unknown to me, Merc placed a license time bomb in the updates which locks out the Multiplexer and all Applications... pack of you know what's!!!
You may argue that if idiots get hold of a powerful diagnostic solution they may injure and or kill themselves or someone else indirectly... IMO only... anyone with basic tech skills should have access to their cars computer to do whatever they like and most people who don't understand wouldn't invest anyway... So I'm going to tell you how you can acquire your own diagnostics system for cheep...
Anyway, I chatted with John Coupland from http://www.jcrecordings.com who is an absolute gentleman and DAS gun! Paid him a few bux and he sent me all the latest up dates, video instructions and developer access to DAS etc... to get my system up and running. Even the Mux was cracked! This bloke is a DAS guru.
So you want to know what's going on under the 55 skin for cheep? Do this...
(1) Buy a cheap IBM laptop, not sure what model but if you check Ebay you will see dealers selling them for 20x the price with the Mux and DAS software which is full of bugs. Just get the model number and buy it as a generic machine from a normal computer dealer.![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
(2) Look up on Ebay or wherever and find a copy MUX (Multiplexer) with a RS232 serial interface and all the cables & crap. There are plenty around as China clones them by the hundreds if not K's. Going very cheep these days.![Big Grin](https://mbworld.org/forums/images/smilies/biggrin.gif)
(3) Go to http://www.jcrecordings.com and buy all of Johns stuff. Tell him Finny sent you and he may do you a better deal if you order a heap of data. Very fair prices though. He sells the whole HD with everything pre installed as well so you just stuff it into the Laptop and your away.![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
(4) If you feel morally obligated to give Finny funds because he's a good lad and saved you a heap of cash just give it to John or charity... Also bare in mind, if you have any problems with your system John will solve "any" problems you encounter, remember the Guru of DAS, WIS and EPC.![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
Now do your own 10 degree mod and service!
![-wis_das.jpg](https://mbworld.org/forums/attachments/w211-amg/147212d1542222114t-ooo-project-stock-awe-ooo-wis_das.jpg)
Yes, when I used slicks the extra traction stressed the Diff carriage assembly mounting bolts which are designed to sheer off after impact for safety reasons. This can be real Dangerous when using slicks. Just remember to check the nut end of the mounting pads by removing the rear wheels and grommets that cover the area. Look for micro stress fractures and or large ring like cracks.
Thanks, I like to get straight to the point and explain it as simple as possible. I speak less and let the images do most the talking. I like science and tech in general and have broad mechanical knowledge which I like to apply to the 55. Love the technical challenge and just enjoy the culture.
I had the machinist match it to the Quafe centre. Plenty of meat there.
Modo 3d for the Mac. Powerful 3d tools which are surprisingly easy to use. Sharp learning curve but worth it as you can design anything thing you like easily. Now with 3d printers available we have desktop prototyping![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
I did, there hanging under the car without the mini axels. No, I didn't count the hub splines but that will probably self destruct next. Thanks for reminding me... Ha Ha... ![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
More $h!te happened after the diff was installed... a bolt came loose in the tranz pump which chewed the pulse ring of the K1 clutch housing which is responsible for detecting the final output speed of the tranz. New one ordered and I'll stick it in soon... Lucky the damage was minimal though... After the tranz repair... DYNO!!! and 1/4 time!!! with stock cooler.
Awesome![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
Awesome
#323
great job Finny....great to read your awesome posts.
So what was the solution to the SLRcooler Map and TEmp sensors?? are you using just the single original sensor that came with the car or have you somehow been able to fit dual sensors into the stock harness?
#324
This is better than ****! I love this thread! Finny, you are doing what I wish I could do: Tear into an AMG! I'm betting you will have the sickest 55 on this board when it's all done.
