••• Project Stock to Awe •••
#128
Lets all go where the Sun don't shine...
Yes... Mmmmm what's in here... Being curious I couldn't resist. I actually rebuilt the Tranz a couple of months ago and since some parts for the engine haven't turned up yet and also to keep the thread fresh for thoes who like to watch, I'll post up some shots of the Tranz rebuild.
With the help of my mate looking over my shoulder who just happens to work at a stealership rebuilding these MB boxes for years guided me through the disassembly and identification of all common trouble spots.
Deano, one of my mates, said this box has the same internals as the ones from the SL65 including identical part numbers to all the clutch assemblies as he has rebuilt many of both types. The main problem with these boxes is when the finally assembly is done at the MB assemble line "almost all the clutch pack tolerances are out of wack to factory specifications" where he cannot recall when one was perfect... So what's the big deal about these tolerances? Basically if it's to loose it will slip... simple as that. The tolerances are critical if your throwing a lot of **** as these like we do, probably not as critical for stock applications.
When all the clutch packs are reassembled, their final compressed hight varies due to manufacturing tolerances of the actual clutch media. So... when compressed with a special tool in a press at the correct poundage, a measurement is then taken off all the clutch plates and clutches. The final spacer ring part number depends on the measurement taken which corresponds to the correct part listed as there are a few, -1, 0-1, +1 etc.... The part is then added to the pack and is ready to go.
The E55, SL65, SLR and Maybach all use the same box. Of course some of the internal part numbers are different but not many. Final ratios and programing seem to be very different.
I will be investigating the valve bodie shortly with another one of my mates who owns a large Auto Tranz shop which is equipped with a real time valve bodie tester that shows all the in's and out pressures whilst changing gears There is also a Tranz dyno among other goodies to play with.
My mate Johnny rebuilt and modified the 55 converter by removing the "two paper lock up clutches" and refitting 3 carbon fiber ones. He discovered that they were excessively worn and braking up. It was most likely due to Vmax runs but it's also a common problem which makes the car shake at certain revs.
I have all the spec documentation from MB if any one is interested in a copy. The files are in .jpg & .pdf formats. Where can I post them?
So here are the shots...
The Victim.
Deano removing the oil pump.
Pan and filter off.
Part of the Tranz brain... Valve Bodie with modulator valves sticking up.
Brainless.
Position for disassembly.
Pop the top off.
Clutch packs and drive shafts removed.
Notice thrust bearings.
Ant farm network of hydraulics plumbed through here on the back of the bell housing.
When you put it in park... guess what?... a pin grabs this wheel.
Notice the slots which the first clutch packs slide into.
The metal rings here, not the actual clutch media are slightly bowed inwards due to excessive heat build up caused by clutch slippage. You cant notice this without a straight edge. Visually they were a blueish heat stained color. The problem is further perpetuated by causing less contact area as the clutch media stays flat. These were all replaced.
All packs rebuilt properly ready for assembly.
Clutch pack and piston assembly.
Another set.
Stacked and ready. All clutch media is soaked in fluid over night before assembly.
Bolted on with oil pump underneath.
Clutch and final drive shaft added.
Another bit put on???
The Victim.
Pan and filter off.
Brainless.
Pop the top off.
Another set.
#130
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
Again Fantastic pics, Finny this is the transmission that spun your differential out of its mounts? And after its pampered life, all you found to replace was some warped clutches? amazing
Dam that used transmission fluid looks like chocolate.
Thanks,
Thanks,
#131
That thing is friggin bullet proof...!
One brave and very knowledgable soul prepared to pull an auto box apart ...
Finny are you trying to qualify as an MB tech or something or complete a degree in Mech Eng ?????!!!!!
#135
Not to mention water also leaked into the box via a faulty radiator which has since been bypassed hence the chocolate colored fluid.
I made up a remote Tranz cooler with an electronic thermostat to activate a fan bolted to the cooler tucked under where the smog pump once lived.
All is now cool...
#137
Rejoice! Heads are back!
Just got the heads back today from Eddie Woods and these look real cool.
I first noticed the dimpled texture in the tubes and chambers... weird hey? cause I like the shiny polished finish... I asked Eddie what's the story here? He said this is a soft finish which prevents "Laminar adhesion" and enhances mixing... So what's that in english? Laminar adhesion is where fuel or liquid sticks to the inlet walls and accumulates, apparently not good for S/C applications. This soft finish also enhances air & fuel mixing which helps burn propagation. Yeah right... Well good I'm happy if it all works!
The valve department was interesting too. I wanted the no expense speared whiz bang Titanium jobs! Eddie said these aren't very good in street Turbo or S/C applications because of the extra heat generated can prematurely damage Titanium valves. He said the Titanium jobs were great for N/A high reving apps. So he custom made a valve set from 214n Stainless Steel which was sent off for hardening. An extra 1mm was added to the inlet and 0.5 mm diameter to the exhaust set.
The supercharger manifold was port matched and got the same job as above.
He didn't bother changing the springs as they all tested well and were suitable for the rev range required.
Next post, assembly.
Stat data 1
Stat data 1
Inlet side.
Finished chamber 1.
Finished chamber 2.
Inlets.
Exhaust 1.
Exhaust 2.
Profile 1.
Profile 2.
S/C 1.
S/C 2.
S/C 3.
S/C 4.
Stat data 1
Stat data 1
Inlet side.
Finished chamber 1.
Finished chamber 2.
Inlets.
Exhaust 1.
Exhaust 2.
Profile 1.
Profile 2.
S/C 1.
S/C 2.
S/C 3.
S/C 4.
#138
Out Of Control!
Another props to you Finny! Are you sure you're not an ex AMG technician?
How long did it take you to pull that trans apart and put it back together? That's just crazy! But gotta love it! Kudos my friend!
#140
Looks great to me, Oh what next SLR cams or a Finny special grind? Man you are ready for your gasket kit
So what's that in english? Laminar adhesion, ya static boundary layer, it works.
I vote this thread should be a sticky how about it Mr. Vanos, Vic55, vraa, drexappeal, RBrenton
#142
Screwing my heads back on...
Dean dose these things quicker but I slowed him down as I was under instruction... Ha Ha...
Here's a few shots of the heads & bump sticks being installed.
After cleaning the adjoining surfaces the so called OEM Merc gaskets are actually Cometic Multi-Layer Steel (MLS) head gaskets which go on dry because they are coated with a sealant. Each MLS gasket is coated with a .001" thick of viton rubber that is bonded to the outer stainless steel layers. No Re-torque is required with these hi techo gaskets. One of my mates use these on a 32psi turbo car with no worries at all. Apparently these are as good as "O" ringing or better which surprises me.
According to WIS we must put some goo here.
Bolted and torqued to the correct sequence.
Next Victim!
Done.
Now ready for the SLR bump sticks.
This is a MB cam locking tool which prevents the cam rotating which holds it the correct timing position with cylinder 1 up at 40.º
This tool is bolted on with the cam before the over head assembly is installed.
Right bank first.
Ready to rocker... Note cam tools still in place.
Rocker arms installed.
Just being sure to be sure. After an hour or so I couldn't work out why the timing was out of whack??? Duh!!! I was using the E55 timing specs not the SLR's !!! All checked out fine then...Duh????...
All done and ready for the next stage.
To be continued.....
#145
What valve springs did you use? Do you happen to have the part number for them??
#149
