Putting our gearheads to the test...what's wrong with this picture?
Old May 3, 2007 | 03:15 PM
Jakpro1's Avatar
2003 E55 & 2014 GL550
Actually what's different about this picture?? Meaning anything strike you as odd??
Besides that it's an E63 with the top end ripped off due to a valve failure.
Old May 3, 2007 | 03:27 PM
MikeF's Avatar
03 C32 | 72 Porsche 914
the top bank looks bone dry and burnt.
without a better picture I can't tell anymore.
Old May 3, 2007 | 03:31 PM
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
spalling
Old May 3, 2007 | 04:32 PM
Jakpro1's Avatar
Answer: Check out the timing chain. Makes NO connection with the cams at all. In fact, entire valve train popped right off with timing chain and gear still in place.
To quote my mechanic, "There's a whole lotta voodoo going on in there" referring to valve timing etc...
I guess as an old time mechanic, just never had seen that before.
AMG.....
Old May 3, 2007 | 04:40 PM
Finny's Avatar
03 E55 AMG
To me, it appears the top cam has failed due to lack of oil to the lobe or maybe component fatigue due to a faulty part batch... ??? Low oil level ???
Old May 3, 2007 | 04:59 PM
mclarenm8d's Avatar
2003 CL55 Kompressor Horizon Blue Metallic
AMG.....
That's pretty cool ... I was wondering what the advantages might be, off hand less chain weight, and more accurate timing (??). Could you see how they get the drive/gear unit in there?
Old May 3, 2007 | 05:30 PM
The center section with chain and gear is the actuator for the variable valve timing. And that is not what is odd. Oil problem here that is what is odd.
Old May 3, 2007 | 06:50 PM
JamE55's Avatar
Out Of Control!
I was going to say there is no oil on the upper bank but i figured the engine is just tilted and that's why all of the oil is on the bottom. I've never seen that about the timing chain making no connection. Very interesting.
Old May 3, 2007 | 10:18 PM
ScottCLS55's Avatar
Lexus
Wow, I guess it is driven by that gear. Much easier to change cams! I wonder if the engine has and whining noise from the gear driven cams?
THe oil is damn dirty for a 63 also, how many miles??
Is this car in for the timing chain tensioner recall?? or was it really a valve failure?
Old May 3, 2007 | 10:28 PM
DFW01E55's Avatar
'14 ML BT
The timing chain was my first thought and then I looked at it again and thought, "the chain is tight and straight ... must be something else."
That chain looks perfect except there's an uncovered sprocket next to it.
Old May 3, 2007 | 11:17 PM
Bluemax's Avatar
15 S550 Daily 96 Dodge Viper GTS
Cool
Look at the top bank lifter buckets completely gone. Were did all that metal go
If that was my car they would be replacing the whole motor
Old May 4, 2007 | 09:25 AM
Finny's Avatar
03 E55 AMG
Thumbs up Detailed Shots
This may help us at understanding what's going on here.
Old May 4, 2007 | 04:45 PM
Finny's Avatar
03 E55 AMG
Just another observation...
Notice that the damage is localized to the right top inlet valve tappets. This would obviously rule out cam failure. The left hand tappets appear fine as well ruling out metal fatigue on these bits too.
So it appears to be loss of oil to the damaged regions. My 2 cents.
Old May 4, 2007 | 05:03 PM
Jakpro1's Avatar
Had some requests for any other pics of the mighty E63 innards.
Only other 2 that I have...bucket tappets looked cool as hell BTW
On the cam thing....guess it was just cool that the chain stayed intact....chaulk me up one on the ownage scale I guess.
Old May 4, 2007 | 05:27 PM
rflow306's Avatar
2005 E 55
Correct Vanos. It could be that the picture was taken way after dis-assembly and the head has good drain back properties, hard to tell from the picture.
Old May 4, 2007 | 05:44 PM
Finny's Avatar
03 E55 AMG
These shots tell a different story... Mmmm Looks OK here..
