Engineers Menu + engine check light
Old May 10, 2007 | 09:00 AM
TheDon's Avatar
2003 E320 CDi
Good afternoon All,
Can i ask if anybody knows how to get into the "engineers menu" on a 2002
E55 ? I've searched the forums and tried the Mute+Call end+serv and also the 3+5+7 trick with no luck.
Also after trying these codes my engine check light has illuminated itself (Cheeky Monkey) !!
I dont know if it's related cuz I'm Not getting any errors on the fault code screen and the car seems to run fine ???
Have i done something wrong trying to get into the engineers menu to cause the engine check light to illuminate ?
Old May 10, 2007 | 01:16 PM
TheDon's Avatar
2003 E320 CDi
Mmmmmm...
Not sure about this...
It says on the nav cd (CD not DVD) Audio 50 APS ??
Heres some pics of my comand unit.
Can anybody tell what command unit i have from these pics ?
Thanks 4 ya 'elp.
Old May 13, 2007 | 02:26 AM
OzE55's Avatar
2003 E55
I'm no expert, but I would doubt that the 3-5-7 thing for a w211 would work in a w210 (you did say 2002). The change in electroincs between the two models was probably substantial.
What did you find when you tried the 3-5-7?
Old May 13, 2007 | 05:56 AM
Efivefive's Avatar
E55 AMG
Originally Posted by TheDon
Mmmmmm...
Thanks 4 ya 'elp.
Attachment 104940
Attachment 104941
That is definitely a w211 console, they appeared in 2002 in the UK. The 3-5-7trick won't work as you have an aps50 nav unit and not the dvd nav unit.
Don't quote me, but your car probably has the MB gateway already wired in, so you could change up to the dvd nav unit????....this would enable you to install tv and play dvd's straight from the head unit.
What is it you would like to change in the engineers menu????
Old May 13, 2007 | 06:28 AM
TheDon's Avatar
2003 E320 CDi
Thanks for all the info.....i need to get a comand APS then by the looks of it.
Anybody know which model i need.
I've seen some on ebay but not sure what model to get.
As for your question EfiveFive....i wanted to enable playing of MP3 but looks like i cant do that know. MB quoted me £2000 for a comand unit, FITTED !
By the way, the engine light issue.......took my car to MB friday morning. Got it back friday afternooon....the Oil Level Sensor has gone and the Air Pump and relay have gone. Its going in next week
Heres a cpl of pics 4 ya...no david bellamy though :-).
Attached Thumbnails Engineers Menu + engine check light-dscf00675-640x427-.jpg   Engineers Menu + engine check light-dscf00664-640x427-.jpg   Engineers Menu + engine check light-dscf00653-640x427-.jpg
