PTE T-Stat Updates (Long)
Old 05-28-2007, 08:44 AM
E55 RUSS's Avatar
E55K
Originally Posted by dsc
I had PTE stat in and sure enough it worked GREAT, to great. I noticed my temp being a little below 80 C on the dash. I started monitoring it via the climate control method (precise numbers) When it was even up to 74F outside my engine would not get up to 80C when I was on the highway for 40 minutes. It would only get above 80C at 74F outside temp in stop and go traffic. As soon as I started cruising it would drop below 80C and stay between 76 & 78C. So it always ran in start up rich mode. I think the 16-F stat is perfect for hot weather and when it's hot at night.
I had to put the stock stat back in to get met engine to proper operating temp. I agree I would love to get the stat in a 175F style not the 160F. I have K2 so I never had a CEL.
So you say that your car with PTE 160 Stat is not good for places where climate is not too hot cause the car would saty is rich mode and loose power cuase of it ???
Old 05-28-2007, 11:15 AM
dsc
dsc's Avatar
2004 E55
Surprisingly, Yes. The thermostat is great. I also must say I think my car tends to run cooler than most. Conversely, Victors car seems to run hotter than most. I think for my car a 175F thermostat would be ideal. I would like to see the temperature stay at 80C to 85C.
Old 05-28-2007, 11:27 AM
E55 RUSS's Avatar
E55K
OK...then I dont need one...
Old 05-28-2007, 04:56 PM
PDC
PDC's Avatar
2006 SL65 ///AMG - GONE BUT NOT FORGOTTEN: 2005 E55; 2002 ML55; 2001 CLK55; 1992 BMW 850i; 1991 M5
K1 / K2 ECU Flash
I got the K1 flash AFTER returning to my "Stock" t-stat. Would the K1 flash 'prevent' the CELs that I kept seeing running the PTE stat with the 'factory' ECU settings???
Old 05-28-2007, 08:27 PM
dsc
dsc's Avatar
2004 E55
I really don't know.
Old 05-28-2007, 08:31 PM
dragonAMG's Avatar
12' C63 P31, 06' Supercharged Range, 08' BMW 550i
I have the PTE Tstat and Kleemann K3 ECU tune (w/ the -10c mod) with no issues.
Old 05-29-2007, 10:40 AM
  #32
viper04's Avatar
+1
I also have the PTE Tstat, with the -10c Mod, and I have never had a Cel. The car sit more that it's driven and in the winter I have even taken it out for a spin in ( Wisconsin Winter) Cold as Hell, and no Cel at all. Maybe some cars like it and some don't.
Old 05-31-2007, 12:04 PM
  #33
PDC
PDC's Avatar
Makin' Progress!
We may be making some progress here. I spoke with Patrick just the other day - what a true class act and what a WEALTH of technical knowledge. It sounds like in cold temps, and I'm sorry that I do not know the ecaxt degree - our cars will automatically engage the climate control system at 78* interior temp. If the coolant that flows through the heater core does not reach that temp within a certain number of minutes - and again I do not know the magic number - and this delayed warm up cycle repeats itself a certain number of times (I think 6) the car will throw the CEL for "Thermostat Below Threshold"
SO ... it stands to reason that if you turn you HVAC system completely OFF before you turn your car off such that it stays off when you cycle up on a cold morning and leave the HVAC OFF until the temp gauge reached the appropriate level, maybe that would prevent the CEL??? Just a thought for those of you with the modified stat to see if it helps!
Still talking with Patrick about other options as well - more later.
Old 05-31-2007, 12:09 PM
  #34
dsc
dsc's Avatar
2004 E55
Pat is reworking my thermostat, no charge. He is a wealth of info and a super guy. Can't wait to try it. I'm hoping this will give me the cooler engine while making it to normal operating temp. Thanks, Pat!
Old 05-31-2007, 01:07 PM
  #35
jason427's Avatar
Viper/Z06/E55/GT500
Ive had mine for a week or so. Running fine here in FL.
Old 05-31-2007, 01:36 PM
  #36
E55 RUSS's Avatar
E55K
Eventhoiugh I had problems if receiveing a IAT for almost a year, cause of the stupid POST office, Patrick told ME once he receive my old Stat which never arrived to my hands, it was sent back to US, he will send a modified version for our colder climate...
Quick Reply: PTE T-Stat Updates (Long)
