Torque management + Dyno mode q's
Former Vendor of MBWorld
W211 E55
Has anyone been able to ascertain if the torque management is attenuated or disabled in Dyno mode?
Power-braking these cars nets the same 60' as an off-idle launch, and this should not be the case.
Has anyone attempted to disable the brake pedal input to the ECU to fool it into thinking that it's not being depressed?
Maybe taking out a brake-light fuse or removal of ABS relay would do the trick.........
Comments?
Comments?
Comments?
Comments?
........I don't know the answer to the question. So why am I responding. I just wanted to add that it is indeed true that just stomping on the gas from the second yellow light yeilds the same 60ft time as power braking. I am sure this is not the case all the time, but I'll implore people to try it. It doesn't make sense, but I have noticed this.
ted
ted
ted
Comments?
Comments?
Have you run in DYNO mode? This disables abs, esp,
but uh yeah launching at a rpm above 1200 seems to do nothing. I agree best 60 ft times are right off idle
What is that TRUE ??? Why you did tell that before...I always power brake at 1200-1500 at launch in 1/4 after burn out...May be doing burn out also make ECU to cut POWER
07 SL550 / 07 E63 AMG
I've found that if you load these cars too high it will just slow the 60ft down, but if you modulate the throttle between idle and around 1500 RPM it works pretty well better than just pushing the throttle from the second yellow light. Make sure the RPM climbes to 1500 JUST as your lifting off the brake. I think the reason for this poor 60ft may have something to do with vaccuum.
So...I dont hold the RPMS at let say 1200 or 1500...I need them to go up and down ??? or I dont play with them at all, jush mush the pedal at the light...
Albert...you never replied to my last PM...I was waiting for info from you
