Should I be able to peel out at will ?
Trying to figure out if I have a pump problem. It feels like I have a lot of power. But driving around the neighborhood I can't peel out at various stops...but enough power to fishtail it. I have RA1s and it's hot out.???
I can peel out whenever i want to...although it is not that often
2005 E55, Renntech Pulley, ECU
You definitely have a problem. Most likely a failing pump. You should be able to shred the tires with no effort (assuming traction control is off). You out to have enough torque and power off idle to scare you, or something is wrong.
Mine gradually lost power until it became extremely obvious that I had no power. Yes, the pump. Fixed and I now am back to having incredible power at all RPMS, able to light up the tires at will. If your car isn't producing enough power to scare you, take her in
Skeeter
Skeeter
'04 E55
My First post and its a question would you believe....!!!!
But whats peeling out?
From standing start I can never pull away without screeching all over the place!!!
04 E55
Haven't heard that term in 20 years !! But it used to mean spinning the tires and burning rubber from a stop...but if he is fishtailing and not peeling out I'm not sure exactly what it means.
2003 CL55 Kompressor Horizon Blue Metallic
1.
The post about torque management: https://mbworld.org/forums/w211-amg/195306-torque-management-dyno-mode-q-s.html
I'm convinced that the ECU in my CL55 will override if one tries to floor it from a dead stop. It's as if it predicts that my torque demand is greater than what the tires can handle. But then if I only let it roll about a foot and jump on the throttle only part way it will light the tires up (even with ESP on). Half throttle is probably where they are getting roasted.
2. Your intercooler pump might be bad.
3. If your lock-up torque convertor is sticking, these cars won't light up the tires (even with 500+ of torque). Voice of experience on that one. If the car starts to buck and stall when you come to a stop, the lock-up is screwing up.
4. Somewhat related to 3, the torque convertor lock-up is more aggressive in manual (M) mode than sport (S). So, it is easier to roast the tires in S than it is in M. In M, the lock-up can begin to happen before you get the full benefit of the torque multiplication at the stall speed.
'06 E55, '05 SLK55, a few others
From a dead stop and ESP off, I've had to get out of it before I ended up into a curb, and I do know how to drive to keep it straight. If you don't have traction problems with ESP off, all is not well.
Four things -
1.
The post about torque management: https://mbworld.org/forums/showthread.php?t=195306
1.
I think it's 1. above in my case and had that very thought last night. I tested it briefly this a.m. by moderately depressing the pedal and it ripped one off. I'm going to keep testing that to see if it fails as an explanation. I also have the sprintbooster which could be a factor combined with 1. Plenty of power from the roll; it was just flooring it from a stop that it acted like it was in 2nd
Former Vendor of MBWorld
W211 E55
2015 S212
I agree. it is a 5 minute install. I'm running R rated 295s now, and I still have to be cognizant of the take off. It doesn't spin out nearly as bad as with the stock tires, but it will definitely smoke them if all you do is flat out floor it. Oh yeah, I also have a sprint booster and I'm still killing the tires.
08 S65, 06 M3 CS(stick), 02 BMW X5 4.6iS, 07 R1 Raven, 08 F-450 4x4, 08 CooperS JCW
Fishtailing is when the back end "wiggles" but the car does not complete a full revolution like with a donut.
My car is a peel out monster with stick and the ability to turn off the electronic nannies.. Overcome the ESP and 516lb/ft will make a bonfire.
Took it in to RBM and I must have said "intercooler water pump" 10 times to make sure they got the message. They found some codes and now they're replacing, whew !
Service adviser said no customer has reported too little power to him before for these cars, and I said well I like to turn off the ESP once in a while.
'Course I ran over the sprintbooster I left on the garage floor like a bonehead but I'm not sure I was going to reinstall anywat
