Dyno Mode: Any problems using full time?
Old 06-07-2007, 01:38 AM
TonyJ89117's Avatar
997C2S
Hey guys,
I am switching my car to dyno mode and was curious if there were any serious issues with leaving it in that setting all the time? I understand that ESP and ABS will be turned off, which is a plus to me. Does dyno mode disable any other features?
Personally, I can't stand how quickly the ESP back comes on in corners even after switching it off. Is there another method of fully defeating ESP without putting the car in dyno mode?
Thanks in advance
Tony
Old 06-07-2007, 02:00 AM
lbE55's Avatar
2004 E55 Evosport I & II; VRP H/E
I think that I read somewhere that the air bags are disabled.
Old 06-07-2007, 02:50 AM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
i've heard enough stories and verified it myself that the tranny will go into it's own limp mode if you run in dyno mode for long periods. basically the tranny locks itself into a gear after too much driving and you have to turn off dyno mode to reset it.
that's about all i can tell you.
Old 06-07-2007, 03:49 AM
sdsilverm3's Avatar
No ABS in a 2 ton sedan. Care to guess how far your car would skid in the case of lockup?
Old 06-07-2007, 04:21 AM
TonyJ89117's Avatar
997C2S
I guess I will not be running my car in dyno mode.
Thanks guys!
Old 06-07-2007, 10:37 AM
newton22's Avatar
BMW E39
It's not that bad. It's like driving a 1952 E55. Seatbelts are optional too.
Old 06-07-2007, 10:51 AM
Jakpro1's Avatar
2003 E55 & 2014 GL550
Yeah, Dyno mode just for quickies my brotha.
Old 06-07-2007, 11:08 AM
SaMaS's Avatar
02 996 Turbo, 05 CLK55 AMG
there was no E55 in 1952
Old 06-07-2007, 11:10 AM
JAYCL600's Avatar
new balance
this correct
Old 06-07-2007, 11:36 AM
newton22's Avatar
BMW E39
You didn't really understand my post.
Old 06-07-2007, 11:38 AM
2MANYCARS's Avatar
20+ to list......
As the name says it, dyno mode is designed for use on dyno's ONLY.
Old 06-07-2007, 11:50 AM
jangy's Avatar
2015 S212
Airbags do not work and the tranny does take some extra time to shift about.
Explain your issues. I can get mine sideways and it still doesn't take over (if I have ESP off). Keep in mind that the tires size you are running has much to do with it. If you have aftermarket wheels with larger diameters, then the ESP kicks in sooner. I am actually running 0.5% smaller than Oem, so the car lets more spin before it kicks in.
Are you trying to drift or just go fast?
Old 10-01-2007, 12:45 PM
TonyJ89117's Avatar
997C2S
Jangy, sorry for the delay in responding. I did not know there were subsequent replies to my inquiry.
My goal is to have more fun with my e55 in the corners. Whenever I drive aggressively in my car into corners with ESP off, the computer still comes on and flashes the ESP light when I push it hard.
Also, if I try to power oversteer around corners and try my best drifter impersonation, the computer reigns in the fun and turns on stability control quite early. I cannot get my car sideways freely. However, I can get sideways a little, but cannot circulate sideways around even half of a 360 degree circle/corner.
I do have 20" wheels with 245/30 and 285/25 tires. However, are very close within the same overall diameter as the OEM tires.
My wheels
245/30/20 = 25.78" O.D.
285/25/20 = 25.61" O.D.
OEM wheels
245/40/18 = 25.72" O.D.
265/35/18 = 25.30" O.D.
What do you think my problem is? I have a 2005 E55.
Tony
Old 10-01-2007, 12:50 PM
Vadim @ FD's Avatar
S600TT, R350
The solution for traction issues is Quaife differential.
Old 10-01-2007, 12:56 PM
TonyJ89117's Avatar
997C2S
Vadim, but would this resolve the ESP issue? I agree a limited slip with an aggressive locking split would help traction considerably, but how about times when I just want to be a hooligan and drift sideways around corners? Thanks.
Old 10-01-2007, 01:04 PM
Jakpro1's Avatar
Maybe Jangy (one of our road racing guys) could chime in on drifting in corners. Out of my element there.
Old 10-02-2007, 10:06 AM
E55 RUSS's Avatar
E55K
So in 1/4 I cant use Dyno mode...
Old 10-02-2007, 10:22 AM
JAYCL600's Avatar
new balance
no u can use dyno mode in the 1/4
Old 10-02-2007, 10:46 AM
draggingcents2's Avatar
2005 E55
DO NOT DO IT WITH YOUR CAR! Use a dealer loaner to expeirment. I was given a C240 6 Speed and had it in Dyno mode. Well a few beers at lunch and I thought I was in my Z06 and locked the tire going into a fast right hand sweeper. I lock the wheels up and brought it up over a curb. $6,000 experment gone sour. DO NOT DO IT IN YOUR CAR. ONLY BAD THINGS CAN HAPPEN.
Old 10-02-2007, 10:54 AM
ItalianStallion's Avatar
R35 GT-R, EvoX
I used to use it all the time in my CLK until I noticed how many rear tires I would go through. Its good for drifting and fun, not for driving or racing.
Old 10-02-2007, 03:35 PM
Vadim @ FD's Avatar
S600TT, R350
Yes, you will still be able to slide your car.
Old 10-02-2007, 09:40 PM
chiromikey's Avatar
i have no problem with 1/4mile or dyno runs. it's the prolonged normal driving that it doesn't like.
Old 07-02-2020, 09:43 PM
toddchen17's Avatar
S211 E63
Is this a big issue and does it harm anything on the car? or is it a quick reset and off you go again?
Old 09-19-2020, 02:23 PM
Kebowers47's Avatar
001 s600, 94 sl600
These Mercedes 'street cars' are developed, tuned, and serviced to provide 'average owner' a Very Smooth, non-jarring, non jolting, non jerking driving experience,that gives one a feeling of total competence, safety, and predictable control. 'Drifting,, hanging tail out, burnouts, etc are not included within their normal driving capabilities.
THEY ARE DESIGNED TO ALWAYS HAVE ALL THE SAFETY FEATURES FUNCTIONING. LIMITED 'turn off' of SOME safety features are designed into 'DIAGNOSTIC FUNCTIONS ONLY to allow testing of certain capabilities. It would require a lot of 'module level' re-programming (serious hard core stuff) to 'turn off' the various, inter-connected safety systems (some of which are mandated by our Federal Dept of Transportation) to 'allow' these 'out of normal control' conditions. The manufacturers and service business, by law, cannot implement or allow Owners' to easily defeat or 'turn off' ' Federal mandated Safety Features. Federal law does not allow the Diagnostic Mode tests to be used in Normal Driving--they MUST automatically turn-back to NORMAL after a very short time of operation. I would not be surprised that some day soon the DOT will mandate use of a 'special limited ID token' issued only to "federally licensed 'mechanics," to activate any 'non-normal'' or 'diagnostic mode' of operation.
Old 09-20-2020, 06:04 PM
Ls1toAMG's Avatar
2004 E55.98 SS Camaro.Jetta TDI. Expedition
All I know is when I turn my ESP off, it's off. I can do anything and it never kicks in. Cheerios, drifting and all.
Quick Reply: Dyno Mode: Any problems using full time?
