*** VRP Extreme Belt Wrap Kit ***
Old Jul 14, 2007 | 05:20 AM
  #101
Finny's Avatar
03 E55 AMG
Originally Posted by Stuttgart Tech
MB design 20-25% slip with current design. I want understand how measure slip i sorry i mean different. With new clutches use they change clearance inside clutch as well all techs have to check clearence when install new assemble yes new idle have better bearing but my concern is clutch not handle less slip from belt will cause failure.
"MB design 20-25% slip with current design." Wow! They actually did this on purpose? Can you imagine the pulley doing burnout's on the belt? Yeah why not! belts are cheeper than s/c clutches hey. Now I finally understand MB's genius methology on saving the supercharger and clutch system.
In regards to the clutch slipping I had the same theory that loss could be occurring in this region as well so I locked up the clutch electrically and marked where they join, then in dyno mode I ran it through all the gears flat stick.
Surprise Surprise... No Clutch Slip with the proto wrap, aux tensioner and a 175mm pulley. It's only a matter of time before the second gen clutches have been street tested. I looking forward to feed back from the 20 or so happy campers.
Finny i send message we talk, yes i live Stuttgart.
Yeah cool, PM me your phone number and we'll organize to catch up on my trip.
You have understand this supercharge basic design is from very early c-klass kompress and MB make rotor longer. It street design not race it have slip engineer not make clutch and bearing system to do this. Extra pressure to clutch paks cause overheat and failure. This design will work very good for short time until clutch and supercharge problem occur.
Lysholm style compressor air pumps have been around long before MB decided to get their mits on them. The actual rotor length is designed to flow enough air to fill our 8 little pot holes. Volume is determined by rotor length and pressure is dictated by outlet size. After pulling apart the gear house and removing the rotors I noticed that MB have used massive high speed bearings and shafts which I'm quite sure it can handle all the extra stress.
An interesting s/c FAQ link with lots of info on engine wear and longevity: http://www.hi-flow.com/HP4FAQSuper.htm
"Extra pressure to clutch packs cause overheat and failure" I'm yet to see a case. Do you know of any 55 clutch failures that have been published? I would be really interested to see a burnt out solid steel clutch.
Vrus and Finny Danke schön! I not here to fight my english not good but like people no like Klaus for try help, i only want understand for customer, how i know who customer is here, he ask me to check out. I not install for customer because will cost later I sorry for try help Finny i message anyone if need help please message.
Fight ???... Who is here to fight??? I find solutions to real world 55 problems through free thought and critical inquiry.
Old Jul 14, 2007 | 11:40 AM
  #102
Zod's Avatar
Zod
CLS55 2006, CLS 63S 2015
Guys chill a bit on the (this guy is a fraud) and give him a chance. He is new to the forums and by his own words says his English is not one of his strengths.
If he came on and said it was crap and gave no explanations, then by all means fire away. He is new and might not know the humour that we have on these forums & might been seen differently.
I really enjoy going through these threads and seeing the work of such great men and how they transfer their knowledge and expertise into our cars.
I am sure we are all car enthusiasts here and it is work such as this that helps us reach new plains of understanding for our cars.
Peace out
Old Jul 16, 2007 | 01:45 PM
  #103
Jakpro1's Avatar
2003 E55 & 2014 GL550
Just got the kit in today V!!!
Thank you so much!!
Can't wait to install!!
Old Jul 16, 2007 | 02:15 PM
  #104
higginsbeach's Avatar
2004 E55 AMG and 2003 C320 4Matic Miss my 993 Turbo above!!
Hey Jim,
Mine is coming this week. Let me know how things go on the install so I may share with my MB Guy.......
Good luck......Are you planning on doing a pre and post DYNO. I know there should not be any HP gains so it may be a wasted DYNO expense.
Roland
Old Jul 16, 2007 | 03:12 PM
  #105
SleeperX's Avatar
E55
Originally Posted by higginsbeach
Hey Jim,
Roland
You should not see choppy lines above 5K rpm. In addition, your A/F ratio should not fall off the charts around the same point. I highly recommend a post dyno..
Old Jul 16, 2007 | 03:40 PM
  #106
ROCKETW19's Avatar
06 EuroElites E55
+1
hey zod, if you dont know, you dont know!
Old Jul 16, 2007 | 04:49 PM
  #107
AdamG@NorCal's Avatar
EVOTECH Mercedes AMG
Thanks Vic,
The package arrived safely. Looking forward to the install this week.
Old Jul 16, 2007 | 06:52 PM
  #108
jangy's Avatar
2015 S212
I love all this cutting edge stuff. Why aren't we running chains and locked SCs anyway? This belt crap reminds me of the days that timing belts popped left and right.
Old Jul 16, 2007 | 07:10 PM
  #109
Jrocket's Avatar
E55
Chains? As in timing chains?
Old Jul 16, 2007 | 07:15 PM
  #110
jangy's Avatar
2015 S212
Haha!! You know it. In all honesty, I do think that MB designed the belt as the weak link. I'm all into getting the most out of these things, but I do worry about adding tension. I definitely believe that these belts slip, but I'm just worried that we will end up with a new weak link if we lock this down.
Old Jul 16, 2007 | 08:04 PM
  #111
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
this kit appears to be designed to reduce slip by increasing contact area not by adding pressure. with the proper size belt i can't see this system adding any more tension to the s/c pulley than oem...but wtf do i know compared to the knowledge and experience chatting in this thread?
Old Jul 16, 2007 | 08:11 PM
  #112
Venom-AMG's Avatar
21 G63, 21 GLS580, 16 GTS Ed. 1
Got my kit in the mail today. Now I just need install instructions. Anybody?
  #113
jparch's Avatar
2018 E63S wagon, 2016 GLE350d, GLE450 on order
it does add tension to the system, did you not see the picture of the tensioner that finny designed to go with it also?? you could wrap that belt around 300degrees and if there is not enough tension it will slip; no slip = more tension.......
Old Jul 16, 2007 | 08:38 PM
  #114
rflow306's Avatar
2005 E 55
The tensioner is a separate piece, you can run the kit with-out the heavy duty tensioner. It will still work good with the factory tensioner spring because of the increased belt wrap.
Old Jul 16, 2007 | 08:39 PM
  #115
Jakpro1's Avatar
Nah, being lazy on this one. Plus having massive belt problems so I really need to swap out the pullies and then the crank pulley asap.
Old Jul 16, 2007 | 09:35 PM
  #116
chiromikey's Avatar
there is also a new secondary idler pulley. so now instead of adding tension in one direction to significantly push against the s/c snout, you have two pulleys adding tension in opposing directions. so yes the belt is tighter around the s/c but the net force against the s/c snout would not appear to be signifcantly increased.
*maybe we're discussing two different things. i'm talking about tension against the s/c snout and i believe you're talking about belt tension. like i said, wtf do i know...
Old Jul 16, 2007 | 10:05 PM
  #117
Will I be the only one running the complete set on stock Pully's? I am not doing the pully upgrade until I complete phase I......
Roland
Old Jul 16, 2007 | 10:36 PM
  #118
OzE55's Avatar
2003 E55
Why aren't we running chains ............
Noisey as all hell, I suspect. No quite an MB image thing.
Old Jul 16, 2007 | 10:39 PM
  #119
Finny's Avatar
03 E55 AMG
Just to clarify a few items...
The added tensioner is spring loaded and is tension adjustable so it actually moves with the stock idler. It supplies some extra tension to the stock s/c idler not locking it up.
There is a new bearing supplied with the kit which is wider than the stock combined idler pulley to strengthen this area. (the one with the accessories and s/c together)
A slightly larger pulley is added to the s/c idler to help gain more s/c pulley foot print area.
The belt supplied is the new Gates fleet runner which is used for large trucks where gates claim 30 to 40% extra life span over their stock belts.
Reinforced, No slip and Longevity! to help efficiency and maximize potential power. Thats the whole idea.
If any one has any install questions, throw them my way.
Old Jul 16, 2007 | 11:12 PM
  #120
ROCKETW19's Avatar
06 EuroElites E55
does adam have you phone number? he will be installing mine on wed. and i think he has one gettin installed right now.
i will be great advertising for this product cuzz my dyno looks crazy at high rpms. i will do a before and after to show this does or dosnt work. witch im sure it will.
Old Jul 16, 2007 | 11:14 PM
  #121
vrus's Avatar
2003 E55 AMG
Guys.. Just wanted to add that I am polishing up the install documentation.. I did not want to hold up the boxes from going out so please bear with me while I complete the installation instructions.
Adam @ EE is doing the install for Michael's car and has a preliminary copy of the docs.. Once they are cleaned up, I will post a link for all of you to download.
Old Jul 17, 2007 | 12:33 AM
  #122
Jakpro1's Avatar
So far so good on mine. Pretty easy install so far.
I am trying to do it without taking out the fan so my arms are paying the price, but real nice setup Fin and V!!!
Was hoping to have it done tonight, but just too burnt. Hopefully Tuesday.
Old Jul 17, 2007 | 03:37 AM
  #123
Finny's Avatar
03 E55 AMG
Thank's, glad you like it.
You must have small arms to get in there.
Old Jul 17, 2007 | 03:54 AM
  #124
Update:
Michael's E55 is coming in on Wednesday for the V.R.P Xtreme Belt wrap kit install.
Will give updates on Thursday after dyno.
Cheers,
Adam
PS: So far the parts are well constructed. Kudos to Finny and VRUS.
Old Jul 17, 2007 | 06:54 AM
  #125
stevebez's Avatar
No longer stock '06 E55, A3 3.2 Quattro, GLE 400d, R107 280SL, Golf Polo
Finny is the gates belt the Micro-V series belts ? I cannot find the "fleet runner" series?
