Why does the CLS55 exhaust sound much more aggressive than E55??
997C2S
Hey guys,
Why does the CLS55 sound so much more aggressive than our E55s? I was listening to my buddy's stock CLS as he was passing by and his car sounds sweet with a nice rumble and a hint of raspiness. We then switched cars and mine sounded much quieter.
Why?
Tony
Why?
Tony
Because CLS55 is way faster compared to the e55! i better hop outta here, before someone break out a flame thrower
anyways, yea... i notice that too. boss got e55 and mind does sound louder.
Hey guys,
Why?
Tony
Why?
Tony
997C2S
997C2S
Is this true?
Stainless?
Tony
i'm running long tube headers with the primary cats removed, highflow cats in the secondary position, and no resonator all flowing into the oem mufflers and i still think the car is almost stock quiet. it's pretty simple...if you want better sound, you'll have to fit aftermarket mufflers.
997C2S
no, it's not true. the resonator is a straight through design and offers so little backpressure it you won't even feel the difference. but to be honest, i doubt you'll hear any appreciable difference either.
Thanks for the feedback.
Are the mufflers the primary reason the CLS55 sounds so much burlier than the E55? Also, are there any negatives of installing free flow mufflers? I know that on a turbo car you want to reduce back pressure as much as possible to increase power, but are supercharged cars different? I am guessing yes, since SC cars are not exhaust gas driven.
I was also told that certain performance mufflers will actually reduce power compared to the OEM mufflers. Is this another myth?
2015 S212
The short story is that you can pick sound or performance. Unlike "muscle" cars, where sound and performane go hand in hand, the SC engines do NOT like the open exhaust setup.
The key on performance is to tune it. The key to sound is also tuning. You may be able to find that happy medium where your car runs strong AND it sounds strong, but nobody here has tried that yet. There are a few custome exhausts running around, and we will see the true gains once all of the 80mm TBs, etc are in place. In the end, getting air into and out of the SC unit is the bottleneck. If you open up the exhaust too much, it will sound LOUD, but it will not have optimal flow through the screw.
Prime example is an Eis race exhaust with cats cut and headers. You LOSE power over the same setup with the cats. It sounds WAAAY loud, but loses low end.
Last thing, when we speak of power loss, we are talking low end. If you don't care about that, then all bets are off.
2015 S212
that is true...if you're replacing the entire system or removing all backpressure. most of the backpressure from our exhaust comes from the primary and secondary cats, so if you're only replacing the mufflers you could go with any aftermarket muffler and not notice any difference in performance. keep in mind that our cars have so much low end tq that we can afford to trade a little for upper end hp...most cars don't have that option which is the reason many shops warn their customers about "losing power".
