So im upgrading my pulley to Kleemann... DO I NEED A NEW BELT???
Old Jul 3, 2007 | 11:48 PM
jdj27x's Avatar
Lightbulb So im upgrading my pulley to Kleemann... DO I NEED A NEW BELT???
I will be installing a kleemann pulley to replace my oem pulley.
I hear that some people replace their belt so that they work more efficent.
What belt do i need for the kleemann pulley? Part number and website would be so great!
Old Jul 4, 2007 | 02:47 AM
jdj27x's Avatar
Bump
Old Jul 4, 2007 | 03:13 AM
Ted Baldwin's Avatar
300ce
Originally Posted by jdj27x
Bump
...........Generally with the kleemann and Renntech Pulle's you can use your stock belt. with AsP pulley, you need another belt. If your question is whether or not you should use a fresh belt when you get new pulleys, the best anser is yes.
Ted
Old Jul 4, 2007 | 03:15 AM
Acez's Avatar
2001 Kleemann CLK 230K, 2006 CLS 350, GTR R35
Kleemann pulleys comes together with a replacement belt. If you don't find it, guess you got ripped off.
Old Jul 4, 2007 | 03:44 AM
jdj27x's Avatar
i got a used pulley.
anyone know the brand of the belt kleemann supplies? part number?
Old Jul 4, 2007 | 03:51 AM
FlyByNight's Avatar
05 E55
They use a stock belt, as Ted said above. Use the one you have, or splurge and get a new one at the dealer. But there is no special belt they use...
Old Jul 4, 2007 | 03:54 AM
rrichard's Avatar
CLK500 (W209), Audi RS5, Harley NightRod Special, Suzuki GS1000
mmmm
Hi guys, whats to be gained by replacing the pully? I have a CLK500 and was thinking about the Kleeman chip upgrade.... and advise? Cheers. R
Old Jul 4, 2007 | 04:05 AM
jdj27x's Avatar
i wast told that there is a better belt to use then oem. any help?
Old Jul 4, 2007 | 05:01 AM
Venom-AMG's Avatar
21 G63, 21 GLS580, 16 GTS Ed. 1
Quick question also. What belt will the asp pulley need? part #?
Old Jul 4, 2007 | 05:31 AM
jdj27x's Avatar
Dayco part number: 5080515. This is for the asp pulley ONLY
Old Jul 4, 2007 | 07:41 AM
300ce
.............seems you really want to buy some sort of special belt. There is no special belt. Any belt with the same length and number of ribs will work. The dayco belt for ASP is only because ASP pulley is much larger than the Kleemann pulley and needs a longer belt. The dayco belts are probably a little stronger than oem, but nno such thing as a belt that makes your pulley "more efficient." Someone is going to sell you some snake oil.
Ted
Old Jul 5, 2007 | 09:04 AM
x-tian-230k's Avatar
CLK500/Range Rover HSE/E55 AMG/Bmw 328Xi coupe/BMW 4.8x/Bmw 335i/GS350/Audi S5/E350
On supercharged engines larger crank pulleys provide more boost to the supercharger..... I am not sure your CLK500 would benefit much from a crank pulley swap....
Old Jul 5, 2007 | 11:45 AM
PTE's Avatar
PTE
05 ML-500 , 03 CLK5.5 AMG has left the Garage
N/A Motor Underdrive pullies
rrichard: Did did several sets back on the CLK5.5 board. These are pullies that VRP Performance Stocks (Vrus) here's a small clip of the install , and yes they help
I installed a set of these pulleys on my 2003 CLK 5.5 AMG . Just for Grins , I wanted to Check the Quality of the workmanship , So I, 1 st checked them on my lathe Before installing them . They were very STRAIGHT and precision made. Too within .0005. And thats excellant. The installation was pretty straight forward, Abit of a pain, because I left everything Mounted on the engine. No removal of assys.
The Alternator pulley nut was on Tight!!. It took a strap Wrench and a 24" breaker bar , too get it loose.Once that was done . The pulley will slide right off easily. The Water pump pulley is a no Brainer . The Power steering pulley is touchy!!
To do that one right, you will need to a K-D Tools,Pulley remover / installer Set. Part Number K-D 2897 . I brought mine from the NAPA Store . Expect to pay about $83.00 / E-bay $45.00. Or borrow one . This one works great and will not damage the OEM or VRP performance Stuff. Sometimes the Auto parts stores have a tool rental / loaner program, You just leave them a deposit .
Remember !! with a poly vee belt , The pulley alignment must be PERFECT!!
I then dynoed the car . I pick up about 10 HP at 3000 RPM thru 4200 rpm Band, only 2 HP @ 6000 rpm. Was it Worth it. YES ,I will take the increase . A HP here & a HP there adds up at the end of the day. It's tough to measure the rate of acceration on the dyno. I just had to remember , these cars do not always respond big , to these mods , like the claims ?? made for some American made engines . You can race dynos all day long . But History is made on the track!!
Regards ___PTE__
