19X9.5's in the rear.. Correct tire size??
Old Jul 22, 2007 | 03:35 AM
e55amg00's Avatar
2017 Alfa Giulia gone, 2004 e55 amg gone,2014 E550 coupe white,2010 E550 coupe white, 2018 giulia ti
Red face 19X9.5's in the rear.. Correct tire size??
My E55 currently has 18x8.5's, 35 offset with 245/40/18's in the front and 18X9.5's ,38 offset 285/35/18's in the rear.. I'm upgrading to 19's but they are 8.5 with a 32 offset in the front and 9.5 and 35 offset in the rear. Can I still use 285's(285/30/19) or do I have to drop to 275's because of the offset. I really like the way the 285's fill the well. My suspension is lowered via the SDS so that u can barely get 2 fingers between the tires and wells now...Any input would be greatly appreciated.
Old Jul 22, 2007 | 10:06 AM
sang55's Avatar
K3 05 E55 sold, 09 GL550
You should shoot Jangy a PM or hopefully He cans chime in and tell you what correct the offset of your car
Old Jul 22, 2007 | 12:28 PM
jangy's Avatar
2015 S212
"38 offset 285/35/18's in the rear"
You sure about that? If they are OEM, then they are 18X9et39.
Anyhow, I'm pretty sure you are going to be pushing it with the 285s. If you have a set and can test fit, I say try it. But honestly, I think it will rub on the ouside. The 275 will fill the well nicely, but you will have "wasted" room on the inside.
Maybe consider shaving the rims a bit? Depending on the make and model, a 4mm shave on the inside is usually very standard and that would put you into the 285/295 range. I dunno for a fact that a 19" 295 can work, but a 285 will for sure.
Old Jul 23, 2007 | 01:06 AM
e55amg00's Avatar
Question
I took my OEM's off shortly after getting the car and put on Cl/SL65 style rims. That's why my 18's are 8.5 and 9.5's. they fit nicely but i was concerned about the 19's with the 35 instead in 38/39 in the rear... I like the fatter tire, plus it's better protection for the rim using the 285's. I'm afraid that they might rub like you said. Who can do shaving of the rims???
Old Jul 23, 2007 | 02:27 AM
sang55's Avatar
I'm currently running 19x8 F &19x10 R with 245/35 & 285/30 with no problem at all .My car is not lower but will do Renn ELM this weekend I will find out or maybe PM Jangy before I do it .
Old Jul 24, 2007 | 04:41 PM
e55amg00's Avatar
Hey Killer, what is your rear offset on the 19X10's???
Old Jul 24, 2007 | 07:12 PM
jangy's Avatar
2015 S212
You can get the wheels shaved at any good machine / race shop. i have a great one down here, so I am a little more willing to try stuff.
19X10, I'd bet the offset is right at 40, if a 285 fits nicely.
Old Jul 24, 2007 | 07:16 PM
psk145's Avatar
2006 E55
Im running 285 rears and 255 fronts. Here are my offsets
Fronts: 19x8.5 offset is 36
Rears: 19x9.5 offset is 38
no rubbing at all
Old Jul 24, 2007 | 08:50 PM
jangy's Avatar
2015 S212
no rubbing at all
Does it look like you have room inside and out to go 295s? I think you could. Just a thought.
8.5 fronts? Hmmmm, I better make sure my HREs aren't 8.5 on the front. They are supposed to be 9s.
Old Jul 25, 2007 | 01:54 AM
psk145's Avatar
2006 E55
I could probably go 295, but Im taking baby steps.
The wheels were initially made for a C32, so thats why the offsets are different, but they work perfectly for the E
Old Jul 25, 2007 | 05:17 PM
jangy's Avatar
2015 S212
My guess would be that you can go 295 in the rear, but not sure if you can do much else with the fronts. That is a pretty agressive offset for wider tires.
I love your setup. The silver on silver is such a nice match. You got lucky on the setup swapping over. You ever consider havving HRE rebuild them into 9 inch front and 10 inch rears?
Old Jul 25, 2007 | 06:43 PM
e55amg00's Avatar
Hey guys,
I just tried OEM SL65 wheels 255/35/19 , 30 offset in the front ,and 285/30/19, 31 offset in the rear and they fit my E perfectly. Thear rears just made it with that offset. They're tucked in pretty tightly. I don't think using these sizes for my rims will be a problem since I'll be running 32 & 35 offsets respectively... I saw 245's and 275's on the same widths and they just looked too small. It was as if the tires were being stretched to fit the rims.
Old Jul 25, 2007 | 09:41 PM
jangy's Avatar
2015 S212
Hey guys,
Have you tried dropping it and running it? I would thinki 285s would rub with that offset on the outside over speed bumps. As a trick, I heard you could flip the 65 wheels around to get the offset a bit better.
Old Jul 25, 2007 | 10:05 PM
e55amg00's Avatar
Question
I did run the car and drove over some secondary bumps with no problem... However, I didn't go over any speed bumps. Do you really think it'll rub over the bumps with the 32/35 setup? I didn't think there would be a problem since my buddy's SL wheels fit with the more aggressive offset. I'd like to buy the same Bridgestone Potenza RE050A tires that he has. I currently have Goodyear Eagle F1DS' on my car.
Old Jul 25, 2007 | 11:32 PM
jangy's Avatar
2015 S212
I think the 35 is TIGHT for 285s, but definitely may work. I was only getting rubbing at et35 on really tight turns when I had the car fully dropped. What rubs is actually the sidewall, not the tread.
The fronts should work with 255s, but no taller or wider.
The tires you are choosing are the best for clearance of the nicer tires, so you have the best odds of success. Good luck.
Old Jul 26, 2007 | 03:30 AM
psk145's Avatar
2006 E55
Is there any advantage? I might have them redo my centers as the paint is all chipped off. The paint they used is so soft, it chips and bubbles if you give it a dirtly look.
I thought 295 rears caused a wiggle
Old Jul 26, 2007 | 08:57 AM
sang55's Avatar
I don't know about the off set but my rear wheels had 4' lip deep with 285/30 and the front had 2.5' with 245/35 . Jangy can you tell me i'm running the right off set or ..... Thanks
Old Jul 26, 2007 | 11:19 AM
jangy's Avatar
2015 S212
What's the advantage? You'd be adding a 1/2 inch of width to each corner. Even if you keep the tire sizes the same, you will have a much quicker turn in, since there is no lag between the pull on the tire (laterally) AND the car will lean less. It was just a thought. I would do that before I got new ones, cause your centers look HOT!
295s do not cause the wiggle. Having a tire that is too close to the inside (subframe) is what causes it. When you pin your car, the rear wheels toe in due to the TQ. That means that if your tire is close to the inside while standing still, it may flex enough to rub the inner part of the tire on the subframe. If that happens, you can tear up the tire = blow out under acceleration = ****!!
That is why proper offset and suspension support is so important when you start modding.
Old Jul 26, 2007 | 11:32 AM
jangy's Avatar
2015 S212
Bro, how can i tell you if you are running the right setup if I don't have your specs?
I can tell you that getting a 4" lip on an E and still running 285/295 is nearly impossible without some slight fender roll. That isn't to say it can't be done. I'm big on performance, so I don't get into those things. If that is your thing, I say try it until yuo get what you want. The wheel companies aren't interested in extreme fittments, since there are so many variables and they would end up having to troubleshoot. So, they just say it can't be done when it can.
Prime example, find a single wheel company willing to fit 9.5 inch rims in the front and run 275s. ALL of them will say it will rub and yet, I've fit tested a 275 on one AND run 275s on a 9 inch rim all the time. It is all about the demand.
When you guys start to demand wider tires on the front, wider rims will pop up. For now, they still get the exact same money from you and get you to run 255s.
Old Aug 7, 2007 | 05:47 PM
e55amg00's Avatar
Talking
Well I finally got the Potenza's RE050A's- 255/35/19's for the front and 285/30/19's for the rears and had them mounted on my '08 style CL/S 63 rims. Had no problems with either size rubbing even with my lowered suspension. The 32/35 offset that I have is perfect. I wonder if I could have gone with 295s in the rear? Looks like I have room to spare.
Old Aug 7, 2007 | 06:00 PM
jangy's Avatar
2015 S212
Very nice!! Let's see some pics. With that offset, I would only be concerned of the outside for 295s. If it looks like you have room, then it may work. I am running 9.5s et37 and there is very little room to spare, but no rubbing at all.
Old Aug 9, 2007 | 10:47 PM
e55amg00's Avatar
I'll put some pics up this weekend. Just got my car back late today from the dealer. The trans control unit was replaced. By the time I got home it was a little too late for pics. I'll definitely try to post some this weekend....
Old Aug 11, 2007 | 05:47 PM
e55amg00's Avatar
Here are a couple of the pics of the car
Attached Thumbnails 19X9.5's in the rear.. Correct tire size??-p1010330.jpg   19X9.5's in the rear.. Correct tire size??-p1010329.jpg
Old Aug 14, 2007 | 12:37 PM
AMG Rider's Avatar
2004 MB E55 AMG, 2006 Audi A6 4.2, 2008 WRX STI
sick!!!definately the best looking AMG rims!!
Old Aug 14, 2007 | 08:54 PM
Quick1's Avatar
AMG
OMG, I was wondering how those wheels would look on a white 55 and now i think ive made up my mind
