Low power E55 - new Kompressor clutch
03' E55, 06' Kawasaki ZX-10R
Hi,
i got my 03' E55 about 6 weeks ago. While the car is fast, it doesn't quite feel like a low 12 second car. I think the kompressor clutch is bad.
I know the kompressor is running because I felt it shut off once after a couple real hard runs and that was a very dramatic loss.
Right now the car feels like it is good for maybe low 13's in the quarter. I have heard others talk about this part going bad, and I can hear mine chirp on a quick throttle blip etc.
Can someone let me knwo where i can buy this part?
Also, do you think this is the problem?
Hi,
2004 E55 Evosport I & II; VRP H/E
Put it on a dyno.
Take it to a track and see if it, in fact, runs in the low 12's or in the 13's. (I guess that my sense of speed and distance is not as keen as yours. Sometimes when I have gone to a track and thought that I had a bad run, the timeslip indicates differently. My point is that I would run it at a track instead of relying on the fact that the car “feels like it is good for maybe low 13's.”
S600TT, R350
Steve: Congratulation on E55 and welcome to MBworld.
My best recommendation is to purchase an ODBII scanner. You can find them at PepBoys for low-end units or if you a laptop or PDA go with www.nology.com or similar units.
E55 is complex car and being able to read will help you with maintenance and upgrades.
Now, what you are describing is a very common failure on 55s - intercooler pump. When engine computer sees intake tempreatures exceed 225F, it shut-off the kompressor clutch.
If you have a CPO or extended warranty, than take your car to MB of Torrance and talk to Chris in service, he knows 55s and will take care of you.
If you are out of warranty, we are not too far from you and I have been working on 55s since they first came out in 2002.
Good Luck!
Good Luck!
2004 E55 AMG and 2003 C320 4Matic Miss my 993 Turbo above!!
Good Luck!
Good Luck!
Roland
Just had my I/C pump replace on my 03'.........problem seems to be fixed for now. Service adviser told me if the problem persist he would install a after market pump for free. I think he's becoming my best friend.
Now if I could just get him to slide some SLR parts in there I would put him in my will......possibly name my first born after him.
S600TT, R350
Does anyone here actually use this product and how accurate are they if used as a DYNO?
It is good for measuring before and after.
As far as ODBII, very nice and easy to use.
Thanks for the responses guys.....
I am under the impression that with a bad IC pump, the power loss comes from the supercharger just shutting off.....which is a dramatic power loss.(I have experienced this after a few hard runs and that difference was enormous) If I am wrong please let me know.
That is not what I am experiencing...the car still has plenty of power, It just isn't at full power (I have owned/ridden in several low 12 second cars....)
This makes me think I am not at full boost, running very rich, etc.
I did a little more research and it looks like when the S/C clutch goes bad you lose all of the supercharge power too. I hear the "chirp" shich indicated the clutch is engaging.
So now i am thinking that maybe either the belt is slipping(although I don't hear it) or perhaps the computer recall was done in which a few others on the board lost 70 or so rwhp(perhaps I am one of the unlucky ones). That is about how the car feels, it is still fast, but feels to be about a 350rwhp car and not a 420-430rwhp car.
either way, I bought this car for the horsepower and i want it.....I need to get this problem addressed, preferably without coming out of pocket as the car was expensive enough for me.
thoughts?
thoughts?
S600TT, R350
Steve: When clutch slips, it lets go completely, so it will be very similar to IC pump problem.
How many miles do you have?
Pull off fron engine cover and take a look at the kompressor belt, if it slipping severly, you will see it on the belt and all around.
If you want to chat call me.
thoughts?
thoughts?
thoughts?
thoughts?
I would have the service adviser check the service records to see if the ECU was ever flashed. And I'm with Higgins....get it DYNOED.
CL 55 AMG
thoughts?
thoughts?
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
E55
