bad intercooler pump symptoms?
about two weeks ago in 96 degree weather I ran the car from 40-120mph and the supercharger shutdown, car had no power for about 5 minutes, then everything was fine....
the other day, in cooler weather, 85 degrees, I ran it from 40-120mph and it shut down again...
does this point to the IAT's and bad cooling? the car is fine with shorter sprints, 0-80mph, etc.... but longer sprints with more load and the car dies powerwise...
thanks!
thanks!
Get the thing in and have it replaced if under warranty with the new upgraded bosch unit.
The root cause is usually a bad IC pump but not always the case. Another root cause may be that the standard intercooler setup is not sufficient and the IC pump is functioning as it was design and functioning properly. If it is the second case because there is substantial mods done, then improving the intercooling system is the solution not throwing in another stock IC pump into the stock insufficient intercooling system.
all referring to the computer for the engine.
https://stumptownbenz.com/custom-ati...-for-the-m113/
